66 T120 Oil circuit diagram? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 09-12-2013, 07:02 AM Thread Starter
Main Motorcycle: 66 Triumph Trophy Chopper
I am waiting on a service manual to get here that hopefully will shed light on my inquiring minds questions...But in the meantime...
I am wondering if there is an oil circuit diagram. I was looking at a video that was detailing the oil pump system and I'm curious now what the oil circuit is.
It looks as if oil is gravity fed to the pump and them i would assume the pump feeds the crank and cams through the block?
and I see there is a hose that feeds the rockers. is that pumped separately. tank/pump/rockers? or is that fed from oil from the block?
How does the oil return to the tank? is there a filter someplace?
I was watching the LUNMAD youtube video's showing him adding an oil filter and this got me wondering where in the circuit is the filter going?
Zc
Zero Cool is offline
post #2 of 12 (permalink) Old 09-12-2013, 07:19 AM Thread Starter
And of course the second I post this. i googled in a different want and found a FREE service manual that i just ordered...and lo and behold...here is the oil circuit diagram...sheeesh...
post #3 of 12 (permalink) Old 09-12-2013, 07:20 AM
Main Motorcycle: 1970 Bonneville
henryanthony is offline
post #4 of 12 (permalink) Old 09-12-2013, 07:23 AM Thread Starter
Originally Posted by henryanthony View Post
LOL! yup MEGA thanks! that is the manual i just downloaded...AND the manual i just ordered off eBay hahaha oh well...
Zc
post #5 of 12 (permalink) Old 09-12-2013, 08:30 AM
Main Motorcycle: T140 E
Lunmad should have explained the send/return from the filter. I'm sure thathe will have done.
It goes from the return side of the engine, after both sides of the pump.
You're just iinterupting the return with the fliter and allowing the filter outputto return back to the tank
DAVE M is online now
post #6 of 12 (permalink) Old 09-29-2013, 02:43 PM Thread Starter
looking at the oil circuit, you can't really put a filter where it really should go. after the oil pump and before everything else.
whats the risk of reducing oil flow or pressure to the rockers with the filter inline there??
I was thinking of using an oberg tattletale type reusable filter.
Zc
post #7 of 12 (permalink) Old 09-29-2013, 03:34 PM
Main Motorcycle: T110 Triton
Triton Thrasher's Avatar
A filter in the return line appears to have no bad effects on rocker feed or anything else.
Triton Thrasher is offline
post #8 of 12 (permalink) Old 09-29-2013, 03:41 PM Thread Starter
I suppose that should the filter get clogged, cutting off oil flow to the rockers would be....less bad... then cutting off all oil flow?
post #9 of 12 (permalink) Old 09-29-2013, 04:02 PM
If you left it unchanged for 50,000 miles it might clog. Then the hose would be forced off and the scavenged oil would be pumped out onto the road.
post #10 of 12 (permalink) Old 09-29-2013, 05:09 PM
Main Motorcycle: T100R Daytona special
Other Motorcycle: Ducati 748/853
Extra Motorcycle: Cagiva Mito, Yamaha SR500
Oil filters have a bypass valve which opens if they get clogged.
davy
Enn skal lytte, når en gammel hund gjø.
Old Cafe Racer is offline
Ignition coil open circuit or short circuit to battery Sasha Speed Triple Forum 9 04-26-2012 03:35 AM
Starting circuit issue. Looking for wiring diagram. uktech1 Street Triple Forum 5 04-22-2012 10:07 PM
Oil Pressure circuit? retrofit187 Triumph SuperSports 2 07-02-2008 05:17 PM
71' T120 Oil Tank? inurgarden Classic, Vintage & Veteran 2 05-27-2006 06:14 PM
T120 wiring diagram slash5bmw Classic, Vintage & Veteran 6 09-28-2004 11:19 AM
