"Other" parts that fit our bikes - Page 19 - Triumph Forum: Triumph Rat Motorcycle Forums
 30Likes
post #181 of 189 (permalink) Old 10-18-2018, 10:38 AM
Main Motorcycle: Triumph Scrambler '15 EFI
Hugo7's Avatar
Originally Posted by DougAU View Post
I wonder if he doesnt mean the screws that hold the plastic side covers on, the reference to the "lucky coin" made my think that, might be wrong.
https://www.triumphestore.com/p/Triu.../T3335566.html from Hermy's.
@Hugo7 , you dont mention the year or model, from your profile I'm assuming a Scrambler and I just picked a random year of 2015
Cheers.
Yes, sorry the plastic side cover screws.
I think it's 900 twin EFI - 2015, but maybe a 2016 (I always forget).
@Forchetto - I was looking at those, but mainly toying with making my own from a m6 allen head bolt by cutting a m10 thread and screwing 'n gluing it into a m10 flanged hex socket nut. All as a mix of budget, looks and different removal options.
I figured a larger hex head would give something to grab onto.
Somewhere I have it in my head that it's a m6 bolt hole, but I can't see to find anything to confirm that.
Hugo7 is offline
post #182 of 189 (permalink) Old 10-18-2018, 03:02 PM
Main Motorcycle: 2014 Triumph Bonnie
Other Motorcycle: 1970 Bonnie
Originally Posted by Hugo7 View Post
Cheers.
That link I posted on my message is from Hermy's, you can view all your bike parts on their site, it is a M6 bolt that you need.
Click on this link, it will show you a diagram of your bike, look at part no.
https://www.triumphestore.com/a/Triu...65736-0-2.html
M6X20
You can find everything/every part for your bike, just click on the boxes that take you to the bike you have and the section/equipment for the bike and it'll have a diagram of those parts.
DougAU is online now
post #183 of 189 (permalink) Old 10-19-2018, 04:31 AM
Hugo7's Avatar
Amazing!
Thanks for that.
Now I just need to resolve the electrical gremlins.
Hugo7 is offline
post #184 of 189 (permalink) Old 10-28-2018, 09:00 AM
Main Motorcycle: 1068cc '05 Thruxton
H3CT1C's Avatar
Alternative sprockets
Few places have Triumph sprockets off the shelf, but Suzuki and Yamaha sprockets can be found anywhere - so this might get you out of a bind in the event of catastrophic failure on the road... Also, if you like to play about with gearing, want to try a 520 chain conversion, or just want cheaper sprockets than Triumph OEM parts...
From the JT Sprockets website:
The rear sprocket (43T) on our bikes is identical to e.g. the Suzuki GSX-R600 (2001-2010) and comes in sizes 40, 41, 42, 43, 44, 45, 47, 48 for 525 chains (stock) - and in 42, 43, 45 for 520 chains.
The front sprocket (18T) is almost identical to the Yamaha YZF R1 (1998-2017) - it's slightly thicker, so you'll need a few minutes on a lathe if you want the locking washer to fit... and comes in sizes 14, 15, 16, 17, 18 for 525 chains (stock) - and in 15, 16, 17 for 520 chains.
The very newest ('15-'17) 865 models also have 18T front sprocket for 520 chains and 42, 43, 45 for 520 chains fitted as stock.
Free Spirits offer an offset 19T front sprocket if you want to run wider rubber - but only for 525 chains.
The Sprocket Center offer 16, 17, 18, 19 size front sprockets for both 520 chains and OEM 525 chains, and for the rear have 40, 42, 43, 44, 45, 46, 47 for 520 chains and 41, 42, 43, 44, 45, 46, 47 for 520 chains. Hunting around for GSXR/R1 sprockets will probably turn up still more sizes...
Supersprox (USA and Europe) offer light "Stealth" rear sprockets for the GSXR in both 520 and 525 size, so perfect for our bikes. Unfortunately for those of us on "this" side of the pond, the European site isn't as comprehensive as the USA one - we're better off looking at the USA site and then armed with the relevant part numbers going back to the European site...
My engine has a small patch of vibration between 4,200-4,500 rpm - but by using The Gearing Commander I was able to "plan" my gearing to make this as unobtrusive as possible on Finnish roads (100kph in the countryside, 120kph on the motorway) - with a 19T front sprocket and 42T rear, the bars start to get a bit buzzy at 112kph but has totally cleared up by 125kph... Perfect! (If you don't mind driving a little over the limit...)
Tim
~'05 Thruxton~Sport Evolution 1100cc~FCR 39mm~813 cams~shim-under-bucket~+1.5mm valves~45mm headers~Ignitech CDI~m-Lock~m-Unit~Acewell CA85~F3 Frankenfork~Hagon Nitros~Pretech caliper~520 chain~wide 17" rims~sticky rubber~
H3CT1C is offline
post #185 of 189 (permalink) Old 01-16-2019, 08:49 PM
Main Motorcycle: My 07 Bonnie Black !!
Ozuzi's Avatar
Other Motorcycle: WR200R
Steering Dampers?
Hi Folks
Has anyone found a bargain steering damper? Others have mentioned ones that are no longer available or a million bucks.
Longer shocks have given my 2007 T100 a tank slapper.
Also, saddlebags without a frame or straps compressing the pillion seat.
Cheers
2007, Last of the carby Bonnies in Black
Airbox-ectomy
Thruxton length Ikon shocks & forks
Staintune pipes
CRG bar end mirrors
Ozuzi is offline
post #186 of 189 (permalink) Old 01-16-2019, 09:45 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
This damper
https://www.dimecitycycles.com/vinta...r-32-0082.html
With this mounting is reasonable
https://www.dimecitycycles.com/vinta...52-032115.html
I see you live in Australia so maybe not such a good deal
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is online now
post #187 of 189 (permalink) Old 03-05-2019, 11:19 AM
Chris Fletcher's Avatar
Originally Posted by Ozuzi View Post
Hi Folks
Cheers
bought mine from ebay a Chinese sight for around £12 for just the damper then made my own mounting brackets ,went on norman hyde triumph site and copied his mounting brackets.also TEC do one at a reasonable price
Chris Fletcher is offline
post #188 of 189 (permalink) Old 03-06-2019, 03:36 AM
Main Motorcycle: 05 Bonneville T100 carbed
Tiz147's Avatar
I would avoid the TEC one unless they’ve drastically improved. I got one and it was junk. I used to get a bit of wobble when I put road riders on. Changed the tyres and the wobble went.
Tiz147 is offline
post #189 of 189 (permalink) Old 04-17-2019, 04:53 AM
H3CT1C's Avatar
FRANKENSPARK!
Sick of Triumph pick-up coils failing every three years at £56 a pop, I've discovered a replacement part with similar specs for £30 from Electrex (who specialise in bike electrics) - and it works! It *does* require 'some user modification' (drill holes to 6mm, connect to OEM wiring - white to black, brown to red) but it produced a spark at the plug on the first attempt! Having to rely on Ducati parts for a spark may seem... how shall I say? Counter-intuitive? 😉 But these are quality parts, the majority of which are made in-house.
Tim
H3CT1C is offline
Combining my "seat heat" and "tune" threads here TheNomad Sprint Forum 10 06-02-2008 12:09 PM
Bikes with "faces" could be safer GixxerMeThis Biker Hang-Out 12 03-14-2008 11:53 PM
Possibly the only episode of "Super Bikes" ever worth watching Mattrat Biker Hang-Out 5 10-04-2007 02:27 PM
"BIKE" Magazine article of top 150 bikes ricster Sprint Forum 18 07-30-2007 10:07 AM
