how to change rear tube with rim locks. - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #1 of 24 (permalink) Old 11-05-2015, 05:26 PM Thread Starter
2XS
Main Motorcycle: 750 bonnie
Ok so a couple years i had new tires put on t 140 with new tubes.
Fast forward couple days ago parked the bike the tire just goes flat the rim lock pinched the tube ordered a new tube changed it out but the rim locks are giving me fits one was shifted off to on side I tried to fix it and pinched the brand new tube. Damn it all.
So what are the tricks to get the tube in the tire get the locks installed and not pinch the tube ?
I'm using tire spoons and a 5 gallon bucket. what do guys use as tire lube ?
2XS is offline
post #2 of 24 (permalink) Old 11-05-2015, 05:43 PM
Main Motorcycle: 1971 t120r
rambo's Avatar
Other Motorcycle: Triumph Rocket 111
Extra Motorcycle: Triumph Thunderbird LT
I took the rim locks out 20 odd years ago and never had a tyre creep on the rim.Just blank off the hole in the rim with a bolt.Make sure the bolt head is very flat,or grind it down to be flat.The correct tyre lube is obviously the best to use,however,i use a silicone lubricant spray and the tyres still never creep on the rim.Just keep the pressure up where they should be.
rambo is offline
post #3 of 24 (permalink) Old 11-05-2015, 05:45 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
Pull the rim locks up as close to the rim as possible then insert the partially inflated tube; when you're installing the final tire bead, make sure to push the rim lock down into the tube when the tire bead is at it, so to speak, so that the tire bead seats properly. It's a pain to do this job (I once spent 8 hours on one), but by taking your time and using the proper tire irons, you should be o.k. For a lube, I used hand soap, but some say that will cause rusting on the rim; there are specific lubes out there for the job.
Not a lot of fun, for sure: Jim
Jim Ballard
jimballard is offline
post #4 of 24 (permalink) Old 11-05-2015, 06:04 PM
Main Motorcycle: 1977 Triumph Bonneville
Other Motorcycle: 1996 Ducati 900ss/cr
Extra Motorcycle: 2007 Ducati S4RS
It also helps to heat the tire so it's more flexible. I bought some long spoons at Harbor Freight and I use something similar to Armor All as a lube. Even after all that it still wasn't any fun. I ended up leaving the locks out and taping over the holes from inside.
duc96cr is offline
post #5 of 24 (permalink) Old 11-05-2015, 07:59 PM
Main Motorcycle: 2002 Ducati ST4s
steved55's Avatar
Other Motorcycle: 1973 T140V
Cure: Remove Locks. Place trash can about five feet away. Toss and let us know your accuracy!
steved55 is offline
post #6 of 24 (permalink) Old 11-05-2015, 08:17 PM
Main Motorcycle: 03 TBird
Beemie's Avatar
Other Motorcycle: '76 Bonnie
http://www.amazon.com/1-7-Formula-Tire-Mounting-Lube/dp/B007GFML72
I used this lube on the last tire changes, radials.
Went right on.
Beemie is offline
post #7 of 24 (permalink) Old 11-05-2015, 08:43 PM
Main Motorcycle: T160
Moderator
Other Motorcycle: T100, T150
Cool
Hi,
couple days ago
With respect, if a rim lock really pinched the tube after two years, the rim lock cannot be the problem, something else is wrong and you're missing it blaming the rim lock.
Fitting a tyre and tube on a rim with locks is easy:-
. Put the lock between the rim and the rim tape (you did check new tapes were fitted with the new tyres and tubes?). Saves weakening the tape with holes for the lock threads and the tape holds the locks in place.
. Screw each lock nut just on to the end of the lock thread.
. Fit the tyre on one side of the rim. As the "spoons" (or the fitting machine) get close to a lock, simply push on the end of the thread to move the lock into the tyre - the tape'll hold the lock in position in one direction, the nut on the thread will stop the lock dropping into the tyre.
. Fit the tube. The tape is holding the locks against the rim so they can't pinch the tube (you are putting a little air into the tube to give it shape?).
. Fit the tyre on the other side of the rim. Again, as the spoons or the fitting machine get close to a lock, simply push on the end of the thread to move the lock into the tyre - the tape and the tube'll hold the lock in position.
. Seat the tyre in the rim, set the correct pressure, fit the rim lock washers and tighten the nuts.
Job done.
Whatever the tyre fitter uses.
How do you do that when you have a puncture?
This is a good cure if you never have a puncture on the move afterwards. Otoh, if you have a puncture on the move, my personal, first-hand experience is having one in a wheel with rim locks is infinitely-less underwear-staining than having one in a wheel without rim locks.
Hth.
Regards,
Stuart
StuartMac is online now
post #8 of 24 (permalink) Old 11-06-2015, 01:08 AM
Rev
Main Motorcycle: T 160 Trident
Other Motorcycle: BMW K1300 R
Extra Motorcycle: 66 Bonnie
Yesterday I was out on my lardy but not so tardy T160. The old slug started wallowing around through turns. And yep, nail punctured rear.
No rim locks & 2 km from home. Ahhhhh decisions, decisions. I thought screw this so I took it real easy and rode home, no way was I ringing you know who for a ute pickup. Tends to squark off a bit if that happens.
Tyre stayed on the rim but I still think they are a good safety investment in case of a high speed blowout. I did have a front blowout about 6 years ago on my old Busa, was very lucky to get away with it, on a bend with a semi big rig coming the other way, still don't know how I pulled that one off
I don't believe no 5 pistoleros could do in Josey Wales.
Boys, this here is English Bob,the Duck of Death. Heard you was dead Little Bill. Hell I heard that too, thought I was dead myself, turns out I was just in Nebraska...
Rev is offline
post #9 of 24 (permalink) Old 11-06-2015, 11:00 PM
Main Motorcycle: 1970 Triumph Bonneville
Code Man's Avatar
Other Motorcycle: None at this time
2XS: I'm using tire spoons and a 5 gallon bucket. what do guys use as tire lube ?
Hello 2XS,
For tire lube, I used baby powder! Less of a mess. I rubbed it all over the tube and the inside of the tire before sticking the tube in the tire. Then put air in the tube temporarily to straiten the tube out so it didn't have any kinks. I watched a couple video's on YouTube before attempting to mount the tire and found it really helpful. Again, all I used was the talcum powder and it work great.....Gary
Code Man is online now
post #10 of 24 (permalink) Old 11-07-2015, 03:19 AM
rambo's Avatar
Always good if you have a helper and about 5 levers.I get the tyre on fairly easy that way without the security bolts.I have only had 2 rear tyre punctures since 1969 so not too worried about a future puncture.I only use roads so not likely to pick up prickles.
Normally,a rear tyre puncture will go down at a controlled pace if it is a tubed tyre and you might get a chance to slow down in control.Most important is how old the tyres and tubes are, and to replace the tube at every tyre change .Of course,there is a product that can be squirted into the tube to mend a puncture as it happens.I have this in a bicycle and it has worked fairly well in allowing a very slow let down.
rambo is offline
2012 T100 Rear Wheel Change to 18" Borrani Rim Big Daddy Air Cooled Twins Technical Talk 3 10-01-2015 05:13 PM
Thunderbird Rear Wheel Rim Strip? Beemie Hinckley Classic Triples 9 07-18-2015 11:46 PM
Change rear tire only with stock or the pair with a different set? bimmerboyE92 Street Triple Forum 9 06-04-2015 03:28 PM
Want to change rear wheel on '98 T-Bird Kball1300 Hinckley Classic Triples 17 05-14-2015 03:37 PM
Step by step lighting update Inline Air Cooled Twins Technical Talk 5 03-15-2015 04:56 AM
