Cold starting - Tiger 650 - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 35 (permalink) Old 02-01-2016, 11:13 AM Thread Starter
Main Motorcycle: Triumph 800xcx
jnamohn's Avatar
Other Motorcycle: 1969 Triumph Tiger 650
Extra Motorcycle: Thruxton 900
I have been trying to replace / repair some old parts this winter on my 1969 Tiger 650 to be ready for spring
Replaced the points with an EI system - great now !
Replaced the old Amal carb with a new one (slide was worn out) and am having the old one rebuilt for a spare.
Tried to start yesterday (temp around 48 F) and it was very hard to start. I ended up squirting some carb cleaner into the intake to get it going and it ran great after that. Any ideas why it would be so hard to start or is this just a classic cold starting issue
Seemed like maybe just not getting fuel up to the carb. Maybe jets are too small? Vacuum leak? Runs fine after it's warmed up and has no issues.
Thanks,
Jeff
jnamohn is offline
post #2 of 35 (permalink) Old 02-01-2016, 11:54 AM
Legend
Classic cold starting.
You need to tickle the carb till it starts to dribble out, then activate the enricher lever (turn it to SLACK OFF the cable, not pull it up tight)
Should fire right up w/o starting spray.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is offline
post #3 of 35 (permalink) Old 02-01-2016, 12:00 PM
Main Motorcycle: 1971 t120r
rambo's Avatar
Other Motorcycle: Triumph Rocket 111
Extra Motorcycle: Triumph Thunderbird LT
I would add that with electronic ignition,it may not start if your kick is not fast enough.A lot down to experience and usually no choke needed.If all else fails,easy start is your best friend.
rambo is offline
post #4 of 35 (permalink) Old 02-01-2016, 02:04 PM
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
Is it only me that has never gone near any bike with those sprays?
lovecuba likes this.
Triton Thrasher is offline
post #5 of 35 (permalink) Old 02-01-2016, 03:18 PM Thread Starter
jnamohn's Avatar
It kicks easy once I hit it with some carb cleaner spray in the carb on first kick.
I am wondering if I tuned it with the choke on and now it's too lean when I start it cold.
Jeff
jnamohn is offline
post #6 of 35 (permalink) Old 02-01-2016, 03:54 PM
Jeff
If you did, it might be.
post #7 of 35 (permalink) Old 02-01-2016, 04:17 PM
rambo's Avatar
Start it again with Pauls instructions.If not first kick,it should start by the third attempt.Tiny bit of throttle applied as you kick it over and when it fires,a little bit more.Not a great big handful.
rambo is offline
post #8 of 35 (permalink) Old 02-01-2016, 05:22 PM Thread Starter
jnamohn's Avatar
Thanks too all !
I will double check the choke and make sure it's slack on starting and I didn't tune it with in "ON".
Seems like it just needs more fuel on the cold start and once I shoot some carb cleaner in there it gets the vacuum going and fuel is sucked in?
It's a new carb and was running fine until this start after the last tune in the summer. Maybe some fuel got gummed up in the idle or pilot line?
Jeff
jnamohn is offline
post #9 of 35 (permalink) Old 02-01-2016, 05:27 PM
Main Motorcycle: 2014 Tiger Explorer
pauhig's Avatar
Other Motorcycle: 1971 Tiger TR6R
I have a 1971 Tiger 650. Cold starting procedure is..... clear the clutch, decent tickle, kick over three times with ignition off, tickle again, ignition on and away it goes !! Have done this on many an occasion on weekends away with the Club at country pubs at 10 degrees C or less.
good luck....
pauhig is online now
post #10 of 35 (permalink) Old 02-01-2016, 05:59 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
Pauhig has hit on something............close the choke, tickle the carb, and with the key off, pull in the clutch and kick it over until it kicks with no resistance; this has the double benefit of freeing up the clutch and drawing fuel into the motor, then re-tickle the carb, turn on the key and kick it over with just, what the Brits would call, a "whiff of throttle". It should start with no problem.
Always worked for the "village idiot": Jim
Jim Ballard
jimballard is offline
cold starting the Bonneville Ian Porter Air Cooled Twins Technical Talk 8 08-06-2015 08:32 AM
1971 Tiger 650 Oil Feed Rocker Pipe Problem. christiger650 Classic, Vintage & Veteran 5 07-07-2015 05:25 PM
02 TIger 955 Cold Start Slow Crank tngarrett Tiger's 885i & 955i - Mods & Workshop 2 06-25-2015 03:51 AM
02 Tiger 955i Slow Crank on Cold Start tngarrett The Welcome Center 1 06-17-2015 07:20 PM
Community Support: Tiger 800 vs KLR 650 TigerJake Tiger Chat 5 06-15-2015 01:30 PM
