Accel coil and spark plug - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 3 (permalink) Old 01-24-2005, 12:07 AM Thread Starter
Send a message via AIM to wudstoc
Has anyone used or use an ACCEL coil? They recommend setting the plug gap at 35. It seems a bit too big for me. Just curious to what some else has done. Also what spark plug do you use. Thanks
wudstoc is offline
post #2 of 3 (permalink) Old 01-24-2005, 12:07 AM Thread Starter
wudstoc is offline
post #3 of 3 (permalink) Old 01-31-2005, 12:47 PM
Although I have no direct experience with this coil I will tell you what I know in general. A spark plug gap of .035 will give you the best performance. Better mileage , more complete combustion, nicer idle, etc. Now the buts. If you are using a Boyer igniton it must have less than 6 ohms resistance. If you are not running a Boyer do that first. It must have enough voltage ( I think about 40,000 to 50,000). In my day we used the infamous K mart coil. Great voltage etc. How ever the amperage draw was so great that with the headlight on you had a constant loss electrical system. Gradually the bike would just stop running. I know that with the new electronics and such you can get around this issue but sometimes it may take more than just a coil to make it all work. Good luck.
Tiger 955 Spark plug issues. B2S? DaveGPz Tiger Chat 0 09-09-2017 04:34 AM
2006 Scrambler - no start issue ChickMacGyver Air Cooled Twins Technical Talk 47 04-20-2017 02:07 PM
Bonneville power at coil but no spark HMBAtrail Air Cooled Twins Technical Talk 39 01-20-2016 04:46 AM
Spark plug hole Question? Gunner Sprint Forum 4 06-22-2015 07:35 AM
No spark... coil checks out fine, but what about power inputs? gjones Air Cooled Twins Technical Talk 13 04-30-2015 07:58 PM
