Fouling plugs - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 27 (permalink) Old 07-26-2019, 06:57 PM Thread Starter
Main Motorcycle: 71 - T120R
Dan2018's Avatar
Fouling plugs
71 Bonneville.
It starts instantly with new plugs and runs great. When the plugs foul, it runs poorly and usually will not start. The plug in the picture was new and ran for about 10 min. Bad carbon fouling. Both plugs look the same. I have been thru the carbs many times and have replaced the floats, seats, jets. I have tried moving the clip at all 3 positions on the needleto lean it out and nothing changes. I tuned the carbs by shutting down a cylinder and tuning the opposite side. And it still fouls the plugs.
If the timing or the valves needed adjustments, it would not run as well as it does - correct?
Suggestions would be appreciated.
Dan2018 is offline
post #2 of 27 (permalink) Old 07-26-2019, 08:11 PM
Main Motorcycle: morgo
speedrattle's Avatar
Other Motorcycle: snorton
Extra Motorcycle: Tbolt
what plugs are you using?
i be kevin
speedrattle is offline
post #3 of 27 (permalink) Old 07-26-2019, 08:49 PM Thread Starter
Dan2018's Avatar
NGK B8ES 2411
Dan2018 is offline
post #4 of 27 (permalink) Old 07-26-2019, 09:43 PM
Main Motorcycle: 1977 Triumph Bonneville
Other Motorcycle: 1996 Ducati 900ss/cr
Extra Motorcycle: 2007 Ducati S4RS
Iím not saying this is you, but : Sometimes when you are trying to figure out something like this it helps to figure out what isnít wrong to narrow down the possibility of what could be wrong. Like stating what has been done to the carbs already. The other thing that really helps is to do a complete tune up and check the compression. What could be wrong ? Anything that youíre not sure is right. If I ask a question on this forum it will help everyone if I do all of the normal adjustments first. It will save days of trading questions and answers back and forth. This is because when someone tells me their bike isnít running right, Iím going to ask when was the last tune up, because that usually gets rid of half the problems.
duc96cr is online now
post #5 of 27 (permalink) Old 07-26-2019, 11:27 PM
Main Motorcycle: 1978 Triumph Bonneville
htown16's Avatar
B8's are a little on the cool side. Try some Champion N3C's. Any evidence of oil fouling?
Htown16, Houston, Texas
1978 T140E Bonneville, 1974 Trident, 1972 Commando, 1971 Commando
1974 Commando, 1970 BSA Thunderbolt, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is online now
post #6 of 27 (permalink) Old 07-27-2019, 02:36 AM
Main Motorcycle: 66 Triumph TR6
Other Motorcycle: 66 Triumph T120R
The needle position has little to no effect on the mixture at idle. How are you setting the air screws?
Rod
Redmoggy is offline
post #7 of 27 (permalink) Old 07-27-2019, 05:09 AM
Main Motorcycle: 1977 T140V(J)
+1 to redmoggy above.
Had similar in my 77 T140 recently, plugs a sooty black as in the picture. Air screws set a 1.5 turns, so have just taken them out to 2 turns. after a couple of miles plugs were brown. Need the opportunity to put a few more miles at highway speeds to check all is still good.
Good luck.
Andy
AndyT140 is offline
post #8 of 27 (permalink) Old 07-27-2019, 05:23 AM
Main Motorcycle: T120V
Caulky's Avatar
Other Motorcycle: 1960 Tiger Cub
Extra Motorcycle: 1971 Bsa A65L
Three things to check:
Float levels:
Using aluminium, viton-tipped needles, set the float level to .080" below the cusp by pressing lightly on the TANG only. 'Stay-up' floats are easy to adjust.
Pilot jet
Get a .016" guitar string and insert through the jet (about 1 1/2 inches in) and file the end to remove any burrs. You may need a flashlight to see the jet hole. Spray carb cleaner through the jets afterwards.
Air filters.
Clean them in a bath of paraffin (kerosene), and leave to dry.
Caulky is offline
post #9 of 27 (permalink) Old 07-27-2019, 05:35 AM
I tried every method I read for setting my mixture at idle, I simply never managed to get it right. I eventually gave in and with some scepticism decided to try a Mates Gunson Colortune. Brilliant bit of kit.
Rod
Redmoggy is offline
post #10 of 27 (permalink) Old 07-27-2019, 07:41 AM
Main Motorcycle: T140 E
Yes
Had a colourtune for 40 odd years
Anybody tried a twinmax balencer?
DAVE M is online now
