Hoping to install a GPS Speedo to replace my cable speedo. The GPS Speedo Wiring comes with negative ground wiring diagram. What alterations (If any) need to be done when installing for Positive ground? See pic. Thanks.*
On my short 17 km ride I found no problems. We shall see. I really like it so far. I paidI have heard that these GPS speedos are often very unreliable regarding a signal and often, the aerial lead is very long. Fit it up and give an opinion wether it is worth fitting. It may be a lot more accurate than the old ones on the bike now.
I like the red led light on permanent with ignition. You can't see it in daylight, only in tunnels or garage but is a nice glow on a cold morning startup. Good luck with the custom! Thanks, Dave.The only thing might be that it would be on permenantly ?
You may be able to wire the switched power into one side
Lots of great work-arounds with detailed explanations, Chris! Thanks!I think it very unlikely that the electronics are connected in any way to the case...
I followed your drawing and everything seems To be working great! Thanks, Peg!Hi
1972 650 Pos ground Triumph, other years/models might have different wiring...
Peg
Yes, I believe it is plastic. Thanks, TT.The speedo case won’t have continuity to anything. Test it with a meter on ohms if you want, but isn’t it plastic?
Not long. Faster than promised. Ordered Sept. 3. Arrived Sept. 13th.Good tip T140V because my original speedo tanked, broke the needle which turns around permanently, slower with slower speeds, faster when I go faster.
Thought about buying magnetic copy, but this one is cheaper and even fits its rubber boot.
How long did you wait for it?
