Black Knee Pads On Side Of Gas Tank? - Triumph Forum: Triumph Rat Motorcycle Forums
 9Likes
post #1 of 25 (permalink) Old 07-03-2017, 06:50 PM Thread Starter
Main Motorcycle: 1970 Triumph Bonneville
Code Man's Avatar
Other Motorcycle: None at this time
What is the best, or correct, way to secure the knee pads to the side of the gas tank on a 70 Bonneville?
Code Man is offline
post #2 of 25 (permalink) Old 07-03-2017, 07:24 PM
max
Main Motorcycle: Thunderbird Storm
Extra Motorcycle: 70 TR6C, 61MatchlessG80CS
Plain old contact glue
Code Man likes this.
max is offline
post #3 of 25 (permalink) Old 07-03-2017, 10:03 PM
Main Motorcycle: T120RT
KADUTZ's Avatar
Other Motorcycle: T140V,T140D,T140E,T140J
The original pads had a double sided tape applied to the pads. The paper backing was removed when you were ready to apply the pads to the tank
If I were doing it toady I would use 3M #3061 (www.walmart.com) or 3M #8061 (your local auto parts store)
Also check with your painter for suggestions
K
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is online now
post #4 of 25 (permalink) Old 07-04-2017, 12:43 AM
Main Motorcycle: 2016 Tri Thruxton Std
Other Motorcycle: I WISH it were a Bultaco
I found some new old stock pads here in Oh, flat checkered surface with original Triumph Logo in center. They went on clean & perfect with RTV silicon sealer/glue. The important thing about using RTV is that it holds its properties (adhesion) up to 400 degrees F.
Clean rubber surface with alcohol (Lavacol) before applying RTV with flat brush. Let the RTV breathe for about ten minutes, and stick em on. They can be removed with a lot of slow and patient pushing with a wood shim, or similar. BTW Do not use acetone anywhere near your bike, or anything that's rubber based. Some fool had acetone in use around his tank - bye bye paint!
Hope this helps, Weedie
"Some folks are educated beyond their intelligence." Mark Twain - An American Original.
weedie is offline
post #5 of 25 (permalink) Old 07-04-2017, 02:01 AM Thread Starter
Code Man's Avatar
Some great suggestions!
The rubber pads that I received do not have any adhesion on them and I guess that's the way they all come these days. I have some of that spray-on 3M adhesion the only thing is I'm concerned about being able to adjust the pad before it sets up. I'll do a test on something with it.
The silicone sounds like it would work pretty well. Probably have to tape the pad on the tank while it cures. I'll do a test on something with it too and see how long it takes to set up. I think ten minutes would be to long. Maybe it depends on the brand and type. Weedie, is that the way you did yours?
Code Man is offline
post #6 of 25 (permalink) Old 07-04-2017, 02:45 AM
Main Motorcycle: 66 Triumph TR6
Other Motorcycle: 66 Triumph T120R
I've always used RTV. Pipe it about an inch from the edge and squiggle in the middle. Push it firmly in place and wipe away any excess. Dries pretty quick to a point where it will hold the weight of the pad and sets up properly in a couple of hours at most. The advantage is that it is very easy to peal away the pad without damaging it and the the RTV on the tank will usually rub off using the tip of your finger and some friction. No damage to paint.
Rod
Redmoggy is online now
post #7 of 25 (permalink) Old 07-04-2017, 04:45 AM
Main Motorcycle: '71 Triumph T120R "Daisy"
Pharisee's Avatar
Other Motorcycle: '68 Triumph T90 "Lilly"
Extra Motorcycle: '55 AJS Model 18S "Bess"
If there's any likelihood of my petrol tank getting anywhere near 400F.... I'm going to be long gone!!!
Bonnie68 likes this.
Pharisee is offline
post #8 of 25 (permalink) Old 07-04-2017, 01:09 PM
wol
Main Motorcycle: T140 "special"
Other Motorcycle: 1970 T120R Project
Extra Motorcycle: yes please
get the pads into the position you want them on the tank using loops of adhesive tape on the back of the pad - just enough to hold them -- then put tape on the tank all around the perimeter of the pad - take the pad off - now you have the exact position of the pad marked on the tank - adhesive of choice - job done
wol is online now
post #9 of 25 (permalink) Old 07-04-2017, 11:26 PM
Talking Not a problem
Well, let's see. Aluminum goes molten at about 900 degrees F, so I think we're ok here. The 400 degree thing was just my abstract way of saying that no amount of heat off the engine is going to cook the RTV and make it fail, sending your knee pads flappin in the breeze.
Man the devil is always in the details. Notice the pictures of the powder coat failure UNDER the damn castrol stickers on a 5 year old bike? Thos stickers are coming off my bike tomorrow morning.
Carry on Lads, Weedie
weedie is offline
post #10 of 25 (permalink) Old 07-04-2017, 11:53 PM
Thumbs up Code Man - RTV useage for your knee pads
Hi CodeMan,
The RTV application is something we were using even way back in the day, it had a double use, for an instant gasket material, or for making things stick without ruining either surface. RTV will not harm the paint it sticks to.
Ok here more recently, I bought two little tubes off ebay, just to be sure it was fresh, sealed in its hang card. AutoZone probably sells it the same way, whichever.
THE HOW TO DO IT:
What I was careful about, clean both surfaces,no dust or fingerprints. Use alcohol on t shirt cotton, good to go.
I spread the RTV on thin with an artist paint brush, cover it right to the edge. Spread it on 100% of the surface of the pad, dont goop it on the pad in big blobs, it will ooze past the edges. It "cures" right away. I don't think RTV ever really dries out. Good idea to do your own tests, get familiar with the stuff.
Obviously, you have to know exactly where to set the pad. I taped it on with painter's tape, used two horizontal pieces of tape to reference the pad position, and then its ready for the RTV.
I made note of just exactly WHERE the end of my knee hit the side of the tank, and this gave me the fore/aft position for the pad. The tank on my Thruxton is no peanut, so it took some fooling around to figure out where they looked the best, Try more than than one position.
The RTV should be the automotive type, not the silicone stuff in the caulking tube.
Be patient, have fun. and let us know how it went. Pics are great if you got em.
Cheers, Weedie
weedie is offline
Tank Knee Pads Jamanimal Hinckley Classic Triples 25 02-12-2017 02:22 PM
recommendations for tank side grip pads STRX Lucydad Street Triple Forum 10 04-26-2015 07:38 AM
