Cat removal (X-pipe) - Dyno tests, A/F ratios, performance - Definitive test results - Page 62 - Triumph Forum: Triumph Rat Motorcycle Forums
Club Cafe' Cafe Racers; the Thruxton, Bobber and other custom cafe styled bikes.
 382Likes
post #611 of 626 (permalink) Old 08-08-2019, 01:39 PM
I would also be willing to donate. I think the Motone X pipe is the last one in need of dyno testing, correct?
Lawton's_Cycle is offline
post #612 of 626 (permalink) Old 08-08-2019, 07:15 PM
Main Motorcycle: 2017 Triumph T120
@meerkat's Avatar
Other Motorcycle: Moto Guzzi V85 TT
Extra Motorcycle: Yamaha 500cc Cafe Racer
Originally Posted by Lawton's_Cycle View Post
Was there ever a dyno run posted of the Motone X pipe vs the Meerkat?
As I have stated before, I always have a crossflow pipe available for genuine independent comparison testing and you don't have to pool your resources to get it.
My preference is for testing with the Thruxton R, because that has the greatest potential for measurable gains, and believing this should, trickle down through the models with similar percentage gains across the range.
I look forward to hearing from you...
Peter H
Tricolour likes this.
@meerkat is offline
post #613 of 626 (permalink) Old 08-09-2019, 06:30 PM
Main Motorcycle: 2016 Thruxton S
Ashman's Avatar
Other Motorcycle: 850 Norton Featherbed
Extra Motorcycle: 1960 650 Manxman
Send a message via Yahoo to Ashman
I don't need any dyno runs to know what a big improvement that the Meerkat and open stock mufflers have done to the performance of my Thruxton, it was a completely different bike after the install, took only a short ride for the ECU to adap for the change, the reason I went for Meerkat was not far from me, I checked out the other brands from my local Triumph shops and on the internet and the read ups about what everyone was saying about them and most important on the quality of workmanship and the Meerkat won hands down, anyway thanks Peter and I would have no problems recommending Meerkat to anyone, whether they listen who knows and my Thruxton looks stock with the stock mufflers except for the bigger opening
Ashley
@meerkat likes this.
Ashman is offline
post #614 of 626 (permalink) Old 08-12-2019, 08:04 PM
Main Motorcycle: 2016 Thruxton R
Captmilk's Avatar
Other Motorcycle: Old bikes 2012 Triumph Bo
Ashley
I just got to installing the motone xpipe on my 16 TTR. Wasn't too bad. Took my time, (it only has 300 miles on it and I still baby it) I am definitely not a fan of the gaping holes I have now....lol I went with the xpipe without the mounts. I'm going to go with this to cover up that gap. (I believe)
https://www.ebay.com/itm/Evotech-Per...-/173984508498
Sent from my Pixel 3 XL using Tapatalk
Kiwi Dave likes this.
Captmilk is offline
post #615 of 626 (permalink) Old 08-13-2019, 05:09 AM
@meerkat's Avatar
I hadn't realised before but the motone actually has more welding than my Crossflow pipe.
I love the no hangers," I WONDER WHERE THEY GOT THAT IDEA FROM....." ( he says sarcastically )
I still have a design question around the switchback curve creating a soft entry, resulting in turbulence and pulse bleed at that critical extraction event point.
Peter H
Ashman and Kiwi Dave like this.
@meerkat is offline
post #616 of 626 (permalink) Old 08-13-2019, 08:23 AM
Main Motorcycle: 2016 Thruxton 1200
CanberraR3's Avatar
Other Motorcycle: 2018 Street Scrambler
Extra Motorcycle: 2016 Tiger 800 XCX
Peter H
The Motone just looks odd to me. Plus itís hard to see how they could get all those welds perfectly smooth inside. Iím with @Ashman re the Meerkat. I started with V&H pipes for very little gain but adding the Meerkat made an enormous improvement. Give me an exhaust specialist design over a general accessory seller any day.
Ashman, retjustdad53 and Kiwi Dave like this.
CanberraR3 is online now
post #617 of 626 (permalink) Old 08-21-2019, 07:25 PM
First time mechanic but here goes.. For completing the decat I'll need to torque the bolts back up. Not sure about the torque spec on this one.
On the Speed Twin there are 3 Bolts for the crankcase front mounting ( 1 silver and 2 black). Anyone know the nm spec for these 3 bolts?
The Thruxton R manual shows only a single 'Bolt (to crankcase front mounting)' spec'd to 105 nm.
ericthered is offline
post #618 of 626 (permalink) Old 08-23-2019, 08:39 PM
Main Motorcycle: Thruxton R
Tricolour's Avatar
Other Motorcycle: Bimota DB9S
Extra Motorcycle: Morini Corsaro
The frame rail to the crank case is correct at 105 Nm.
If the other three are the frame rail bolts (one at the top front and two at the bottom rear) I torqued them to 40 Nm iirc.
Just checked the manual. Cradle to frame mounting bolts 40 Nm.
Tricolour is online now
post #619 of 626 (permalink) Old 09-10-2019, 12:32 PM
Main Motorcycle: 2016 Triumph Thruxton
ColoradoSteve's Avatar
Other Motorcycle: 2001 BMW R1100R - Sold
Does the Meerkat logo piece fill in the front of the space where the original guard used to hide?
ColoradoSteve is online now
post #620 of 626 (permalink) Old 09-10-2019, 05:37 PM
CanberraR3's Avatar
No. If thatís important for you there are other x pipes available that enable fitment of that guard, but may sacrifice performance. You could drop @meerkat a line and see if he can accomodate that.
