need advice on exhaust spigots - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 17 (permalink) Old 08-17-2019, 07:00 PM Thread Starter
Main Motorcycle: Triumph Thruxton 900
Other Motorcycle: Triumph Tiger XC800
Extra Motorcycle: Triumph Thunderbird 6T
Hello all,
I am about to have some work done on my 1954 Thunderbird engine. Both exhaust spigots on the head are damaged (pictures attached). What is the best solution? I think I am correct in believing that these spigots are not threaded or pressed in but rather a part of the iron head.. The company I am going to for the repairs said that if that is the case it would be better to cut them off and bore out the exhaust ports to press in new spigots as welding them could result in them being out of round. What are your opinions?
Sean Knox is offline
post #2 of 17 (permalink) Old 08-18-2019, 06:02 AM
Tritn Thrashr's Avatar
There’s enough left there to hold the pipes.
The one with the long crack looks like it needs the piece removed so it doesn’t drop off in use.
Tritn Thrashr is offline
post #3 of 17 (permalink) Old 08-18-2019, 06:06 AM
tridentt150v's Avatar
Is that a crack in the head at 8 o'clock??? If so then pressed in versions won't work either. The crack will only get bigger with pressure plus heating and cooling.
Personally, I would take the work to somebody that can weld cast and get the spigots/exhaust stubs repaired. Don't get them removed or replaced, just repair them. I reckon they could be welded up so that they are as good as new.
tridentt150v,
Great Southern Land.
tridentt150v is offline
post #4 of 17 (permalink) Old 08-18-2019, 06:22 AM
wol
Main Motorcycle: T140 "special"
Other Motorcycle: 1970 T120R Project
Extra Motorcycle: yes please
I agree - it must be easier to repair the spigots rather than remove / replace them ( your pockets will retain more money too)
wol is offline
post #5 of 17 (permalink) Old 08-18-2019, 06:44 AM
Main Motorcycle: 79 T140D
Other Motorcycle: 96 Ducati 900M
Extra Motorcycle: Several Triumph racers
What TT say or scrap the head...Weldling cast iron ,especially thinner stuff, is a bit of magic....Building it up with spray welding or rod is possible and then the time spend making it all round and nice might be a bit expensive..Maybe a replacement is best...
Second fastest Triumph..............land speed racing....dressed in animal skins clinging to oily vibrating machines propelled by fire..
Truckedup is online now
post #6 of 17 (permalink) Old 08-18-2019, 07:25 AM
Main Motorcycle: T140 E
I'd cut off the dodgy bit and leave it alone
DAVE M is offline
post #7 of 17 (permalink) Old 08-18-2019, 07:42 AM
I can’t see a crack in the head itself.
post #8 of 17 (permalink) Old 08-18-2019, 06:26 PM Thread Starter
No cracks in the head itself.. I did discuss welding but was told that getting the spigots round again when grinding back would be extremely difficult. if there is enough material there to hold the exhausts, I might consider just cutting off the damage
post #9 of 17 (permalink) Old 08-18-2019, 11:27 PM
Here:
tridentt150v,
post #10 of 17 (permalink) Old 08-19-2019, 04:06 AM Thread Starter
That is actually the edge of the flaked paint. However on second inspection I did realise that the crack in one of the spigots goes more or less right down to the head, so in light of this new revelation... what are my options??
Apologies for the qaulity of the photo, I know it isn't perfectly clear but you can see the crack running in towards the head
