wiring harness - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 10-05-2008, 03:09 PM Thread Starter
Main Motorcycle: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
wiring harness
I have an 07 speedmaster dealer put in a new wiring harness but its not the same as the one they took out it has another safety device on it. With the kick stand down you can't rev it up its like you hit the rev limiter since then the charging system doesn't work. any Ideals
toys for big boys
wildchild is offline
post #2 of 7 (permalink) Old 10-05-2008, 05:38 PM
Legend
That's just odd. Something isn't right in your story, or your bike.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT "Thruxton" needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #3 of 7 (permalink) Old 10-05-2008, 08:07 PM
What occurred with your 07 bike to require a wiring harness? Did the shop discuss the particulars of this different harness with you and, as importantly, provide you with a corrected schematic for your bike? Your descriptions of the bike being unable to rev up with the kickstand down does not make operational sense; neither does any situation where the engine would be running with the charging system inoperative - either of theise by themselves indicate an error. I agree with Balto that the request for ideas requires better information.
SPARKSS is offline
post #4 of 7 (permalink) Old 10-05-2008, 10:08 PM
Supernova
Main Motorcycle: 2012 Tiger 800XC
Motorcyclist
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
That's wierd - I don't think that's a safety feature - I think that is the result of some problem. Maybe linked to the charging system not working. The charging system fault may be related to whatever caused the need for the wiring harness to be replaced - but I am at a loss as to what to suggest I'm afraid.
Well, everything seems to be in order then.
propforward is offline
post #5 of 7 (permalink) Old 10-05-2008, 10:23 PM
any Ideals
Wouldn't the best idea be to ask the dealer who did the work?
'08 America Blue/White; Custom Headlamps, Custom Lowers, Clearview 20", Long TORS
Lazyrider is offline
post #6 of 7 (permalink) Old 10-06-2008, 10:11 PM Thread Starter
wildchild's Avatar
OK they replaced the harness because every time i turn on the right turn blinker the fuss would blow. Now they told me they found a bad spot in the harness where it Y off to the key switch. Then when I picked the bike up I started it and let it warm up for a few minutes then turn the throttle a little bit and it sounded like it was hitting the rev limiter they came out and sad thats goofy must be some new thing they came out with for 09. The part number was different but the old part number crossed over to the part number on the new harness.
toys for big boys
post #7 of 7 (permalink) Old 10-07-2008, 02:39 PM
Main Motorcycle: '03 Speedmaster
Ganson's Avatar
Other Motorcycle: '99 Triumph Tiger
Send a message via AIM to Ganson Send a message via Skype™ to Ganson
Unless there was some sort of recall on the original harness, the dealer should have installed an identical one. There is no good reason for them to install a different (newer/older/modified) wiring harness on a fairly new bike, especially one where the correct parts can easily be ordered.
Garrick
I'm not lost, I'm exploring. Columbus didn't have a clue in hell where he was either!
Garrick.co
Ganson is online now
Wiring Harness Help. cbm206 Classic, Vintage & Veteran 3 09-26-2008 05:45 PM
I Need Wiring Harness Help JEB Air Cooled Twins Talk 12 03-05-2007 10:01 AM
Wiring Harness tuffy22 T3 Sport / Touring Forum 3 09-05-2006 05:17 AM
Wiring harness RacingGreen T3 Sport / Touring Forum 6 01-11-2006 09:50 AM
wiring harness quagmire Classic, Vintage & Veteran 2 10-08-2005 09:56 PM
