Tire Mounting - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 19Likes
post #11 of 37 (permalink) Old 11-13-2018, 02:21 PM
Main Motorcycle: 17' T100
Other Motorcycle: Gold Wing
I find it's not the act of mounting and balancing the tire, but the act of removal of the tires from the bike that is the hardest part of the job. I have been changing my tires for years and have saved alot of money not to mention the satisfaction of working on my own bikes. With the right tools a comfortable garage space any one can do it. All you safe can go to buying more gas and more riding.
tawhuhn is offline
post #12 of 37 (permalink) Old 11-15-2018, 01:29 AM
Main Motorcycle: 03 TBird
Beemie's Avatar
Other Motorcycle: '76 Bonnie
I always did my own (by hand) but on my last set thought I'd try the local Triumph shop.
I was quoted a price but when it was finished I was charged more.
I questioned it and was told that they added in weights, charging by the ounce. How petty.
Never went back.
Maybe I should add pencil charges to my design work.
Beemie is offline
post #13 of 37 (permalink) Old 11-15-2018, 03:51 AM
Main Motorcycle: Thruxton 900
Other Motorcycle: Thruxton 1200r
Extra Motorcycle: KTM Duke 390
Further to useful equipment for fitting I have used aerosol polish ( Mr Sheen ) as an alternative to soap to seat the beads when soap was not available . And stick on weights can be reused with suitable double sided tape ( servo tape from radio control car ) not that I'm tight/cheap or anything .
BonnieBlack likes this.
Hedgepig is offline
post #14 of 37 (permalink) Old 11-16-2018, 12:47 PM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
I've watched a video of a tire being mounted use large plastic wire ties; the new tire was "tied" in 5 or so areas around the circumference of the tire, pulling both beads together. The tire was lubed and force onto the rim as if it were a solid piece, not one with 2 sides, so to speak. The ties were then cut off, the beads seated and the tire filled with air. I've never tried this method, but look for a video of it. The ones doing the video claim that this method also will work with tubed tires as long as you protect the valve stem and have it oriented properly to the hole in the rim.
Just a thought on the subject: Jim
Back2-2 likes this.
Jim Ballard
jimballard is offline
post #15 of 37 (permalink) Old 11-16-2018, 01:10 PM
I was quoted $430.00 for 2 tires and mounting. I know they must make a profit but that is to rich for my blood. I would have to stop riding if I needed to use a dealer for everything. Like I stated in my last post, it's not the mounting the tire to the rim, it's the mounting the tire and rim to the bike. That's what takes the time.
tawhuhn is offline
post #16 of 37 (permalink) Old 11-16-2018, 03:32 PM
The Hornet's Avatar
Do my own as well, the bigger the bike the bigger the tire the bigger the job.
The Thunderbird Commander is some work.
I have a manual tire changer I purchased form Harbor freight, took me two seasons to modify it to my liking.
Also have a Mojo Lever, nice piece of kit. and a balancer.
Last mount I used Ride On tire sealant in the tubeless Avons.
Three reasons, no balancing, tire puncture protection and cooler running longer tire life.
It' doesn't appear the tire life will be extended by the looks of the wear. However the balancing with the product was great.
Back2-2 likes this.
Red Devil
The Hornet is offline
post #17 of 37 (permalink) Old 11-16-2018, 03:49 PM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
Where did you purchase the MoJo lever. I tried to make one but had trouble getting a phenolic / nylon end for the remount to hold up to the leverage.
“Its all about motorbikes. Always has been, always will be”
Neil in AZ
Back2-2 is offline
post #18 of 37 (permalink) Old 11-16-2018, 04:07 PM Thread Starter
gbc
Main Motorcycle: Rocket 3
gbc's Avatar
Other Motorcycle: 2014 Moto Guzzi Calf.
Extra Motorcycle: 1999 Triumph Adventurer
Did the TBS today
Installed and balanced front and rear tires on my Thunderbird Sport today. No issues at all, other than some effort to break the beads during dismounting. Before attempting the Rocket 3 or Goose Touring, I am going to be looking at a bead breaker and maybe the Harbor Freight set up. Regardless, my spoons and balancer paid for themselves this afternoon.....
gbc is offline
post #19 of 37 (permalink) Old 11-16-2018, 04:38 PM
The Hornet's Avatar
I'm not sure you can do the Rocket tire change with the HF manual set up. That's a big ole low profile tire with a stiff bead.
Red Devil
post #20 of 37 (permalink) Old 11-16-2018, 04:41 PM
The Hornet's Avatar
Right here, got the mojo blocks as well and added to the harbor Freight changer. https://www.mojotiretools.com/mojoweb.htm
Back2-2 likes this.
Red Devil
Expierence with " Ride On sealant and balancer"? svdave Club Cafe' 41 09-13-2018 04:57 AM
Why You Should Consider A Sportier Front Tire On Your Motorcycle El Fenix Biker Hang-Out 21 01-12-2016 07:23 PM
how to change rear tube with rim locks. 2XS Classic, Vintage & Veteran 23 11-13-2015 08:21 PM
Tire mounting bead mounting trick sonicboom Air Cooled Twins Technical Talk 6 08-14-2015 10:05 AM
Beware new tyres! al1 Biker Hang-Out 78 05-19-2015 05:39 PM
