Mods, Upgrades and Fixes Catalog - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 13 (permalink) Old 01-24-2013, 03:38 PM Thread Starter
Supernova
DEcosse's Avatar
One of the members asked me to create a Reference Thread of quick links to some of the Mods, Upgrades and Fixes that have been posted previously and which apply to the Daytona range.
Thanks Henkka83 for suggestion.
Please don't make this a discussion thread - take any questions on any of the links directly to the link thread itself.
I'll start it off - please add as you find appropriate, whether your own personal work or something you found helpful as you came across in research.
Some of the links may be in other sub-forums (Sprint or Speed Triple) where there is commonality in specific application.
All suggestions listed below this post will also be incorporated into Post #1 to make a complete listing.
OEM Part Number Find
https://www.triumphrat.net/speed-tri...r-locator.html
T595 Ground Block
https://www.triumphrat.net/speed-tri...ml#post1592416 (post # 10)
Charging System Diagnostics
https://www.triumphrat.net/speed-tri...r-upgrade.html
Headlight Upgrade
https://www.triumphrat.net/speed-tri...provement.html
https://www.triumphrat.net/speed-tri...t-install.html
Headlight Cut Till start
https://www.triumphrat.net/speed-tri...ml#post2365636
Starter Power Mod
https://www.triumphrat.net/speed-tri...power-mod.html
Digital Speedo Conversion for 97-01
https://www.triumphrat.net/speed-tri...o-97-01-a.html
https://www.triumphrat.net/speed-tri...d-daytona.html
GSXR Fork Swap
https://www.triumphrat.net/speed-tri...-complete.html
Speed Sender Alternative Solution
https://www.triumphrat.net/speed-tri...rly-model.html
Quick Throttle
https://www.triumphrat.net/speed-tri...ottle-mod.html
Digital Instrument Panel LED upgrade
https://www.triumphrat.net/speed-tri...g-02-04-a.html
Seat Padding/Cover Upgrade (Great Day to Ride)
https://www.triumphrat.net/speed-tri...t-upgrade.html
2002 Ignition Circuit difference (NOT in manual!)
https://www.triumphrat.net/daytona-d...n-circuit.html
Fork Selector Shaft Oil Seal leak
https://www.triumphrat.net/speed-tri...-resolved.html
Keyless Ignition System
https://www.triumphrat.net/speed-tri...part-deux.html
Chain/Sprocket Replacement
https://www.triumphrat.net/maintenan...-part-1-a.html
Rear Hub Bearing Maintenance
https://www.triumphrat.net/maintenan...-bearings.html
Valve Clearance Adjustment (1050 but same for 955 02+)
https://www.triumphrat.net/maintenan...t-5-notes.html
Fuel Pump Fitting Replacement
https://www.triumphrat.net/daytona-d...placement.html
Fuel Tank Leak from Drain/Vent Nipples
https://www.triumphrat.net/daytona-d...leak-help.html
Clutch Switch Bypass
https://www.triumphrat.net/speed-tri...-o-clutch.html
Installing relay for heated grips
https://www.triumphrat.net/daytona-d...ted-grips.html
Fuel Bot- Fuel level and MPG Gauge
https://www.triumphrat.net/speed-tri...ever-find.html
Quick Release Seat
https://www.triumphrat.net/speed-tri...at-screws.html
Steering Head Bearing Replacement
https://www.triumphrat.net/sprint-fo...tml#post501700
Raised Handlebar Position (inverted clip-ons)
https://www.triumphrat.net/daytona-d...-position.html
Header Cleaner
https://www.triumphrat.net/speed-tri...away-pics.html
Full Range Fuel Gauge
https://www.triumphrat.net/daytona-d...tona-955i.html
Easy Clutch Pull
https://www.triumphrat.net/daytona-d...ft-clutch.html
Lowering rear via Sprint Brake Swap
https://www.triumphrat.net/speed-tri...ed-triple.html
Sprag Clutch Replacement Option
https://www.triumphrat.net/speed-tri...nt-option.html
DEcosse is offline
post #2 of 13 (permalink) Old 01-24-2013, 04:06 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
https://www.triumphrat.net/daytona-de...ted-grips.html
https://www.triumphrat.net/speed-trip...mpg-gauge.html
Felony is online now
post #3 of 13 (permalink) Old 01-25-2013, 12:29 PM Thread Starter
Supernova
DEcosse's Avatar
DEcosse is offline
post #4 of 13 (permalink) Old 01-26-2013, 03:54 PM
Not sure if this one qualifies:
https://www.triumphrat.net/sprint-for...tml#post501700
post #5 of 13 (permalink) Old 03-26-2013, 01:41 PM Thread Starter
Supernova
DEcosse's Avatar
DEcosse is offline
post #6 of 13 (permalink) Old 06-16-2013, 01:52 PM Thread Starter
Supernova
DEcosse's Avatar
DEcosse is offline
post #7 of 13 (permalink) Old 06-30-2013, 05:28 PM
Main Motorcycle: 2001 955i
malfino1's Avatar
You are an excellent person my friend. I have looked at this triumph site for months. Ive appreciated your infomation. You also know tuneecu. I am a top level machinist that works nights. My ride is my love. Every persons gives me a thumbs up on the idea. Thanks for this website. I hope I can help....
Sent from Motorcycle.com Free App
malfino1 is offline
post #8 of 13 (permalink) Old 12-27-2013, 06:02 PM Thread Starter
Supernova
DEcosse's Avatar
DEcosse is offline
post #9 of 13 (permalink) Old 10-19-2015, 02:04 PM Thread Starter
Supernova
DEcosse's Avatar
DEcosse is offline
post #10 of 13 (permalink) Old 03-16-2016, 01:39 PM Thread Starter
Supernova
DEcosse's Avatar
FuelBot link has been updated to the location for the new Fuelbot2.0 thread.
DEcosse is offline
Any one doing upgrades or mods this winter? LakeRat Hinckley Classic Triples 40 03-21-2012 11:58 PM
Winter Mods and Upgrades propforward Air Cooled Twins Talk 150 06-25-2010 11:20 AM
order of upgrades and mods primodulce Air Cooled Twins Technical Talk 8 05-13-2009 04:23 PM
Performance Upgrades and Mods Thread MotoZiggy Speed Triple Forum 11 02-16-2009 02:56 PM
New Thruxton mods/upgrades wroding Air Cooled Twins Technical Talk 14 09-22-2008 11:35 AM
