What's the best way to fix tiny paint chips? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 01-24-2009, 08:17 PM Thread Starter
Main Motorcycle: 1970 TR6R
Other Motorcycle: 2006 Scrambler
Extra Motorcycle: 1966 Lambretta
Since I've been riding my restored '70 Tiger I have about a half dozen very minor paint chips. Not a big deal and I definately wouldn't consider riding it less to avoid having this kind of stuff happen. But I would like to touch up the paint chips if possible. I had a tiny stratch on the bottom of my side cover not in a noticeable spot so tried touching up with Diamond Hard Acrylic Enamel (rust inhibiting) and using a very fine paint brush. I could definately see the paint brush marks when I was done. In another spot on the side cover there were a few very tiny chips (pin head size) which I gave very gentle dabs of paint to, and the result was a lot better, no paint brush marks at all, much harder to notice. But on my gas tank and fenders I have a few very small chips, I figured I could get a small container of touch up paint from Don Hutchinson in correct Spring Gold, the only question is do I dab at the chip with a paint brush or is there another more sophisticated way (that a handy person could do without any special tools) to touch up where the result is better/less noticeable? Thanks a lot because I intend to ride my bike like crazy, and I know I will be getting some more wee chips in her paint, not a big deal but I'd like to know how to fix them.
GleaminTwin is offline
post #2 of 5 (permalink) Old 01-24-2009, 10:05 PM
To fix the chips put a drop with a toothpick or similar and let dry. Then repeat until the paint is higher than the surface. You can then block sand the spot carefully with 600 paper until level and then go to finer papers up to 1500. Then polish with a compound to the desired finish.
Another trick to level is to use a straight razor blade with a wrap of masking tape on each end leaving the center bare. Then gently knock down the built up drop until level with the rest of the surface...sand. polish.
Snakepit is offline
post #3 of 5 (permalink) Old 01-24-2009, 11:20 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
I've gently dabbed a little paint in the chip, keeping the level lower than the actual painted surface, then, when it's dry I use a bit of clear lacquer such as nail polish on top of it and polish it down to blend in with the rest. I believe the factory used a clear coat of lacquer back then, and the clear is much more forgiving. Needless to say, practice a bit until you're comfortable with it, and make sure your paint doesn't react with the clear coat. And, as "She Who Must Be Obeyed" once said to me: "Are you going to ride it, or put the world's largest cake plate cover over it and just look at it?" They were made to be ridden; I know how you feel as mine is original with just another clear coat done on the tank some years back.
Don't let it become an obsession, like I did for a while: Jim
Jim Ballard
jimballard is offline
post #4 of 5 (permalink) Old 01-25-2009, 03:01 PM Thread Starter
OK, thanks for the tips. When I'm sanding I'm gonna assume use a very small piece of sandpaper so as not to scratch the paint surrounding the chipped spot (maybe glue a piece of sand paper to a pencil eraser). I'm also gonna wait 'til spring b/c I think the garage is too cold now for the paint to dry. Do you guys recommend wet sanding or dry sanding. I'm gonna assume I'd also sand the clear coat following the same procedure. I know the perfect spot on the bike to practice: I have a couple chips on the paint on the fender under the seat. Cheers .. Jason
post #5 of 5 (permalink) Old 01-25-2009, 03:22 PM
wet sand. Use a sanding block. Level the spot with 600. Once you are at a fine grade (1000 then 1200 then 1500 and 2000 if you want) you'll be sanding a bigger area.
But sand lightly and only as much as required to eliminate the previous sandpapers scratches...be careful not to sand more than needed so you don't sand through the clear.
I like Farecla polishing compound. http://www.farecla.com/ You use it with water and their G mop. Start with G3 compound. wash surface and Gmop well and then finish with G10
Snakepit is offline
cheap as chips from China iceman Biker Hang-Out 11 03-19-2009 02:52 PM
Rock Chips to OEM Belly Pan? cmc1978 Speed Triple Forum 4 05-21-2008 07:08 AM
Tiny specks of paint damage on gas tank? chamade Sprint Forum 8 09-08-2006 01:57 PM
ST05/6 stone chips ST Sprint Forum 7 08-26-2005 09:44 AM
Paint chips clogging reserve petcock? UJMrider Hinckley Classic Triples 6 08-01-2005 05:12 PM
