Show your Thruxton R/ Standard 1200 mods so far - Page 107 - Triumph Forum: Triumph Rat Motorcycle Forums
Club Cafe' Cafe Racers; the Thruxton, Bobber and other custom cafe styled bikes.
 1086Likes
post #1061 of 1074 (permalink) Old 08-09-2019, 12:49 PM
Main Motorcycle: 2017 Thruxton R
hoodrat4r's Avatar
Other Motorcycle: 2008 Honda CBR600RR
Originally Posted by drainyoo View Post
Snapped some pics today of the current state of the mods on my bike. More to come. A lot of the installs were done by A&J Cycles. Here's the list so far:
Body
New Rage Cycles LED Fender Eliminator Kit
Triumph Black Headlight Bezel
British Customs Race Headlight Brackets
Removed Tank Strap
Removed Seat Cowl
Removed Front Fender
Exhaust
Arrow 71664MI Racing Headers
Cone Engineering Shorty Performer Mufflers
Suspension
Ohlins Steering Damper
Chassis
Free Spirits Triple Tree
Renthal Gen3 Clip-ons
Renthal Original Series Race Grips
Rizoma Bar End Caps
Rizoma 3D Levers
Sato Racing Rear Sets
Motogadget m.View Spy Mirror
Brakes
Rizoma CT027 Fluid Reservoir
Engine
A&J Cycles Sprint Filter Air Pod Filter Kit
Super Corse Temperature Gauge Oil Fill Cap
Electronics
Arton Works Vintage Racing Gauge Faces
Wire Models Throttle Spacers
Lighting
Kellermann Bullet Atto Mini Turn Signals
PIAA 70456 Xtreme White Plus Bulb
Laminix Yellow Headlight Film
Love the mods! Youre the only person ive seen/know of that has the Sato Reasets, how do you like them? ive been debating if i want to get them or not. any feedback would be appreciated. Thanks!
drainyoo likes this.
BraapBraap
hoodrat4r is offline
post #1062 of 1074 (permalink) Old 08-09-2019, 01:16 PM
Hey, thanks! I love the rear sets. The quality and fit are superb, and I much prefer the more aggressive stance they give you. The position of the pegs are moved 27.5mm back and 50mm up. Doesnít seem like much but itís definitely a big difference that you feel, mainly in the vertical change. My knees and feet are up higher, which is what I wanted. It makes it easier to grip the tank with your knees. Iím 6ft, so if youíre taller it might feel too compact. Also, the pegs are more narrow, so your feet are up against the bike and you really use those heel plates.
Install was fairly easy, but the instruction are very vague. You have to figure some things out on your own. The shift side was simple, but the brake side took me a few hours to figure out and adjust. I had to look at the diagrams that are in the instructions and piece it together. You donít need to modify anything, they bolt right in.
Shifting seems much smoother and faster to me. You have 3 positions for the shifter so you can change the stroke to your liking. Each pedal tip has two positions so you can change the distance from the pegs and the brake pedal height can be adjusted as well.
Overall Iím super happy with them. Definitely recommend them if you want a more aggressive stance.
hoodrat4r likes this.
drainyoo is offline
post #1063 of 1074 (permalink) Old 08-09-2019, 03:02 PM
hoodrat4r's Avatar
Awesome! yea im 5'6 so my knees just barely touch the bottom part of the tank so i have been looking for something that will help raise my knees so i can grip the tank better. This and the steering damper are my next must have mods. Thanks for info!
BraapBraap
post #1064 of 1074 (permalink) Old 08-09-2019, 03:39 PM
If you get them let me know if you need any help with the install. One thing to note, the main bolts that secure the pedals to the brackets have red loctite on them and are set at the factory. Don't unscrew them. I learned this the hard way and had to clean out the dried loctite on one of them. It might seem like you can't install the brake side without removing the pedal, but you can.
drainyoo is offline
post #1065 of 1074 (permalink) Old 08-10-2019, 11:29 AM
Newbie
Here's my 2019 silver ice Thruxton R!
Not too many mods yet, but I love everything about the bike thus far!
Mods so far include:
LED shorty OEM signals
Analog motors FEK
Larson upholstery seat cover and matching tank pads in tobacco brown
Motone xpipe
Vance and Hines slip ons
Tamarit belly pan
Future mods:
PCV
Might switch to arrow headers and either the cone or BC GP exhaust
Other than that, the bike is everything I've wanted it to be and more honestly! Cheers!
Captmilk likes this.
nudarkshadowl is offline
post #1066 of 1074 (permalink) Old 08-13-2019, 07:00 PM
Main Motorcycle: 2016 Thruxton R
Captmilk's Avatar
Other Motorcycle: Old bikes 2012 Triumph Bo
Got my New Rage fender eliminator....
I live in PA does anyone know if it's okay to install the tuckef license plate bracket in pa. Or where I might find that information I like that look better but I also don't want to get pulled over.
I found this:
*Registration plate lamp.*A registration plate lamp, if originally equipped, shall emit white light and make the registration plate visible from a distance of 50 feet to the rear of the vehicle
The license plate is hanging loosely from its mounting bracket.
*******(C)***The license plate is obscured so that the numbers cannot be identified.
*******(D)***The license plate lamp, if so equipped, does not illuminate the license plate.
https://www.pacode.com/secure/data/0...bchapHtoc.html
Captmilk is offline
post #1067 of 1074 (permalink) Old 08-13-2019, 08:16 PM
Main Motorcycle: Thruxton R
Tricolour's Avatar
Other Motorcycle: Bimota DB9S
Extra Motorcycle: Morini Corsaro
Does the tucked plate meet ANY of those requirements?
Tricolour is offline
post #1068 of 1074 (permalink) Old 08-14-2019, 05:54 AM
Main Motorcycle: 1977 Triumph T140V
Bsafer's Avatar
Other Motorcycle: 2017 Triumph Thruxton
Extra Motorcycle: 1974 Norton Mk2a Inter
TEC finally came out with their Raider 2 into 1 exhaust system for the 1200 Thruxton. The Rebel 2 into 1 they currently had did not fit the Thruxton, though it seemed like it might. I shopped around and settled on the Raider (Thanks Tricolour for the input re:Iron Cobra!). I just installed it a few days ago - and it looks a lot cleaner, weighs a lot less and has a great sporty sound. May even be a bit too loud for me. It may be my imagination - but I think the bike is even faster! The ECU seems to have adapted without any special attention on my part., but Ive only ridden it about 15 - 20 minutes. Oh and the catalytic convertor removal was a bitch, but overall, Im quite pleased!
All my other small modifications to date are listed earlier - so am just showing the new system on the bike.
ID:	652266   Click image for larger version
DaveM likes this.
Bsafer is offline
post #1069 of 1074 (permalink) Old 08-14-2019, 06:02 AM
Captmilk's Avatar
Here is a picture 50feet away(as stated in PA law). I can clearly see the plate number with the naked eye. I think I'm good.
Sent from my Pixel 3 XL using Tapatalk
AusSimon likes this.
Captmilk is offline
post #1070 of 1074 (permalink) Old 08-14-2019, 08:25 PM
Newbie
2016 I picked up a few weeks ago only had 1600ks on it so mayb 900 miles . Already had everything on it I would of wanted to add. Pipe , fender delete, windscreen. The only thing is it still has the Cat still on it which I will do this winter . Loving this bike so far wouldn’t trade it for any other bike !! Put 4000 k on it since I got it 4 weeks ago..
ID:	652320   Click image for larger version
Jon.R is online now
T120 bars on a Thruxton? mprhead5 Water Cooled Twins Talk 18 06-09-2016 10:32 AM
New Thruxton Release at Phillip Island Grand Prix jonkster News Room - Homepage 1 03-18-2016 07:33 PM
I think I am jumpin ship on the Thruxton R... Usaftrevor87 Air Cooled Twins Talk 93 02-10-2016 03:56 PM
