Twin horn relay wiring 1970 T120R - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 23 (permalink) Old 04-16-2019, 01:11 PM Thread Starter
wol
Main Motorcycle: T140 "special"
Other Motorcycle: 1970 T120R Project
Extra Motorcycle: yes please
Trying to sort out the correct wiring for the horn relay on my 1970 T120R - its a Genuine Lucas relay marked 6 RV - when i google it i find the POD in his infinite wisdom used 6RA as a reference for a multitude of relays and other items mainly with 4 conns so no help
-- my relay has 3 connections C1 -- C2 and W1
-- any one know what wires go where ?
- pic is attatched - ignore my scribbles in the backround
wol is offline
post #2 of 23 (permalink) Old 04-16-2019, 01:35 PM
Main Motorcycle: T120RT
KADUTZ's Avatar
Other Motorcycle: T140V,T140D,T140E,T140J
wol
C1 - BROWN/BLUE WIRES TO HORNS
C2- BROWN/BLUE "HOT" WIRE IN HARNESS
W1 - BROWN/BLACK? WIRE FROM HORN BUTTON
Always found it interesting how they mounted the relay in the frame.
K
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is offline
post #3 of 23 (permalink) Old 04-16-2019, 02:12 PM Thread Starter
wol
Thanks K - i thought C1 was to the horns but unsure which was which on the other two
regarding the relay position - i have found two options - pics attatched
above the coils is where mine came fitted but i am going to use the other position because i am going to fit a reg/rec in the position above the coils
wol is offline
post #4 of 23 (permalink) Old 04-16-2019, 03:16 PM
Main Motorcycle: T160
Moderator
Other Motorcycle: T100, T150
Lightbulb
Hi Wol, K,
Bigger picture, second picture, maybe (it's too small to be sure and the wiring's been done with Bodger's Terminals); on the twins, it was always a complete assembly of relay and horns, attached to the underside of the front tank mounting bracket ... with two 1/4" bolts ...
What horns are you actually using?
The two earliest iterations of the Clearhooters (shown in the '69 and '70 parts books) were heavy (they were basically car horns) and Meriden attached each horn to the bracket and then the bracket to the frame with a couple of the aforementioned 1/4" bolts. The longest-lasting of the Clearhooters (because they were the lightest) were the ones fitted to '71-on T150's and Rocket 3's; they would be correct on a '69 or '70 twin (but agitate the bobblies) because Triumph and BSA replaced so many of the earlier ones under warranty. However, working versions of any Clearhooter are rocking-horse poo ... and they aren't very loud ...
Correct. All 'original Lucas' parts had both some sort of 'group' reference ("6RA" in this case) and an individual reference - the '70 Triumph US-market 650 parts book has "33188".
If you Google "lucas 33188" and ignore all the obviously-brand-new 'Wassell Genuine Lucas" rubbish, you should see at least https://www.ebay.com/itm/Lucas-33188...-/331405284984 and https://www.ebay.com/itm/NOS-GENUINE...-/263933217281, both with just the three separate terminals.
'Original Lucas' did also make 6RA relays with four separate terminals - the additional one is marked W2; with W1, they have a separate supply and return from C1/C2 - but Lucas gave 'em different 5-figure individual references.
Brown/Blue simply needs to be connected to W2 as well as C2.
Hth.
Regards,
Stuart
StuartMac is online now
post #5 of 23 (permalink) Old 04-16-2019, 03:46 PM Thread Starter
wol
the smaller picture is one i found ontinternt - just to find evidence of how the parts in the parts book fit together - the thin "L" shaped braket i think is a home made jobbie and does not look quite right but close enough -- i think i will have to make one too as i cant find one as yet
What horns ? - good question - havent got any that would pass as original - for now i will be fitting a pair of cheapies from China , at least they are light, being smaller ( even so the riveted on mounting brackets eventually crack but at less than two squid each delivered what can you expect)- will be looking out for some "proper" ones - but prices are scarey!
wol is offline
post #6 of 23 (permalink) Old 04-17-2019, 04:00 AM
Moderator
Lightbulb
Hi Wol,
What horns ?
Japanese Nikko YP. They're available as aftermarket accessories and they were fitted to some late-1970's/early-1980's Suzis; recommended on TOL several times over the years as Clearhooter substitutes, some owners even paint 'em black.
As I say, unfortunately 'cos they're rocking-horse poo. Original "'69" ones - pan-shaped plastic cover - had a design fault, in that there was an unplated steel washer in the centre of the diaphragm, which rusted and trashed the diaphragm ...
Correct "'70" ones - dome-shaped steel cover - have an oblong trumpet opening. Afaict, these were peculiar to Triumphs and BSA's, the more-common car ones have a triangular trumpet opening; relatively cheap at car autojumbles, Triumph and BSA owners will try to persuade you out of lots of money for 'em. But they're as heavy as '69 ones; if you find a pair of either and want to fit them, I advise securing 'em with cable ties as well the bolts - when the inevitable happens to the bolts, at least the horn won't go bouncing down the road.
Back in the naughties, Burton Bike Bits set out to have new '69 and '70 Clearhooters made ... They had a batch of each made in NZ ... in Christchurch ... just before the big 2010 earthquake ...
Floating around t'internet for years have been claims that some Triumphs and BSA's were fitted with twin Lucas 6H's. Not impossible as long as a 6H's mounting bracket has two 1/4" ID holes closer together than, and in addition to, the usual two 5/16" ID holes; just the latter on their own are further apart than any Clearhooter's mounting. And two 6H's won't give you a Clearhooter pair's combination of high and low notes ...
Hth.
Regards,
Stuart
post #7 of 23 (permalink) Old 04-17-2019, 01:06 PM Thread Starter
wol
thanks for the info on the Nikko YP horns - will see what i can find
wol is offline
post #8 of 23 (permalink) Old 04-17-2019, 02:13 PM
KADUTZ's Avatar
Nothing wrong with the NIKKO horns they make noise.
For what its worth if you are going to use the stock bracket (83-1254) I would suggest the addition of a small brace from the base to the bent parts. I have repeatedly seen the bracket break at the bends. I would also suggest safety wiring the horn bodies to the bike. As when the bracket or horn bracket breaks (note I didn't say if) you will not have a scratched fender or lost horn. Been there done that.
Regarding the 1970 T120 horns. Early models (up to about January 1970 builds used the Dome Style horn Stuart mentions (part numbers 60-2256 & 60-2257 . The 2256 was a Clear Hooter P201 and the 2257 was a Clear Hooter P101) About December 1969/January 1970 there was a problem with the previously mentioned horns.
Was it a horn availability or horn quality problem I do not know. I suspect it may have been the bracket breaking due to the horn weight.
Regardless about January 1970 Triumph starting using Clear Hooter horns Triumph part numbers 60-2623 & 60-2624 (Clear Hooter part numbers HF80 lo note & HF80 high note) These are the same horns used on 1971 and later T150's These horn resemble the LUCAS 6H and is where the confusion comes from.
1970 was a long production year with many running production line changes that were not necessarily documented properly.
K
TRIUMPH
KADUTZ is offline
post #9 of 23 (permalink) Old 04-17-2019, 07:52 PM
Main Motorcycle: 70 BSA A65
In my Trident I have the same relay but with 5 connectors :
C 1 is double going to horns,
C 2 is hot double white wire,
W 1 is purple wire from a horn button
W 2 is double red wire ( battery + )
I understand from Stuart post it should be another hot white wire or not ?
I didn't have my horns installed yet, so doesn't know is this set up works or not.
Adam M. is online now
post #10 of 23 (permalink) Old 04-18-2019, 12:59 AM
Moderator
Cool
Hi Adam,
Uh-uh. I posted "four separate terminals", which is what you've listed; C1 is just a double terminal, which is why it's convenient to connect the two separate horn supply wires to it.
'71-on (e.g. your Trident) horn/relay wiring is different from pre-'71 (e.g. Wol's '70 T120R) horn wiring:-
. Fundamentally, pre-'71, the horn/s could be sounded irrespective of whether the ignition was on or off; '71-on, it/they could only be sounded with the ignition on.
. C2-C1 is the horns supply; '71-'74 C2 has a White wire (only "hot" when the ignition switch is on), pre-'71 C2 has a Brown/Blue wire (unswitched "hot" directly from battery -ve).
. The three-separate-terminal 6RA relay used only in '69 and '70 is odd in that C2 is also the supply for W1 (Brown/Black wire to the horn button). Pressing the button completes the relay switching circuit simply by connecting the button to the handlebar (through the mounting screws ), then it's a Lucas 'magic earth' through sundry bits of bike to an attached Red wire somewhere.
. The four-separate-terminal 6RA relay is more conventional in that the switched (C1-C2) is completely-separate from the switching (W1-W2); '71-on, the handlebar horn button is supplied by a White wire, the wire from the horn button to relay W1 is (should be) Lucas/British Standard Purple/Black, the Red wire on relay W2 is simply the switching circuit return to battery +ve.
Wol and anyone else battling with the Mickey-Mouse pre-'71 horn button: the 'magic earth' can be improved by attaching a Red wire inside the horn button body, threading it beside the other horn/dipswitch wires and connecting it to existing harness Red wires.
Hth.
Regards.
Stuart
69 T120R wiring poser. Cal30M1 Classic, Vintage & Veteran 4 06-11-2016 01:21 PM
wiring diagram needed for T120R terry1956 Classic, Vintage & Veteran 15 03-24-2014 03:44 PM
Oxford Hotgrips relay wiring problem??? p.dixon1 Air Cooled Twins Technical Talk 1 03-06-2011 08:52 PM
T120R wiring -positive ground canadian Vintage Technical Tips & Tricks 5 10-29-2010 08:10 PM
1962 Triumph 5TA speed twin - Wiring trouble Jolly5TA Classic, Vintage & Veteran 5 07-31-2009 08:57 PM
