Poor staring when hot. 2011 efi Bonneville - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 3Likes
post #1 of 13 (permalink) Old 10-19-2019, 08:36 AM Thread Starter
Main Motorcycle: Bonneville 2011
Other Motorcycle: Le Velocette 1951
Hi Folks
Recently the bike has failed to start when hot. Leave it for a cool down period and it's fine.
When running there is no indications of a problem.
Currently thinking coil breakdown.
Idea's please before I commit to purchasing a coil.
Whilst I sort this issue I am only stopping where there is a cafe that serves good coffee, well that's my excuse.
Philip
Blyth
Northumberland
England
Tornadof3 is offline
post #2 of 13 (permalink) Old 10-19-2019, 09:14 AM
Supernova
Forchetto's Avatar
Assuming you're using the same starting procedure as when it started fine, stuff like a closed throttle, a little "choke" when partly warm (as per owners manual), etc, the main suspect could be the old pick-up coil or CPS (crank position sensor).
These tend to give trouble when hot and detection is not easy, as it involves measuring its resistance and Sod's Law says that by the time you find the cunningly hidden connector, got your multimeter out, etc the thing has cooled down and measures correctly.
It ought to flag up a fault code and light the engine check light, but it often doesn't.
The ignition coil on EFI models is very durable and reliable and seldom gives trouble, by the way. I say this because a replacement costs 113 so changing it is not a decision to be taken lightly.
Forchetto is offline
post #3 of 13 (permalink) Old 10-19-2019, 11:12 AM
Ripper's Avatar
Fully agree. The way to test the CPS is remove it completely from the bike when cold, measure the coil resistance, then dump it into a jug of boiling water for a couple of minutes. Take another resistance reading and if there's a large difference between the two readings, the coil is most likely duff. The CPS is notorious for this specific problem.
To be fair, the cost of a new gasket, oil leakage (that's if you have no way of doing this with the bike lying on its side) and sheer pain in the backside to do, is prohibitive against just replacing the CPS to eliminate it. Compared to the rest of the ignition system the CPS is the cheapest item to replace, so its worth taking that gamble before you start looking at replacing ignition coils. Whilst removing the CPS I would also check the condition of its wiring and connector.
One other word of caution (or would it be a tip?) is the rubber grommet which the CPS wires run through, in the triangular engine case. This will undoubtedly seep engine oil after the job is done, unless you use silicone sealant (I use the tar-like roof/gutter sealant) to seal the rubber into the engine case.
Forchetto likes this.
Arrow 2-2, Snorkel/Baffle removed, DNA filter, TTP Tune#3, TEC piggy back gas shocks, 5.5" risers with drag bars, LED Lighting, Hazards, Oberon Footpegs, Burton Seat, D9 bracketry, Hands Free Keyless ignition.
Ripper is offline
post #4 of 13 (permalink) Old 10-19-2019, 05:33 PM
Main Motorcycle: 2010t100 67 ttspecial rep
mike-tt special's Avatar
Other Motorcycle: 91 zxr750(805cc)
As you say that the bike runs fine once started even when it is hot i doubt it is the CPS...
As you say it starts fine when cold and it is just a hot starting issue my investigations would centre around the various temp sensors that feed data to the ECU.
Does the bike have pod air filters? And if so, where is the iat sensor positioned?
Is the barometric air pressure sensor clear and working
Is the oil temp sensor working?
Etc
mike-tt special is offline
post #5 of 13 (permalink) Old 10-21-2019, 04:45 AM Thread Starter
Good Morning Gentlemen
First. Thank you for your help, its greatfully received.
The bike started with the problem last week on a ride out, luckily at a cafe stop so it cooled down whilst we had our drinks.
The bike has no intake mods other than a new filter last week?
The air injection system was removed one year ago, a good mod.
Starting system, fully retard ignition, tickle carb, index finger on valve lifter oops wrong bike and showing my age. The bike starts normally without any help, not even choke. Its rare to need to put the choke on?
I will order a CPS tomorrow once the Triumph dealer is open, monday is a closed day.
Any suggestion on how to test other sensors. I am competent with a multi meter.
Philip
post #6 of 13 (permalink) Old 10-21-2019, 06:04 AM
Main Motorcycle: 2008 Bonnie Black Special
PieMan's Avatar
That's your problem right there, you should need the fast idle (choke) from cold, if not then your mixture is far too rich.
On a correctly jetted (oops, wrong bike ) EFI Triumph twin you should need fast idle when cold for a couple of minutes and then when hot starting, just for a couple of seconds to ensure a good idle.
If your old filter was really dirty, the new filter would allow more air through to give a little leaner mixture.
Mike (UK)
https://www.triumphtwinpower.com
PieMan is offline
post #7 of 13 (permalink) Old 10-21-2019, 03:36 PM Thread Starter
Hi Pie Man
All noted. Starting from cold is not a problem, it was hot starting that was the issue.
No, the old filter was clean, it was time changed that's all
Thanks for the inputs.
Now struggling to find the route of the CPS cable.
Philip
post #8 of 13 (permalink) Old 10-21-2019, 04:37 PM
Supernova
Forchetto's Avatar
The connector is cunningly hidden between the top of the airbox and the frame. To get at it you might have to remove battery and ECU, loosen airbox fixing bolts and airfilter to throttle body clamps and pull the airbox down and back. I've extracted mine and tied it to the fusebox for easy access for fault-finding, like this:
post #9 of 13 (permalink) Old 10-21-2019, 10:20 PM
Main Motorcycle: 2013 Bonneville T100
CapitalSon's Avatar
Other Motorcycle: 1955 AJS 350 (ex)
Are you pulling out the "choke" to the first position EVERY time, hot or cold - that's what the manual says.
2013 T100 - Cranberry Red, New England White, Triumph QR Screen, Racetech Shocks-F, YSS Shocks-R, Biltwell Grips, Moto bars, RoxSpeed Risers, GIPro DS, MC/NightRiderz LED Tail/Head light, Scotolier, Michelin Anakee III's, TORs; No SAI, ECS, Baffle
CapitalSon is offline
post #10 of 13 (permalink) Old 10-22-2019, 04:27 PM Thread Starter
Hi Folk.
To all who have advised on the starting technique my thanks, but it's not that...
To Forchetto, my humble thanks. Your information has been invaluable. The plug for the cps was near where you said but was a real *******, they had wrapped the cable around a large loom and so I cut off the plug to take it out. No worries being an ex electrical engineer. New sensor should arrive wednesday and will re route as you suggested. The worst bit was that in assembly they had tie wrapped the cables together as the come up from beneath the gear box, that took twenty minutes of struggle to cut off. I will make a reply in a few days once the cps is fitted engine is running, hmmm hopefully.
Out of interest I would like to know if the temp sesnors etc can be tested?
God Bless Philip
