Fork Oil Research - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 05-24-2015, 11:21 PM Thread Starter
Main Motorcycle: 03 TBird
Beemie's Avatar
Other Motorcycle: '76 Bonnie
Fork Oil Research
In trying to translate my '76 T140 owners manual recommendations on fork oil to current products, I thought I share the information found. Hopefully the extrapolations of the information are correct.
The owner's manual lists several specific AFT oils, a couple being Mobil ATF 210 and Castrol T.Q.F.
Information is still available on both these products which are type "F" or Ford spec trans oils. One opinion expressed was that Type F was basically a 20 weight motor oil base with additives and red dye and without friction modifiers.
The specs found on Mobil ATF 210 were: 8.5 viscosity @ 100 degrees C, 39 viscosity @ 40 C., Visc Index 196.
The Castrol TQF specs were 8.5 viscosity @ 100 degrees C, viscosity @ 40 C not listed, Visc Index 166.
The two products were similar except in the VI, which apparently indicates variability of viscosity within a temperature range, higher number being less variability.
One product that seems it may match up is Maxima Racing Fork oil in 15 weight which has 8.5 viscosity @ 100 C, VI 151.
The Maxima regular 15 weight fork oil also has a 8.5 viscosity @ 100 C and 47 @ 40 C, VI 151.
These look similar to the original ATFs seeming to indicate that a 15 weight fork oil may be in the general ball park of the original specs.
I didn't look into other brands but hopefully similar information is available.
That being said, one thing learned was that oil grade (weight, a misnomer?) is Not it's viscosity. A local dealer thought that 7 1/2 weight fork oil was about equal to AFT but it doesn't look that way from the comparisons above
To take the weight out of the picture, there are also a couple current synthetic ATFs, Amsoil and Redline, that are noted as "Racing" and referred to as type "F".
The Amsoil is listed as 7.1 viscosity @ 100C and 40 @ 40C.
The Redline is listed as 10 viscosity @ 100C and 54 @ 40C, a bit higher than the former.
To me it looks like a 15 weight fork oil, or perhaps a mix of 15 and 10wts may be a reasonable match to the ATF specified in the T140 manual, with the Amsoil Racing ATF an alternative.
Any supporting or contradictory information would be welcome.
Beemie is offline
post #2 of 17 (permalink) Old 05-25-2015, 01:33 AM Thread Starter
Beemie's Avatar
Here is a good comparison chart:
http://www.advrider.com/forums/showt...=286065&page=6
Unfortunately it doesn't cross reference ATF.
Beemie is offline
post #3 of 17 (permalink) Old 05-27-2015, 09:47 AM
Main Motorcycle: 1973 Triumph TR7RV
TR7RVMan's Avatar
Other Motorcycle: 1964 Triumph Mountain Cub
Hi Beemie keeping in mind forks run cold meaning say 25-110f I did a drip test. Took some paper cups. Poked a pin hole in bottom & filled cup to a line about 3/4 full. Then counted how many seconds it took to drip into a lower cup to marked line about 1/4 from bottom.
I found most atf compares to 7.5w Belray fork oil with the drip test. Type F, DexronIII, Mercedes atf134, 5/40 synthetic motor oil were all quite close. I used atf134 because it's free to me.
I've checked the temp on many auto trans at work as some the level is set at 80c. On a summer day the trans will normally run near 100c which is of course is 220f.
Don
TR7RVMan is offline
post #4 of 17 (permalink) Old 05-27-2015, 05:12 PM
Main Motorcycle: '71 Triumph T120R "Daisy"
Pharisee's Avatar
Other Motorcycle: '68 Triumph T90 "Lilly"
Extra Motorcycle: '55 AJS Model 18S "Bess"
It was 212F when I went to school.
Pharisee is offline
post #5 of 17 (permalink) Old 05-28-2015, 02:01 PM Thread Starter
Beemie's Avatar
drip test. Took some paper cups. Poked a pin hole in bottom & filled cup to a line about 3/4 full. Then counted how many seconds it took to drip into a lower cup to marked line about 1/4 from bottom. Don
Interesting. I'd need to think about whether that was a legit viscosity test or a test of another property of the fluids. Going down stairs to dig out the fluid dynamics book from school.
You say "about" 3.4 full.
First thoughts are that different depths as well as different densities would produce different pressures at the bottom of the cup.
Beemie is offline
post #6 of 17 (permalink) Old 05-28-2015, 08:54 PM
Main Motorcycle: Triumph Tiger 800XC
NORTY FLATZ's Avatar
Other Motorcycle: 2016 Harley FXDL,
Extra Motorcycle: 2018 Husqvarna 701E
The forks on motorcycles, are hydraulic actuated. (Except Harley Davidson's "Springer" type forks, that are no longer marketed.)
This means you can use a hydraulic oil/fluid. I would pick a premium oil that has all the additives that are needed. Don't just get an "R & O" (rust & oxidation inhibited fluid).
You'll want anti-foaming, water shedding, & other properties.
My recommendation would be to use 1 (or mix 2) of Shell's Tellus oils. You'll find them in many different viscosity grades.
MSF RiderCoach. Retired!
NORTY FLATZ is offline
post #7 of 17 (permalink) Old 05-29-2015, 02:48 AM
TR7RVMan's Avatar
Sorry, 220 was a boo boo by my fingers...
Don
TR7RVMan is offline
post #8 of 17 (permalink) Old 05-29-2015, 09:54 AM Thread Starter
Beemie's Avatar
I ride at 75 degrees and up and as noted before I can find viscosity numbers for the original spec'd ATF and current fork oils at 40C which is 104F to be between 10 and 15 weight Maxima fork oil.
The VI is fairly high meaning there shouldn't be a big change in viscosity in a small temperature change going from 104F to say 80F so I think I'm on the right track, atleast for my usage range.
But I managed to get a more specifically technically trained fellow involved for another opinion.
Beemie is offline
post #9 of 17 (permalink) Old 05-29-2015, 09:55 AM Thread Starter
Beemie's Avatar
Ya but Celcius or Centigrade?
Beemie is offline
post #10 of 17 (permalink) Old 05-29-2015, 09:57 AM Thread Starter
Beemie's Avatar
The exercise is to determine an equivalent weight to the original spec'd AFT, which by example is Shell ATF 210.
Beemie is offline
How To: Progressive Suspension progressive springs cb200t Air Cooled Twins Technical Talk 3 03-04-2019 02:11 PM
Fork oil removal reidy41 Air Cooled Twins Technical Talk 26 05-22-2015 10:53 AM
Fumoto quick oil drain valve (Long & Boring) Forchetto Air Cooled Twins Technical Talk 36 05-02-2015 09:49 PM
When and how to check air gap and fork oil SkipII Air Cooled Twins Technical Talk 11 04-09-2015 09:27 PM
new fork seals and oil / front end bounce ("patter?") kvdv Air Cooled Twins Technical Talk 4 03-18-2015 02:14 PM
