Finally Fixed my Foot Pegs - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 10Likes
post #1 of 14 (permalink) Old 10-19-2019, 10:24 PM Thread Starter
Main Motorcycle: 2009 Bonneville
Flash Nick's Avatar
Other Motorcycle: Kawasaki Super Sherpa
Was never a big fan of the original footpegs, too big and chunky for my liking. On top of that, I needed feet like Krusty the Clown to reach the pedals. I found myself lifting my foot right off the footpeg to apply the brake.
I got some replacements from MC Motoparts. These fit perfectly and have the option of a 25mm or 40mm radial extension, which can be set at 15 degree increments. The original pegs have about a 25mm offset already, so I got the 40mm.
The brake pedal was too high and had no downward adjustment left, so I shortened the push-rod by 12mm and ran some extra thread on it. Beware if you do this that when you remove the circlip holding the push-rod into the master cylinder, the guts of the master cylinder want to fall out, so have something ready to hold the remainder in. Just when I was feeling pleased with myself I discovered that with downward adjustment the brake pedal hits the pedal spring anchor bracket, so having got this far I scalloped out the brake pedal to clear the bracket. One important discovery is that the hole in the brake pedal is about 1mm larger than the push rod clevis pin. Doesn't sound like much but equates to about 5mm of wasted travel at the pedal before anything happens. I have bushed this hole to make it size for size with the pin, and it's now much better.
The whole setup is now far better. I would have rated MC Motoparts a 10 out of 10 except that their email communication is terrible, waiting a week for a reply doesn't cut it. Too bad because the product quality is superb.
Picture below, you can also see where I scalloped the pedal.
CapitalSon and Bonnie59 like this.
I'll have you know I come from the best of convict stock.
Flash Nick is offline
post #2 of 14 (permalink) Old 10-19-2019, 10:47 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
While messing with the pegs, you should up-armour the peg mounting bracket as there are quite a few reports of the welded-head 5/16 full thread bolt shearing off while riding along. Not a fun thing at all. Easy fix is to remove bracket, bash out the welded bolt with a suitable sized socket supporting the bracket while waling with a BFH (Big F'ing Hammer). Then drill out the bracket hole to next size up (3/8?) and use a proper shanked bolt with a nylock nut and some washers. The shank will now take all the loading, giving much more meat to the load.
BonnieBlack and BonnieJon like this.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
post #3 of 14 (permalink) Old 10-22-2019, 10:42 AM
Main Motorcycle: 2013 Rocket 3 Touring
norton74's Avatar
Other Motorcycle: 2013 Torphy SE
Extra Motorcycle: 2012 Bonneville T100
Questionable advice. This joint is a tension joint where bending and shear loads are born by the contact surfaces of the joint due to the clamping force of a properly torqued bolt. The bolt should not “ take all the loading”. Better to check the bolt torque to be sure it is within spec.
Bonnie59 likes this.
"Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
norton74 is offline
post #4 of 14 (permalink) Old 10-22-2019, 01:13 PM
Main Motorcycle: Bonneville 790
Bonnie59's Avatar
Other Motorcycle: Harley MT350 thing ..
Very nice looking pegs... it’s on my hit list as well... nice job!
Sent from my iPhone using Tapatalk
Bonnie59 is offline
post #5 of 14 (permalink) Old 10-22-2019, 04:29 PM
Tornado99's Avatar
That 5/16" full threaded stock bolt has failed in may reported cases, with or without being at the spec torque. And what about the second failure mode of the stock pegs, as in the castings letting go? Are they also somehow the owners fault?
Ridgy likes this.
post #6 of 14 (permalink) Old 10-22-2019, 08:47 PM
norton74's Avatar
How many failures? How do you know the torque was or was not at spec?
What about the casting?
Is it possible that the foot peg was over loaded due to accident, tip over, or the foot peg hit an immovable object like a curb?
Owner’ fault? Maybe, maybe not.
In any case, there are thousands of Bonneville out there that haven’t had a foot peg break. Implying a design flaw based on sketchy anecdotes is unfair and premature.
norton74 is offline
post #7 of 14 (permalink) Old 10-22-2019, 11:03 PM Thread Starter
Flash Nick's Avatar
I've read most of the posts on Bonneville footpeg failures and there does seem to be an inordinate number of reports of both bolt and casting failures, albeit a small percentage of the population. Most of these are reported as material failure in normal operation.
Anyway, I've inspected and torqued my bolts and decided not to go any further. As this topic was not the reason I started the post, let's leave it at that.
Cheers.
Tornado99 likes this.
post #8 of 14 (permalink) Old 10-25-2019, 02:01 AM
norton74's Avatar
Cheers.
I ran a quick search of the forum and found six threads about Bonneville foot peg failures. In two of these the OPs stated that the bike had been down while riding and the foot peg failed later. In one thread the OP stated that he bought the bike with the foot peg already broken.
My question is: Is six problematic reports an inordinate number?
norton74 is offline
post #9 of 14 (permalink) Old 10-25-2019, 02:35 PM
Supernova
Forchetto's Avatar
Forchetto is offline
post #10 of 14 (permalink) Old 10-29-2019, 11:19 AM
norton74's Avatar
Originally Posted by Forchetto View Post
I went through all of the threads that were in your references. Lots more failures than I believed. Below is a list of the posters with a summary of what was in their posts that applied to their foot peg failure. I might have missed a few; but, I listed every instance that I found. Note that many of the posters acknowledged that they had hit a hard object, tipped their bikes over, or had dropped the bike while in motion. Also, those posts that included photos showed fatigue on the fracture surface showing that a crack nucleated and then grew over time with usage. There were a relatively small number of fractures of the aluminum part of the foot peg assembly.
There were also some posts when the posters (Forchetto among them) checked the tightness of their foot peg bolts and found them loose or the torque was low.
Columbo: Witnessed foot peg failure due to bolt fracture
Oddsteven: left foot peg failed acknowledged the bike was dropped several weeks previous
JxnBonnie: foot peg failed
FlyingCelt: Foot peg bolt failed
Thump Bonnie!: Right foot pegbolt failed
gt1jimmie: Foot peg casting broke after hitting solid object
Durbud: Found his bike lying on its side with broken foot peg (probably bumped by a car)
MES: Foot peg broke. Acknowledged that the bolt may have been loose
WaltZ: Foot peg broke. Acknowledged bolt was loose
greyplague: Foot peg broke after bike went down
SpaceCoastRat: Foot peg casting broke when bike tipped over
Lake: Foot peg broke while riding. Photo shows fracture surface that the surface shows evidence of fatigue failure with only about 40% of cross section intact at time of failure.
Bonnie25: Left foot peg broke
Viperject: Right foot peg broke
Chicagobob: Found his foot peg loose. No breakage
Tornado99: Reports foot peg casting broke on his buddy’s T100. Noted that buddy was second owner of the bike.
Tunabreath: Foot peg bolt broke
MeanStreaker: Foot peg broke
Redstickboy: Foot peg bolt broke on cousin’s bike
dr_kedaver: Left foot peg bolt broke. Photos show fracture surface with what appears to be a fatigue fracture with only 10% of cross section intact at the time of final total fracture
extractable: Left foot peg bolt broke
nimravus01: Broke right foot peg bolt. Acknowledged that foot pegs were used replacements
Cruzin1a: Both foot pegs loose when checked
Snook: Foot peg broke after running into a post.
Ready to Ride: Found one foot peg loose after hitting something.
Irish Guy: Found foot peg casting cracked
WaltZ: Found loose right foot peg. When torqued bolt fractured showing only 1/3 bolt cross section intact
Sasper: Broke foot peg after running into a curb
Untold: Foot peg snapped of when he bumped the bike in his garage
Steve Betts: Foot peg broke after tip over. He noticed his wife’s bike had crack in the cast portion
Forchetto: Reported finding both foot peg bolts loose (actually, torque was low)
DinoZ: Broke foot peg due to tip over
Squidsix: Broke left foot peg at clevis joint
Padre: Foot peg broke “Blasted white metal”
BonnieBlack: Foot peg broke. Great close up photos showing fracture surface. Fracture showed evidence of fatigue and corrosion. At failure, only about 10% of cross section was not already fractured due to fatigue.
Kj6itk: Left foot peg bolt broke
Tecpatl4: Broke left foot peg
Blueback: Reported that his left foot peg was torqued low (10-12 Nm vs recommended 27 Nm). Right foot peg was torqued to 20 Nm
Bonnienyc11: Right foot peg broke
Traveler501: Right foot peg torqued to only 8 ft-lb (10.9 Nm)
RICW: Foot peg bolt broke while being torqued to only 20 ft lb (27.1 Nm)
pgreer: Right foot peg bolt broke
nygumbo: Right foot peg bolt broke. Noted that half of fracture surface was rusty (fatigue failure over time)
Reported second foot peg bolt broke at later date.
JesseD: Foot peg broke.
Ocka: Left foot peg broke
DavidR8: Bike tipped over bending the left U-shaped foot peg bracket. Third owner of the bike. Foot peg bolt broke. Photo showed evidence of fatigue failure
UllyssesCale: Multiple right side foot peg breaks due to tip overs while bike is parked
Dicimus: Broke left foot peg bolt
rmglad55: Broke foot peg
tdnathens: Both foot peg bolts found to be loose
UrbanizedOkie: Left foot peg bolt broke
Not of the TriumphRat forum, a blog reported a broken foot peg bolt
dboone: Cast aluminum part of foot peg assembly broke
extractable: Left side foot peg bolt broke
richm: Right foot peg cast aluminum part broke when bike tipped over in garage
bjh1112: Foot peg broke while riding
bonza: Observed right foot peg bolt failure on pal’s. Noted that pal’s bike had been dropped at low speed previously.
Forchetto likes this.
norton74 is offline
