scissor gear setup - Triumph Forum: Triumph Rat Motorcycle Forums
Club Cafe' Cafe Racers; the Thruxton, Bobber and other custom cafe styled bikes.
post #1 of 4 (permalink) Old 11-04-2005, 04:34 PM Thread Starter
any one out there have a/the procedure for preloading the scissor gears located on the cam shaft drive?? has anyone not done it correctly? any damage or noise result???
cheers....
all that we see or seem is but a dream within a dream..
katanaman is offline
post #2 of 4 (permalink) Old 11-04-2005, 06:17 PM Thread Starter
anybody????????????????
post #3 of 4 (permalink) Old 11-04-2005, 10:15 PM
You're talking about the spring-loaded split gear on the cams themselves, right? I found something that would fit the hole, like a drill bit maybe. Once you spin the spring loaded gear enough the hole in the stationary gear will line up. Put the drill bit in to hold them in place until you've got one of the caps in place. If I recall, the spring loading amounts to about the distance of one tooth.
Mr. Whatisit? That guy treats objects like women, man.
whatisit is offline
post #4 of 4 (permalink) Old 11-04-2005, 11:26 PM Thread Starter
Excellant.... exactly what i needed to know... now if this is not loaded correctly i would get a bit of back lash through my cams and associated noise??? pretty sure i have nailed my noisy top end problem, you would think the shop would know this eh?!
Hagon Setup ?? gundog T3 Sport / Touring Forum 0 07-03-2007 11:59 AM
anybody got this setup wildchild Air Cooled Twins Technical Talk 3 06-12-2007 09:42 PM
'02 955i / Wisconsin / Gear, gear, gear. wwpageiv Daytona Deliberations 2 06-06-2007 11:24 PM
This is one HOT setup!!! DrEnglish Club Cafe' 12 03-02-2005 07:20 PM
Setup littonlad Sprint Forum 3 07-29-2004 10:42 PM
