Amal 930 Concentric Drain Plug - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 23 (permalink) Old 10-27-2018, 08:53 AM Thread Starter
Main Motorcycle: T120 (preunit)
Other Motorcycle: T20C
Anyone know where in the UK I can get a float bowl drainplug that has the Hex rather than the screwdriver slot? Seen these available in the States but not UK, and US postage makes them to dear?
Freakmaster is offline
post #2 of 23 (permalink) Old 10-27-2018, 01:27 PM
Main Motorcycle: T140 cafe NRE900cc
Other Motorcycle: Yes
Extra Motorcycle: Of course
Hi
Give Surrey cycles a call.
+44(0)1342 716120
https://surreycycles.com/carburettor...00-concentric/
Item 34/5
The function of man is to live, not to exist. (Jack London)
Rancidpegwoman is offline
post #3 of 23 (permalink) Old 10-27-2018, 02:53 PM Thread Starter
Excellent, thanks RW just the job.
post #4 of 23 (permalink) Old 03-11-2019, 09:02 PM Thread Starter
Seems SC don't monitor their online site mails, so no joy, anyone know what thread these drain plugs are and i'll source a die. Thanks.
post #5 of 23 (permalink) Old 03-11-2019, 09:41 PM
Main Motorcycle: BSA A65 1971
Other Motorcycle: Cagiva raptor 2001 650
Surrey cycles are best contacted by phone.
We have no means of establishing reality outside our own frame of reference.
GavinE is offline
post #6 of 23 (permalink) Old 03-12-2019, 02:26 AM
Hi Freakmaster
Try their quick access e-mail address below
00441342 716 120
They are the nicest, most helpful people, you need to pay over the phone anyway, proper old school style.
Regards
Peg.
post #7 of 23 (permalink) Old 03-12-2019, 02:39 AM
tridentt150v's Avatar
Or you could try this:
https://www.ebay.com/itm/1x-BOWL-SCR...oAAOSw-0xYT6Dy
I don't have them but interesting idea.
tridentt150v,
Great Southern Land.
tridentt150v is online now
post #8 of 23 (permalink) Old 03-12-2019, 04:12 AM
Main Motorcycle: T160
Moderator
Other Motorcycle: T100, T150
Lightbulb
Hi,
IIrc, 9/16" Cycle.
Originally Posted by tridentt150v View Post
Mmmm ... having "distort[ed] the bowl lip" with "the two small bowl screws", those that really shouldn't be allowed big boys' tools unsupervised can bugger the jet holder thread too ...
Hth.
Regards,
Stuart
StuartMac is offline
post #9 of 23 (permalink) Old 03-12-2019, 12:07 PM Thread Starter
Thanks Tri150, Iv'e ordered the drain plug, that is what the hex was required for, to establish a quick drain facility, done one before but was looking for a neater solution. But I think I can improve on this Aussie one once it is received. Tar also to StuartMac 9/16" CEI was tried, but did not seem a correct pitch, perhaps just clumsy me, I'll look at that again. I take your point about overkill on retention, specially as once up on a time it was a plastic bung. The reduction on fuel capacity in chamber, and also flow to jets occurs to me, might be an issue though presumably these guys have tested this?
post #10 of 23 (permalink) Old 03-13-2019, 06:15 AM
No idea...I just saw them and thought it was an interesting idea irrespective of the sales pitch. But they could create their own issues, eg how do you ensure that the bowl is in its correct position if you don't use the two screws. The central mount looks OK but it would allow the bowl to swivel on the axis, not ideal.
Personally, I forked out the $$$$ and bought the hex drain plugs, plastic ones were always sh#t, the nickel coated brass copies were ok but still not ideal - the slot you use to tighten them is only every 180 degrees, the centre carbie on the Trident is awkward, the hex ones are great. I wouldn't go back.
tridentt150v,
Help with stripped drain plug TorqueBird Maintenance & Workshop Talk 0 07-04-2018 08:10 PM
What screwdriver do you use on Amal Concentric drain? Scot68 Classic, Vintage & Veteran 34 09-13-2017 07:09 AM
Oil drain plug crush washer issue foxj Air Cooled Twins Technical Talk 31 01-05-2016 11:06 AM
How to seal leaky drain plug for a few hundred miles? bran12 Street Triple Forum 13 06-10-2015 05:06 PM
Fumoto quick oil drain valve (Long & Boring) Forchetto Air Cooled Twins Technical Talk 36 05-02-2015 09:49 PM
