2013 Thruxton (EFI), cranks but won't start. HELP! - Triumph Forum: Triumph Rat Motorcycle Forums
Club Cafe' Cafe Racers; the Thruxton, Bobber and other custom cafe styled bikes.
 3Likes
post #1 of 11 (permalink) Old 10-09-2019, 02:26 AM Thread Starter
Main Motorcycle: 2013 Triumph Thruxton
MASSIVExATTACK's Avatar
Other Motorcycle: 1982 Yamaha Maxim 650
Question 2013 Thruxton (EFI), cranks but won't start. HELP!
OK, I've tried looking up the old threads on the forum but can't find one that helps. maybe i missed it?
Anyway! Went out last night on the bike and she rode like a champ, no problems. Went to take a ride earlier today to run some errands and she wouldn't start. Turn the key, lights come on, fuel pump sounds, I hit the button... cranks but won't turn over. Kept trying for few before giving up and plugging it in to the trickle charger I have in my garage. Came back a couple hours laters to a fully charged battery and tried again. Same thing... cranks, won't start. Ive tried it in neutral with kickstand down and up, in gear with the kick stand up. Even tried to jump start it with my truck (no, the truck was not on).
Bought the battery last spring, though it seems its not a battery issue.
Fueled it up last a few days ago and ran great last night, so not a fuel issue either.
What am I missing? any ideas??
MASSIVExATTACK is offline
post #2 of 11 (permalink) Old 10-09-2019, 03:25 AM
Main Motorcycle: ThruxtonR (Broomstick)
ThruxB-rad's Avatar
Did the magnet fall off the frame that engages with the side stand?
Sent from my SM-N960U using Tapatalk
Wake Up, Be Nice, Kick Ass Repeat .... MTFU
ThruxB-rad is offline
post #3 of 11 (permalink) Old 10-09-2019, 04:00 AM
Main Motorcycle: Daytona 675R
CafRacer's Avatar
Other Motorcycle: Thruxton R
I don't think it would turn over if that was the case, and as long as your bikes in neutral it wouldn't matter, presume the neutral lights on?
If you are 100% confident in the battery or you've tried it with your truck battery connected then it could be the CPS.
CafRacer is online now
post #4 of 11 (permalink) Old 10-09-2019, 11:34 AM
Main Motorcycle: ThruxtonR,
pmorritt's Avatar
Other Motorcycle: BMWR1100RT
TPS (throttle position sensor) ?
Paddy399 likes this.
Masquerading every day as a normal person is exhausting.
pmorritt is online now
post #5 of 11 (permalink) Old 10-09-2019, 01:03 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Dumb stuff. Pull the clutch in when you hit the starter. Kill switch not in the run position? (Magnet is for the water-cooled models.)
PS. Fuel can still be sketchy BTW. Will run to get home but no start the next day. Seen that. May not apply here of course.
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #6 of 11 (permalink) Old 10-10-2019, 01:10 PM Thread Starter
Angry
Update...
YES... In neutral, neutral light is on, clutch is engaged, kill switch is on run position (or else nothing would turn on), battery fully charged.
No recent electrical work done on it except for an LED bulb upgrade for the headlight 2 years ago and Denali Soundbomb airhorn 3 years ago.
Checked all my fuses, and did a spark test - NO spark, ***?
Towed it to a shop this morning. Let's see what they find.
post #7 of 11 (permalink) Old 10-12-2019, 01:06 PM
ianadell's Avatar
a crank but no start condition will always be a lack of spark of a lack of fuel. Lack of fuel is easy to check, but a little messy. Just remove the fuel line from the fuel rail, turn the vehicle or bike on the fuel pump should prime and some fuel should come out, then crank it over and more fuel should come out. If non of that happens you have a fueling issue. For spark you can buy an inline spark tester or get a scree driver and stick it in the plug wire and put the screw driver close to something metal like a part of the engine, valve cover, a metal bench so when electricity goes through it it will arch and give you a visual that yes or no you have spark and can continue your diagnosis.
ianadell is offline
post #8 of 11 (permalink) Old 10-15-2019, 05:46 AM
Main Motorcycle: Thruxton R
Tricolour's Avatar
Other Motorcycle: Bimota DB9S
Extra Motorcycle: Morini Corsaro
There was no spark in post 6?
But that was a couple of days ago.6
Tricolour is offline
post #9 of 11 (permalink) Old 10-15-2019, 09:37 PM Thread Starter
Well, the problem has been found. Ordering up a new crankshaft position sensor and clutch cover gasket. Hopefully it's in soon so I can enjoy the last few days of fall before it gets way too cold to ride.
CafRacer likes this.
post #10 of 11 (permalink) Old 10-16-2019, 07:59 AM
CafRacer's Avatar
Said that at the beginning
2016 Thruxton R, track racer kit, x pipe decat, US Vance and Hines, de-snorkel, no slack throttle mod, heated grips, 17t fr sprocket, quickshifter, TuneECU remap with custom riding modes, tubeless conversion.
