New Pazon Ignition and 6v coils on '68 T120 = no spark - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 11 (permalink) Old 09-16-2018, 02:58 PM Thread Starter
Main Motorcycle: 2018 Street Triple R
Hello,
I just installed a Pazon Ignition on my '68 Bonneville 650 using Lowbrow Customs install video and following installation, I set the timing and valve clearances. I fired the bike up to do the strobe timing and it seemed to be working fine and fired up faster than it had ever done before. Based on recommendation of lowbrow, I replaced my two 12v coils with two 6v coils, however, now it won't start and it doesn't appear I am getting any spark when I touch the plug against the engine to test it. I wired the coils the same way. Does anyone have any ways I can diagnose the issue? Do I switch back to the 12v coils or change any wiring?
Thanks for any help and suggestions,
Ethan
ekaplan1020 is online now
post #2 of 11 (permalink) Old 09-16-2018, 04:22 PM
Main Motorcycle: T140 cafe NRE900cc
Other Motorcycle: Yes
Extra Motorcycle: Of course
Hi Ethan,
It can only be wiring, coils or Pazon unit that will cause a complete loss of spark, plug and ht lead will loss of one spark (unless you are super unlucky).
I think you are on the right track, put it back to when it was working with the 12v coils. Double check the wiring connections.
If it runs again then the new 6v coils are suspect.
If it does not run, then the Pazon is suspect.
Once you have eliminated either the coils or Pazon from the list, then you can run further tests on the remaining suspect components.
Check the wiring as if you were fitting the ignition from new.
Also check the fuse, just in case it is blown.
Best of luck
Peg.
The function of man is to live, not to exist. (Jack London)
Rancidpegwoman is offline
post #3 of 11 (permalink) Old 09-16-2018, 05:00 PM
Main Motorcycle: T140 E
Fist thing I would suspect is that the coils are wired wrong if , as you say, that was the last and only change made.
Check that first- I suppose it's possible that the coil +/- are wired wrong?
Or that the HT leads aren't properly in?
DAVE M is offline
post #4 of 11 (permalink) Old 09-16-2018, 11:01 PM
Main Motorcycle: T100R Daytona special
Other Motorcycle: Ducati 748/853
Extra Motorcycle: Cagiva Mito, Yamaha SR500
6v coils should be wired in series on a 12v supply.
Have you checked the resistances of the primary windings on the new coils?
Does the red led on the timing cover stator illuminate when you switch on and kick it over?
//ocr
Enn skal lytte, nr en gammel hund gj.
Old Cafe Racer is offline
post #5 of 11 (permalink) Old 09-16-2018, 11:52 PM Thread Starter
//ocr
I have not checked the resistance. How would i go about wiring them in a series? Would that include or exclude the jumper wire?
post #6 of 11 (permalink) Old 09-17-2018, 01:36 AM
Positive wire to + on first coil, jumper from negative on that coil to + on the other coil and then the negative wire to the negative on that second coil.
They both fire at the same time as it's a wasted spark EI.
//ocr
post #7 of 11 (permalink) Old 09-17-2018, 09:15 AM
Hi Ethan,
Is this new ignition a Pazon Altair, Pazon Smart Fire or a Pazon Sure Fire?
This would help in determining the exact wiring diagram you need.
All of the above ignition types will have the coils wired in series, so when you connected it up originally to the 12v coils, following the wiring instructions that came with the ignition and it worked, you must have wired the 12v coils in series already.
Check that the 6v coils are wired the same as you had the 12v coils.
Because the coils are wired in series, if one coil is faulty it can stop other coil from firing also.
If you are unsure of what the wiring should be, post a photo of the connections you have already made.
Regards
Peg.
post #8 of 11 (permalink) Old 09-17-2018, 09:44 AM Thread Starter
Originally Posted by Rancidpegwoman View Post
Hi Ethan,
Regards
Peg.
It’s a Surefire. The video from Lowbrow customs installs it with a negative ground, but my 650 is a positive ground.
post #9 of 11 (permalink) Old 09-17-2018, 11:09 AM
Hi Ethan
So I would expect the wiring connections to look like the drawing on figure1 in the drawing on page 7.
http://www.pazon.com/files/PDF/PA2.pdf
If the wiring is the same as the figure 1 drawing, then there are 3 possibilities to stop the ignition firing:
1) No power on the white wire of the ignition unit, maybe the fuse has blown orred wire of the ignition unit has bad connection to the battery positive terminal.
2) One or both of the coils are faulty, this can be easily checked by fitting the 12v coils again.
3) The amplifier or pickup of the ignition is faulty.
Pazon have a comprehensive series of tests if you cannot get a spark, I have copied these in blue colour from their troubleshooting guide.
NO SPARK
Check battery has power.
Switch on headlamp, this should stay bright for at least one minute.
BATTERY IS OK, BUT STILL NO SPARK - CHECK FOR POWER TO THE IGNITION MODULE
Using a test bulb or voltmeter/multimeter, check for a good power feed into the ignition module.
The power feed is the wire coming from the ignition or kill switch.
Measure between this ignition feed wire and ground, with the ignition switched on.
If using a multimeter/voltmeter set the meter selector switch to "DC Volts" on the 0-15 Volts or 0-20 Volts range. Some digital multimeters are auto-ranging, so need only to be set to "DC Volts".
For positive ground electrics, connect the meter's positive (red) test probe to frame ground and the negative (black) test probe to the ignition feed wire, where it connects to the ignition module.
For negative ground electrics, connect the meter's negative (black) test probe to frame ground and the positive (red) test probe to the ignition feed wire, where it connects to the ignition module.
The voltage reading here should be compared with the voltage across the battery terminals.
A fully charged battery will typically read around 12.7 Volts, but there will inevitably be some voltage drops across wiring, ignition/kill switch, connections (including earth).
Therefore the voltage reading at the ignition module will be a little lower than that across the battery.
A significantly lower reading than the battery voltage indicates a fault in the ignition/kill switch or a bad electrical connection in the ignition circuit. A simple way to verify this is to connect the ignition module feed wire directly to the battery, bypassing the normal feed from the ignition/kill switch or wiring harness.
If the ignition now produces good sparks, there is a fault in the ignition/kill switch or ignition circuit.
A better way to test for a good power feed to the ignition module is to use a stop lamp or indicator bulb, in addition to the test meter. This draws a similar current to the ignition system and gives a visual indication of available power.
Connect the test bulb between the frame (ground) and the ignition feed wire. Switch the ignition on, the bulb should glow brightly. If the bulb is dim or varies in brightness, try moving the wiring, fuseholder, handlebars, etc., to locate the area of the faulty connection. The bulb will change in brightness (or even go out) when the problem area is found.
IGNITION MODULE HAS POWER - MANUAL TRIGGER TEST
The Sure-Fire ignition module features a simple self-test facility for producing sparks without turning the engine. For the self test:
First, switch the ignition off
Pull the plug caps off the spark plugs
Remove the spark plug(s)
Push the removed spark plugs into the plug caps
Ensure that the spark plug(s) are grounded (making contact) with the cylinder head.For this test to work, the spark must have a good electrical path to engine ground.
If necessary, remove the contact-breaker cover to gain access to the ignition trigger assembly and wiring.
On the trigger assembly, loosen the two connector terminal block screws and remove the two wires (Yellow-Black and White-Black)
Take the two trigger wires (Yellow-Black and White-Black), touch together and open, approximately once per second.Each time you make and break these wires there should be a spark at the plug(s).
When test is finished switch ignition off
Reconnect wires to trigger, observing correct polarity
Refit contact-breaker cover
Refit spark plug(s) and cap(s)
The alternative to step 3 above is to use another spare set of good spark plug(s) for this test, which saves having to remove the existing ones.
Note: the minimum cranking speed for the Sure-Fire ignition module is typically 100rpm, therefore sparks will not be produced if the ignition is triggered slowly by hand.
For twins/triples: all plugs should spark at the same time.
If only one plug produces sparks, check the ignition coil, lead, cap and plug.
On twins/triples, the ignition coils are connected in series, i.e. in a chain, linked from plus to minus.
If one coil fails and develops a short to the case it can stop the other coil(s) after it in the chain from working.
Sometimes a coil has a short to its case, but still produces sparks. This can also prevent the other coil(s) from working.
This is a common problem where the casing of a Lucas coil has been crushed by over-tightening of the clamp.
This can cause the windings inside to touch the case, and the fault often shows up when the coil is warm.
This is best resolved by replacing the coil(s), but a temporary cure can sometimes be effected by insulating the case from the clamp.
If there are no sparks, check battery, switch, earthing, wiring, connections & ignition module.
Continuous sparks without turning the engine indicates a poor supply to the ignition; check battery (bad cell), switch, earthing, & connections.
MANUAL TRIGGER TEST OK - NO SPARKS ON CRANKING
Visually Check the condition of the trigger assembly, including the printed circuit board, pickup coils and connector terminal block. Look for loose or damaged parts. Using a multimeter, check for continuity through the trigger. Set the meter selector switch to 'ohms' (Ω) on a low scale (e.g. x1, x10 or 200). On the underside of the trigger board, Connect the meter probes (either way around) across each pickup coil in turn, across the two solder joints.
The resistance reading should be 55ohms 10% @ 20 C. If either coil gives a high or low reading (or is open circuit) then there could be a broken winding inside the coil. If both coils give the correct reading, measure the total trigger resistance by connecting the meter probes across the connector terminal block. This can be done by touching the probes onto the two metal tags on the back of the terminal block, by pressing the probes hard into the two terminal screws or by inserting the probes into the wire openings. The total resistance reading should be 110ohms 10% @ 20 C.
Keeping the probes connected to the terminal block (or underside of the board), run your fingers around the pickup coils.
If the resistance reading changes there could be a faulty pickup coil or bad connection.
CHECKING THE MAGNETIC ROTOR
Each of the two magnets should hold the weight of the rotor when placed against a piece of steel. Each magnet should have a similar strength. The magnet polarity can be checked, using a compass. Bringing the compass up towards the outer face of the rotor should make the south end of the needle point towards each magnet in turn.
SPARKS ON CRANKING BUT ENGINE WILL NOT RUN
Check the polarity of the wires from the ignition module to the trigger.
The Yellow-Black wire connects to the left-hand terminal on the connector block (marked Y-B on the printed circuit board).
The White-Black wire connects to the right-hand terminal on the connector block (marked W-B on the printed circuit board).
If these wires are swapped the ignition will still produce sparks, but the ignition timing will be very retarded.
It will also retard even further with increasing engine speed.
CONTINUOUS SPARKING, WITHOUT CRANKING THE ENGINE
This indicates a poor supply to the ignition. Check battery for one or more bad cells.
Also, a bad battery with a battery charger connected.
A high resistance in the wiring or earth, due to a bad electrical connection, poor earth or bad ignition switch contacts.
Check for a good earth from the engine case to the frame and battery. Plastic coated frames must have a good earth connection to the engine case.
An incorrect type of ignition coil is fitted, i.e. one with a very low primary resistance (CDI or DIGITAL type).
This will draw a very high current and produce a large voltage drop across the wiring circuits.
This can cause the ignition unit to turn off and on, producing a series of sparks.
Sometimes this can occur very rapidly, so that a buzzing is heard.
post #10 of 11 (permalink) Old 09-17-2018, 12:07 PM
Legend
Old Cafe Racer was right, 6V coils in series.
12V coils are wired in parallel.
Code Man likes this.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is offline
