2015 T100 Oil and Filter recommendation - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 22Likes
post #1 of 20 (permalink) Unread 09-10-2019, 03:24 PM Thread Starter
Main Motorcycle: Triumph Bonneville T100 B
Hey folks,
Please recommend the best oil and filter for my 2015 Bonneville T100 Black!
Thanks in advance!
mattbonne is offline
post #2 of 20 (permalink) Unread 09-10-2019, 03:29 PM
Newbie
Main Motorcycle: 2014 Triumph T100
Other Motorcycle: 2006 Triumph T100
Extra Motorcycle: 1979 Triumph T140D
I personally use K&N oil filter with Motul 5100 engine oil with great success.
mattbonne likes this.
elbaracing is offline
post #3 of 20 (permalink) Unread 09-10-2019, 03:36 PM
Main Motorcycle: 2015 Triumph Thruxton 900
AusSimon's Avatar
Any thing that is NOT K & N. There are some serious and ongoing issues with their oil filters, the bolt welds come undone dropping your oil out all over your rear tire (dangerous) and if you don't notice in time sized motor.
I was a long time K & N fan, and am annoyed that I had the drain/replace my oil, just to get their ****ty filter off.
I replaced it with a HifloFiltro.
I dont think there is a huge difference in oils. Just as long as you have one made for motorcycles (they are made different for the wet clutch).
As long as its synthetic and probably 10w40 your good to go. The motul 5100 mentioned above is popular.
BonnieJon and mattbonne like this.
2015 Triumph Thruxton (British Racing Green)
Currently Addicted To Changing Just About Everything On It, For No Apparent Reason.
AusSimon is offline
post #4 of 20 (permalink) Unread 09-10-2019, 03:37 PM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
BonnieBlack is offline
post #5 of 20 (permalink) Unread 09-10-2019, 04:35 PM
Originally Posted by mattbonne View Post
Hey folks,
Thanks in advance!
NO K&N... problems with oil leaks and a recall.
Mobil One 4T 10W40 Synthetic @ Walmart for $9.97 a quart.
Best bang for the buck in a HIGH quality oil filter is a MAHLE OC575
Amazon sells them for $8.08. Buy a few.
justalurker is offline
post #6 of 20 (permalink) Unread 09-10-2019, 05:04 PM
I ditched the K&Ns on my bikes after one started leaking at the nut. Better safe than sorry. I get Mahle 575 filters from Rock Auto for about five bucks each. My Porsche snob friends swear by them, so they must be good, right?
Lone Commuter of the Apocalypse
2012 Bonneville T100
2013 Honda CB1100
Gone in 60 is offline
post #7 of 20 (permalink) Unread 09-10-2019, 06:30 PM Thread Starter
Smile Well noted, huge thanks!
Thanks so much for your recommendations, guys!
Guess my bike should be fine as long as she stays away from K&N filters.
Cheers!
post #8 of 20 (permalink) Unread 09-10-2019, 07:25 PM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
I use Mobil 1 V-Twin 20w-50 and now a Mobil 1 108 filter. Been using Mobil 1 V-Twin for 14 yrs and 2 different T100's without any problems.
BonnieBlack and mattbonne like this.
Ride safe,
Quentin
wenzel850 is offline
post #9 of 20 (permalink) Unread 09-10-2019, 08:02 PM
Main Motorcycle: 2013 Hinckley Bonnie T100
jhancock's Avatar
I thought the same folks who make the HiFlo filter make the K&N filter? Does the HiFlo have a nut welded to the bottom?
Jeff Hancock
Richmond, VA, USA
jhancock is offline
post #10 of 20 (permalink) Unread 09-10-2019, 08:53 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
The welded nut on such filters is only meant to be for removal, not installing the filters. IMHO it is also serves no useful purpose as there are many different types of filter wrenches available that can do the removal job just fine. We've had multiple reports on these forums of the K&N 204 welded nut failing whether or not it was used for installation. Doing a Goggle for these failures shows same failures happening to back before 2010 and many different bikes/cars.
Forchetto and mattbonne like this.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
