Stage 1 Dynojet - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 7Likes
post #11 of 22 (permalink) Old 10-05-2019, 09:31 AM
Main Motorcycle: Bonneville T100. 2006
Other Motorcycle: Wifes car
Extra Motorcycle: Bus
Hi Pieman
My typo error that's 128 .
Bosch LSU 4.9 sensor and Zeitronix zt-3 meter and gauge. As I understand it, doesn't need calibrating.
Jon
2006 Bonneville T100. Arrows 2-2. Airbox Baffle removed. K+N filter. TTP Bellmouth. TTP BlueFlame coils. TTP jetting kit. Crank case breather moved. 120 mains. 40 pilots. 3 Turns idle jet.
Jonnys Bonnie is offline
post #12 of 22 (permalink) Old 10-05-2019, 03:24 PM Thread Starter
Main Motorcycle: Bonneville 790
Bonnie59's Avatar
Other Motorcycle: Harley MT350 thing ..
Originally Posted by PieMan View Post
Jonny, are you sure that your AFR gauge was calibrated correctly? 120 mains should be way too lean for your mods.
Hey Pieman
So Iím fitting Kit 4 to my 790 next weekend, there is some confused direction with the kit. Can you give some advice as to what to try first?
Sent from my iPhone using Tapatalk
Bonnie59 is offline
post #13 of 22 (permalink) Old 10-07-2019, 05:53 AM
Main Motorcycle: 2008 Bonnie Black Special
PieMan's Avatar
Originally Posted by Jonnys Bonnie View Post
Hi Pieman
Jon
Hi Jon, as far as I know, all Bosch LSU 4.9 sensors need calibrating in free air before use and every so often to ensure you get accurate results. Even 128's seem lean, but to be fair using the K&N air filter will restrict the jet size required.
Mike (UK)
https://www.triumphtwinpower.com
PieMan is offline
post #14 of 22 (permalink) Old 10-07-2019, 05:56 AM
PieMan's Avatar
Originally Posted by Bonnie59 View Post
Hey Pieman
Hi Bonnie59,
what's your setup? As in exhaust and induction mods?
Mike (UK)
PieMan is offline
post #15 of 22 (permalink) Old 10-07-2019, 06:52 AM Thread Starter
Bonnie59's Avatar
Stage 1 Dynojet
Hi Bonnie59,
Ok mate, Iíve removed the snorkel, fitted a DNA filter and breathe cover, SAI blanked off and a Tec tracker 2 into 1. I have your no 4 kit ready to fit.. I was also considering removing the baffle from the air box but wonít if it will mess up the fuelling...
Bonnie59 is offline
post #16 of 22 (permalink) Old 10-08-2019, 07:41 AM
PieMan's Avatar
With Jetting Kit 4 it is essential to remove the internal airbox baffle or your engine will run very rich. As you have the DNA Performance air filter and the Breathe with the TEC Tracker system, I would suggest starting with the larger of the two sets of main jets.
Bonnie59 likes this.
Mike (UK)
PieMan is offline
post #17 of 22 (permalink) Old 10-08-2019, 06:20 PM Thread Starter
Bonnie59's Avatar
Righto; Iíll get them in on Saturday and rip the baffle out as I do it.
This is what I mean by confusing because I thought kit no 4 was for baffle in, so much appreciated mate!
Iíll let you know how it goes.
Iíve not taken these carbs out before so Haynes will have to tell me how. I was going to up jet with the carbs fitted but a previous keeper had chewed up the left hand float bowl screws so they need to come out...
Thanks again and Iíll keep you posted!
Bonnie59 is offline
post #18 of 22 (permalink) Old 10-09-2019, 04:44 PM
Hi Pieman,
I contacted the supplier of my AFR and they confirmed it does not need to be calibrated.
I did change to the Uni from K&N as you advised, and as I have noted (as have others) there is no difference on the gauge reading.
Also plugs are a nice biscuit brown colour, so I'm assuming all is ok.
When I have saved up enough I'll put it on the Dyno.
Jon
post #19 of 22 (permalink) Old 10-12-2019, 10:46 AM Thread Starter
Bonnie59's Avatar
Stage 1 Dynojet
Hey Pieman
So Iíve stuck your 130 main jets in (from 115) and one shim under the needles... I found a loose shim in the left hand needle holder and the right was shimmed; a previous keeper had also ruined the screw heads when attempting to jet the bike I think.. Iíve replaced all fasteners with your stainless kit (very pretty)..
I know you said to remove the baffle but I think you may be muddled with the other kit for my set up (see photo)..
The bike really is sweet now, pulling hard to 90 and just pops a little on the over run (I quite like it..). If you say remove the baffle I will but as I say I think there may be some confusion with the other kit..
Bonnie59 is offline
post #20 of 22 (permalink) Old 10-15-2019, 10:59 AM
PieMan's Avatar
Bonnie59, you are absolutely correct, with kit 4 you leave the internal airbox baffle in place. Please forgive my old and knackered brain.
Regards
Mike (UK)
PieMan is offline
