Amal MK2 Carb T140E Jet Confusion - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 08-14-2014, 11:31 PM Thread Starter
Main Motorcycle: 1978 T140E
Other Motorcycle: 1975 Triumph T160 Trident
Extra Motorcycle: BMW F650GS
I have a 1978 T140E. The Amal MK2 carbs are in rough shape and impossible to tune. Itís to a point where it makes more sense to just replace, rather than rebuild them.
When I order the new carbs I need to specify the jets, needle and slide I want. Iím confused because 1978 Triumph parts manual (T140E supplement) specifies one thing, while the 1979 T140E manual another. The 1978 manual calls for the needle jet to be a .105, pilot jet 25 and the starter jet to be a 50. The 1979 manual calls for the needle jet to be .106, pilot 20 and the starter jet to be a 35. As far as I know, the 1978 and 1979 T140E engines were identical, so I donít understand why these jets are different. Did they learn something between the publication of the two manuals? Would I be better to go with the 1979 specified jets, or should I stick to the original í78 recommendations?
2wheelride is offline
post #2 of 17 (permalink) Old 08-15-2014, 12:10 AM
Main Motorcycle: The one I'm on.
House Hubby's Avatar
Other Motorcycle: Suzuki Bandit 1200
Extra Motorcycle: KTM 525 EXC
Although I have no personal experience with the T140, or the Mk ll carbs, from what I recall the E suffix referred to "Emissions" Therefore I would assume the 79 specs would be more restrictive than the 78. I would go with the 78 spec. carbs.
Alan.
House Hubby is offline
post #3 of 17 (permalink) Old 08-15-2014, 05:05 AM
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
There was European jetting and US jetting and changes made to very late models, apparently.
I refer you to J Healy, here:
http://www.britbike.com/forums/ubbth...752#Post121752
Triton Thrasher is offline
post #4 of 17 (permalink) Old 08-15-2014, 05:38 AM
Main Motorcycle: T140E 1979
Other Motorcycle: Yes
When I rebuilt my T140E I used the 2C3's and .105's it ran okay but seemed to feel restricted, after much experimenting, I went with the 2A1's and .106 and the difference was night and day, needless to say I have stayed with this combo. (I am running peashooters with no balance pipe and T120 cams).
tribsa1954 is offline
post #5 of 17 (permalink) Old 08-15-2014, 11:05 PM Thread Starter
Thanks for the help. The Healy post was very helpful. Considering my bike is stock, standard exhaust system and cams, I'm going to go with the stock '78 setup. I know it will provide a good starting point and I can always make minor adjustments from there.
post #6 of 17 (permalink) Old 08-15-2014, 11:16 PM
Main Motorcycle: T120RT
KADUTZ's Avatar
Other Motorcycle: T140V,T140D,T140E,T140J
2wheel
There were some problem's with the jetting when these were new also plug fouling.
To eliminate problems use the jetting as shown in the thread listed by Triton Thrasher.
Just wondering did you make the Bike show last week end at MCC.
K
TRIUMPH
"THE WORLDS PRE-EMINENT MOTORCYCLE"
KADUTZ is online now
post #7 of 17 (permalink) Old 08-16-2014, 02:11 PM
Main Motorcycle: 1978 Triumph Bonneville
htown16's Avatar
The stock "US" jetting works fine with the factory mufflers and air cleaners. I ran it for years with no problem. When I went to more open peashooter mufflers and uni foam aircleaners I switch to the "European" jetting and that also works fine with that configuration.
Run N5C Champions or equivalents not N3C's in the 1978&1/2 and later t140e and d bikes with the parallel port heads and Mark II's. Less fouling problems.
Htown16, Houston, Texas
1978 T140E Bonneville, 1974 Trident, 1972 Commando, 1971 Commando
1974 Commando, 1970 BSA Thunderbolt, 2004 XL 1200R Sportster
Everything will be alright in the end.
If its not alright, its not the end.
htown16 is offline
post #8 of 17 (permalink) Old 08-17-2014, 11:10 PM Thread Starter
Originally Posted by KADUTZ View Post
2wheel
To eliminate problems .
K
". . .use the jetting as shown in the thread listed by Triton Thrasher" EPA or non-EPA (Euro)?
As recommended by htown16, I'm thinking the stock "US" jetting is probably the way to go.
I did make the MCC show - a lot of great bikes and good conversation!
post #9 of 17 (permalink) Old 08-18-2014, 05:22 AM
Main Motorcycle: T140 E
you'd get better performance with the European jetting
DAVE M is online now
post #10 of 17 (permalink) Old 08-18-2014, 06:57 AM
KADUTZ's Avatar
2wheel
If it were me I would be using the jetting as recommended by Triton Thrasher. That is same I was going to post. John Healy is very wise in the ways of Triumph.
I enjoyed the show also have been to 22 out of the last 23.
Since your in the area you might want to consider joining the sponsoring club.
K
TRIUMPH
Carb tuning advise required Amal MK2 ruger001 Classic, Vintage & Veteran 8 03-22-2014 09:25 PM
Carb jetting ideas for 32mm amal MK2 boyzee Classic, Vintage & Veteran 2 07-23-2013 05:14 AM
Amal Mk2 pilot jet tubes Vince C Classic, Vintage & Veteran 6 02-08-2013 05:35 AM
Amal mk2 jet question stevelak1 Classic, Vintage & Veteran 5 05-19-2010 07:16 AM
