Clanking metal sound shifting into 1st. - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 3Likes
post #1 of 14 (permalink) Old 09-16-2019, 08:08 PM Thread Starter
Main Motorcycle: 2002 Bonneville T100
RaceDweeb's Avatar
Other Motorcycle: Tri, Ducati, HD, Gilera
Extra Motorcycle: "The Knucklution"
I have a 2002 T100 that makes a loud metallic-sounding clanking sound when I shift into 1st gear from neutral. It gets better as the bike warms-up. Oil type & level is correct. Any ideas as to the source?
/M
ENGINEERED TO THRILL
RaceDweeb is offline
post #2 of 14 (permalink) Old 09-16-2019, 09:41 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
Are you sure you'r not talking about the Harley? If not it could be too high idle, clutch adjustment(too much free play) or one week or broken clutch spring.
rweb is online now
post #3 of 14 (permalink) Old 09-16-2019, 11:33 PM Thread Starter
RaceDweeb's Avatar
Idle is bang-on @ 1100. Free play adjusted properly and there is a relatively fresh set of Barnett green springs installed. This sounds like metal plate being banged on and ringing. My other Bonnie's (and Harley) do not make such a noise.
/M
post #4 of 14 (permalink) Old 09-17-2019, 03:48 AM
Main Motorcycle: Thruxton
plodalong's Avatar
Other Motorcycle: 08 Bonneville efi
front sprocket loose?
07 thrux,Ram air ark, TPUSA manifolds Predator pros, 40mm Mikuni flatslides, ttp +3 ignitor,yss emulators,hp springs, Bitubo shocks,pingle steering damper,D9 layflat,2" rise clipons,shorai battery,Changes daily.
plodalong is offline
post #5 of 14 (permalink) Old 09-17-2019, 03:52 AM
Main Motorcycle: 2007 Bonnie T100
bonza's Avatar
Other Motorcycle: Jeep Wrangler
/M
mine does the same when it's very cold.
as the engine is cold, of course the oil too is cold and much thicker than when at normal operating temps. this allows the clutch plates to grab each other and slowly spin around thus creating the "clunk" when going from neutral to first gear. sometimes you can feel it want to lurch forward. if you have a centre stand and try it you will see the wheel spin even when the clutch is pulled in
even though we use multigrade engine oils, it is still thicker at cold temps and thins out at normal temps. the change in viscosity is simply not as great if it were a mono oil
personally, I like the clunk. sounds tuff
2007 Tuxedo T100.
Dom Tourers, TTP breathe, DNA filter,baffle gone, 40/140/1 shim 3 turns, TTP igniter tune, Hagon Nitros, Thruxton Bars, Halcyon bar end mirrors, Pingel fuel valve, Monza gas cap, Burton seat, Avon Roadriders
bonza is offline
post #6 of 14 (permalink) Old 09-17-2019, 04:08 AM
Main Motorcycle: 2010t100 67 ttspecial rep
mike-tt special's Avatar
Other Motorcycle: 91 zxr750(805cc)
Also check the cush drive rubber pads in the rear wheel for slop, and the bearing in the sprocket carrier for wear
Hedgepig likes this.
mike-tt special is offline
post #7 of 14 (permalink) Old 09-17-2019, 10:19 AM
Main Motorcycle: ThruxtonR,
pmorritt's Avatar
Other Motorcycle: BMWR1100RT
They all do that. Cold, clunk, warm not so much. Normal.
Masquerading every day as a normal person is exhausting.
pmorritt is online now
post #8 of 14 (permalink) Old 09-17-2019, 02:59 PM
Try backing the idle down to 950 to 1000 RPM. Just for fun.
rweb is online now
post #9 of 14 (permalink) Old 09-17-2019, 07:25 PM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
I have a 2002 T100 that makes a loud metallic-sounding clanking sound when I shift into 1st gear from neutral. It gets better as the bike warms-up. Oil type & level is correct. Any ideas as to the source?/M
If this only occurs at cold start up, let the bike warm up a little longer. I let mine warm up for about 1 minute, then there is only a slight clunk.
Ride safe,
Quentin
wenzel850 is online now
post #10 of 14 (permalink) Old 09-17-2019, 07:30 PM
Main Motorcycle: 2012 T100 Black
tlchris's Avatar
Other Motorcycle: KTM 250 XCF
my 2012 t100 also do that, i think it is the chain knocking on the chainguard, i might have some links in my chain that are seized , i will replace it next spring and see if it fix it.
tlchris is offline
