dismantling a conical rear hub - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 09-26-2019, 12:23 AM Thread Starter
rbe
Main Motorcycle: 1976 T140
rbe's Avatar
Other Motorcycle: 1970/78 T120R, MV Brutale
Extra Motorcycle: FLSTC TZ600 300EXC 350EXC
i need to pull my rear hub apart to get the flaking chrome removed - i then plan to polish it
the hub has had the spokes and rim removed
the hub proper came apart ok - bearings out
i'm now working on the brake backing plate - the pivot pin that the brake lever sits on came out easily, but the pin that the brake stay arm attaches to is a bit stubborn
it looks like it should come out, but just wondering if someone has some experience or tips that will make it easier and reduce the risk of damaging the plate - it seems pretty fragile
thanks in advance as usual for what i'm sure will be sage advice
rory
rbe is offline
post #2 of 12 (permalink) Old 09-26-2019, 02:23 AM
Main Motorcycle: 2015 Triumph Thruxton
Juan's Avatar
Other Motorcycle: 2016 Triumph Street Twin
Extra Motorcycle: Triumph T140V,T120R,TR6R
Hello Rory
I removed it on my rear conical brake but it has been a while. I would apply some penetrating oil and using a heat gun apply heat to the part then tap on the screw with a piece of wood. It should come out. I wouldn`t use a torch to heat it up.
Juan
[IMG][/IMG]
Juan is online now
post #3 of 12 (permalink) Old 09-26-2019, 04:35 AM Thread Starter
rbe
rbe's Avatar
thanks Juan
i'll give that a try
i only hope mine end up looking as good as yours
rory
rbe is offline
post #4 of 12 (permalink) Old 09-26-2019, 02:59 PM
Main Motorcycle: T140 E
Were they chromed originally?
It might be easier to find a decent unchromed one
DAVE M is online now
post #5 of 12 (permalink) Old 10-01-2019, 08:55 PM Thread Starter
rbe
rbe's Avatar
finally got around to it today
heat gun applied and it came right out - with a bit of coaxing - thanks again Juan
note that the pin has splines/knurling on the part that is interference fit in the backing plate - glad i didn't try to twist it out
i assume that a PO had done the chroming - i don't know whether any models came with chrome originally
i would look around for one that wasn't chromed, but its taken me a year to find this one, and its in good nick so i'll go with it
rbe is offline
post #6 of 12 (permalink) Old 10-02-2019, 07:00 AM
Main Motorcycle: 1971 t120r
rambo's Avatar
Other Motorcycle: Triumph Rocket 111
Extra Motorcycle: Triumph Thunderbird LT
They were not chromed on any new bike. Usually painted with a plain silver paint. I paint mine so i never have to polish between spokes. The brake plates were also painted in silver, although i have polished mine.
Now,where did that bit fall off ?
rambo is online now
post #7 of 12 (permalink) Old 10-03-2019, 02:21 AM Thread Starter
rbe
rbe's Avatar
does anyone have experience with anodising the hub and backing plate?
i too am now starting to dread the upkeep of a polished hub with all those spokes in the way
was thinking of getting it anodised clear - which i think is really just aluminium colour
rbe is offline
post #8 of 12 (permalink) Old 10-04-2019, 03:49 PM
You could polish and lacquer before a build.
Lacquer used to go yellow but I think it's better nowadays
My hubs were polished from the factory and I assume, lacquered ?
I have machine polished them and keep them up once built - without lacquer
post #9 of 12 (permalink) Old 10-17-2019, 07:02 PM Thread Starter
rbe
rbe's Avatar
latest update: took my hub and backing plate to an anodoiser to see if they could strip and andodise them
the person said they didn't work with chrome and couldn't anodise them because they were magnesium - the backing plate is very light, so i could accet it is mag, but the hub weighs a ton, so i'm less willing to accept that its mag (acknowledging that the brake drum would add weight)
does anyone know if the 2 bits are mag?
then took the bits to a chromer who will strip and suggested that afterwards i polish and clear lacquer them - sounds familiar eh?
thanks
rory
rbe is offline
post #10 of 12 (permalink) Old 10-18-2019, 07:10 AM
wol
Main Motorcycle: T140 "special"
Other Motorcycle: 1970 T120R Project
Extra Motorcycle: yes please
I would be surprized if they are Magnesium --( change that to Very surprized )
wol is offline
