Charlies filter kit fit, Tiger 750. - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 35 (permalink) Old 04-12-2015, 01:12 PM Thread Starter
Main Motorcycle: 1978 Triumph 750 Tiger
tommytiger's Avatar
Other Motorcycle: Trident 900
Extra Motorcycle: Cz350
Finally got round to buying my Charlies types filter kit, I have had a filter fitted to the return line for 3 years in an attempt to extend engine life and reduce the speed my sludge trap fills up. I'm going belt and braces now by also fitting a Charlies.
Simple job I know nut I'd just ask you fellas first if you have any tips and any other jobs I could tackle whilst at it eg. a wash out of the oil tank/frame tube?
tommytiger is offline
post #2 of 35 (permalink) Old 04-12-2015, 03:37 PM
Main Motorcycle: T140 E
I guess it would make sense to replace the rubber pipe if it is old, and I think that the new cnc'd ones that people have reviewed on here had slightly tights holes? So they opened them up slightly.
Other than that, unless your bike is an early one with the internal pipe, it just
Pops on. I suppose a wash with a paraffin gun might be worth it if you have one
DAVE M is online now
post #3 of 35 (permalink) Old 04-12-2015, 05:12 PM
Main Motorcycle: 1971 t120r
rambo's Avatar
Other Motorcycle: Triumph Rocket 111
Extra Motorcycle: Triumph Thunderbird LT
There is no need to clean the frame oil tube.Look in from the bottom and you will find nothing sticks to it.
rambo is online now
post #4 of 35 (permalink) Old 04-12-2015, 05:25 PM
Main Motorcycle: Triumph TR7
Other Motorcycle: T140
Extra Motorcycle: Most of another T140
Just swap & go really Tommy. My only advice will either be irrelevant or too late, because it is to avoid the Burton bike Bits type kits and get a Motao kit (the CNCd plate Dave referred to above). They are miles better in every way, and if you shop around, cheaper too.
JohnA is offline
post #5 of 35 (permalink) Old 04-12-2015, 05:56 PM Thread Starter
tommytiger's Avatar
Bu**er seems I have gone and bought a non cnc higher quality item!!
Have done a search and yes they look much better quality than the one I have which is cast.
Why did I not ask this question before I purchased? I wonder if TMS will take it back?
Research twice, buy once!!!
post #6 of 35 (permalink) Old 04-12-2015, 06:08 PM
Aye, bugge* indeed! Try a magnet on the outlet stub. Some of the pattern sump plates have this as an integral part of the casting, and they are VERY fragile (as I found to my cost). It seems several places make these plates, as most seem to have the proper pressed in steel outlet tube (I'm pretty sure TMS's kits have the steel tube).
The Motao kit has several advantages, including that the threaded rod that runs through the filter is threaded into a blind hole in the plate, meaning no possibility of leaks from there. They also have a threaded oil outlet pipe, meaning you can hole it with a 3/4" spanner and unscrew the whole plate from it, without having to disturb the hose's fit on the stub when changing the filter. They also have a strong magnet in the drain plug. They also have a cutout across the bottom, to allow clearance for the centrestand (the normal type have a domed nut right where the stand's cross-member is, which gets slammed into every time you roll the bike off the stand). And they're also rather beautifully made.
JohnA is offline
post #7 of 35 (permalink) Old 04-12-2015, 06:28 PM
Main Motorcycle: 2012 800 Tiger
lovecuba's Avatar
Other Motorcycle: 1977 T140
Oil Filter
And, when you replace the filter element you can use a Wix 57203 which has a larger diameter (twice the filter area of a standard replacement Charlie element) and is a 1/4 of the price (out here anyway).
lovecuba is offline
post #8 of 35 (permalink) Old 04-13-2015, 06:14 AM
to be fair, I have had a "genuine" charlie's from 84 and it is fine.
It uses a genuine Meriden part with steel outlet. The central stud can be prone to weeping if you don't take care but mine is fine.
post #9 of 35 (permalink) Old 04-13-2015, 08:42 AM
Main Motorcycle: 1977 Triumph Bonneville
Other Motorcycle: 1996 Ducati 900ss/cr
Extra Motorcycle: 2007 Ducati S4RS
I did have some sludge inside my frame. I sprayed it out with brake cleaner. I also have the cast spigot plate with a through hole for the stud and it wasn't threaded. It leaked. When I had it apart I lengthened the stud and put two filters in and used sealer on the stud hole with a fiber washer on each side. It's worked fine since.
duc96cr is offline
post #10 of 35 (permalink) Old 04-13-2015, 11:54 AM
Main Motorcycle: T140ES
Other Motorcycle: Street Triple R
where can you buy the Motao kit in the UK from.
Marko999 is offline
Harris Tiger 750 rodphoto Classic, Vintage & Veteran 32 06-23-2016 04:01 PM
73 750 Tiger new Mikuni carb - runs on choke only Triumph5ta Classic, Vintage & Veteran 15 10-28-2015 10:03 AM
K&N Air Filter Definitely Does Not Fit patrickcol Air Cooled Twins Technical Talk 17 09-08-2015 06:12 AM
750 tiger Lespaul59 The Welcome Center 2 03-30-2015 07:30 PM
