Steel screw stuck in an alloy casing, suggestions? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 10-22-2009, 11:45 AM Thread Starter
Steel screw stuck in an alloy casing, Its out!!!!
Howdy all, I was sorting a high beam/low beam issue on my 71 Bonnie and have come across this problem, the last person into the handlebars electrics had effectively rounded out the philips head screw that holds the plastic assembly with the horn and lights circuit. It looked like they had spun the screw over and over with an electric drill with a philips head bit in it, it was completely rounded out and would not take a screwdriver.
At the time my dremmel was in arms reach so I took the wrecked head off the screw with the dremmel and pulled the electrics out.
I then thought it would just be a matter of putting some long nosed pliers onto the rest of the screw and removing it and replacing it.
Unfortunately the frikkin thing is jammed tight, and I am terrified of snapping it off.
I initially went and bought a can of freezing lubricant, the type where you spray the stuck bolt and the snap freeze cracks the corrosion holding the bolt. No luck with that, so I tried the opposite direction, and got out my soldering iron and heated the bolt and tried again, no luck. Out of frustration, I did the soldering iron again, then hit it with the freeze treatment, still no luck. All this in the mean time slowly wearing what little of the bolt I had to get some sort of purchase on away.
It is currently sitting soaking with some penetrating oil spray on it, now before I go and buy a remarkably small pair of vice grips and try again tomorrow, does anyone have a sure fire remedy for this sort of situation?
dogtired is offline
post #2 of 14 (permalink) Old 10-22-2009, 11:55 AM
Main Motorcycle: '68 TR6R
68TR6R's Avatar
Other Motorcycle: 1978 suzuki 125
Unfortunately, it's too late for my suggestion, but for future reference. If you have a phillips head screw that is rounded to the point that even a hammer impact wont remove it, you can take a dremel with a cutoff wheel and grind a slot and use a big flat screwdriver to remove it. I always try the impact first. Now, either you can try to turn it with the vise grips or us a reverse pitch drill bit and see if it will spin out.
68TR6R is offline
post #3 of 14 (permalink) Old 10-22-2009, 11:59 AM Thread Starter
Yerp, tried that on the way out, cut a slot, and the screw was so tight it popped one half of the head off the screw as I was giving it some with a screwdriver..
It is an old trick, we used it a lot restoring antique furniture where screw heads would be corroded beyond viability.
(Used to have an antique resto business till the wife went feral on me)
dogtired is offline
post #4 of 14 (permalink) Old 10-22-2009, 01:10 PM
Main Motorcycle: T120R Bonneville (mine)
Plewsy's Avatar
Other Motorcycle: I wish
hi dogtired
that looks a pain, with what is left of it! you should give it lots of little whacks and maybe mushroom the end a touch, then try smacking a small 1/4 drive socket onto it.
You might just get lucky and not snap it off, a bit of heat would be handy.
If it does snap off its the (not very) easyouts, or drilling and taping.
Plewsy is offline
post #5 of 14 (permalink) Old 10-22-2009, 02:37 PM
TBS
Just use a blowlamp on it for a while to heat the casing and break the corrosion seal, it will come out with no problems with a decent pair of grips.
TBS is offline
post #6 of 14 (permalink) Old 10-22-2009, 04:42 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
I recently removed a very "frozen" bolt by lubricating it with "Break Free" which is a Teflon based product that is usually sold in gun shops and sporting goods stores. It took 3 or 4 days of applying it once a day, but in the end it had worked its way through the corrosion. If you've got the time, it's worth a try. Also, when you do try to remove it, use a small pair of vice-grips (mole-grips?) and be very gentle.
Hope this helps: Jim
Jim Ballard
jimballard is offline
post #7 of 14 (permalink) Old 10-22-2009, 04:56 PM
Other Motorcycle: Triumph Speedtriple
You can buy a very small set of pointed nose vice grips, they are very good (I'd be lost without mine)
Webby
Webby is offline
post #8 of 14 (permalink) Old 10-22-2009, 05:02 PM
Main Motorcycle: 2018 Speedmaster
oldroadie's Avatar
If you have some ATF and acetone you can make a 50/50 mix and put a few drops on the screw to break the bond between the steel and aluminum. Might take a couple of doses to get all the way thru. Then with a set of smallish vice grips firmly attached, I like the needle nose model, give the screw a tiny turn towards tighten then see if it won't come on out.
2006 Scrambler
1974 BMW R90 sidecar rig
2001 BMW R1100RT
oldroadie is offline
post #9 of 14 (permalink) Old 10-22-2009, 06:25 PM Thread Starter
Thanks all for the advice, I think the most important thing most of you are saying is allow it time for the penetrating oil to get into it. Will let it sit a few days and keep at it with the oil and give it every chance before I attack it again with the hot and cold methods, and a damn good set of miniature vice grips. I need all the help I can get, the actual screw is possibly less than 2mm diameter.
Will post the results in a few days, thanks again.
dogtired is offline
post #10 of 14 (permalink) Old 10-22-2009, 11:55 PM
Main Motorcycle: 1976 T140V - 1983 TSS
thirdbike's Avatar
Other Motorcycle: 1950 Matchless G80
Extra Motorcycle: 1992 Yamaha XVZ13
The bolt is a bit small for an easy-out. Don't force anything if the penetrating oil trick doesn't work. Instead throw the piece in the freezer for a couple of hours. Use an acetylene torch with a small tip and quickly heat the surrounding aluminum to a max of 302 degrees Fahrenheit or about 150 degrees Celsius and the stub should turn free very easily with a set of vice-grips. The combination of lubricants and heat differential should do it but if it doesn't come out easily, you can assume that the PO used a non-conforming bolt. I'd be expecting this to be the case given the grief you've had so far. If you can get enough of a bite on the stud it may still come out but the thread will be damaged. In order to get a proper purchase on the stud, a bit of careful filing will help the vice-grip to grab on.
thirdbike is offline
Steel or Alloy rear sprocket Kev_England Classic, Vintage & Veteran 3 09-01-2009 05:51 PM
stuck pinch bolt - any suggestions millwallfcuk T3 Sport / Touring Forum 17 08-01-2009 03:19 AM
Idle Mixture Screw/Pilot Screw skromfols Air Cooled Twins Technical Talk 7 07-30-2009 10:35 AM
Compression dampening force adjuster screw stuck... Reppyboyo Triumph SuperSports 5 07-06-2007 03:54 PM
Tickler stuck leaking gas. Suggestions? Otis Maintenance & Workshop Talk 6 08-24-2005 09:22 AM
