Baffling electrical problem continues -- HELP! - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
post #1 of 8 (permalink) Old 10-13-2019, 08:10 PM Thread Starter
Main Motorcycle: 2006 Triumph Scrambler
Other Motorcycle: 81 Honda CB900C +sidecar
Extra Motorcycle: 1977 Yamaha 750
I am posting an update on a problem I am having with my 2006 Scrambler. Hopefully someone who did not see the original post will see this and have some ideas.
When I turn my ignition switch toward the "on" position, the oil and neutral flash momentarily but then both go out when the key reaches the actual "on" position. I repeat, BOTH THE OIL AND NEUTRAL LIGHTS MOMENTARILY FLASH AS THE KEY IS BEING MOVED TO THE “ON” POSITION but has not reached the actual "on" position. Once the "on" position is reached, all lights go out and there is no power to anything.
Based on my own ideas and several suggestions from other users of this site, I have done the following:
--Battery and fuses are all good.
--I checked and cleaned the contacts in the main ignition switch. No change.
--I installed a new main ignition switch. No change.
--I disconnected and “jumped” the kickstand safety switch. It is working correctly. No change.
--I installed a new starter relay cross-over. No change.
--I installed new coils. No change.
I am having a hard time imagining what other component failure would kill the power completely and shut off the oil and neutral lights when ignition key is in the ON position.
Thanks for any and all suggestions.
Jack DG is offline
post #2 of 8 (permalink) Old 10-13-2019, 08:41 PM
Main Motorcycle: Bonneville 790
Bonnie59's Avatar
Other Motorcycle: Harley MT350 thing ..
Hi there
It sounds like the ignition switch is bad mate...
Sorry just read that you put a new ignition on it... well it still sounds like one so check your earths and connections, also get your meter along the feeds and check resistance ... good luck mate!
Sent from my iPhone using Tapatalk
Bonnie59 is offline
post #3 of 8 (permalink) Old 10-13-2019, 11:35 PM
Main Motorcycle: Thruxton
plodalong's Avatar
Other Motorcycle: 08 Bonneville efi
Possibly a bad main power lead or earth connection. Try running a jumper cable fron the negative battery terminal to a good earth like one of the motor bolts and see if it makes a difference.
07 thrux,Ram air ark, TPUSA manifolds Predator pros, 40mm Mikuni flatslides, ttp +3 ignitor,yss emulators,hp springs, Bitubo shocks,pingle steering damper,D9 layflat,2" rise clipons,shorai battery,Changes daily.
plodalong is offline
post #4 of 8 (permalink) Old 10-14-2019, 04:03 AM
R0B
Main Motorcycle: Modified Bonnie
Other Motorcycle: another Bonnie
Extra Motorcycle: Selling it.........
Clean the contacts on the ignition switch. I had a non starting problem once, and this was the cure.............typically having been through everything.
Rob
R0B is offline
post #5 of 8 (permalink) Old 10-14-2019, 05:53 AM
Main Motorcycle: Daytona 675R
CafRacer's Avatar
Other Motorcycle: Thruxton R
Hi
Firstly do you have a multimeter or test lamp you can use and a wiring diagram for your bike?
You say the battery is good and all fuses are ok so I assume when you have the ignition in the on position you still have 12 volts at the battery?
You need to start tracing forward from the battery through the fuse box and ignition switch to see where you're losing the power.
Have you checked all Earth's to the frame?
come back when you're ready to test and I can give you some pointers if you like.
CafRacer is offline
post #6 of 8 (permalink) Old 10-15-2019, 01:34 AM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
Faulty ignition switch. ...J.D.
Wire-Wheels is offline
post #7 of 8 (permalink) Old 10-16-2019, 02:47 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
As you've replaced or tried a new ign switch, we need to look elsewhere. These bikes have a poor metal crimp on the main loom running near the steering head. Hard to assess as it's buried beneath layers of wrapping. Quite a few reports of strange electrical issues have been traced to that crimp....wires get stress cracked and either short or go open circuit.
I think one repair was to fill the crimp with solder??
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is online now
post #8 of 8 (permalink) Old 10-16-2019, 03:00 PM
Tornado99's Avatar
Here's one thread dealing with the crimped joint failure:
https://www.triumphrat.net/air-coole...ht-bucket.html
Not sure this was a thing on older models...but definitely on the later CanBus bikes.
