Horror- dropped a piece down the oil tube - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 21Likes
  • 3 Post By BonnieBlack
  • 2 Post By Gone in 60
  • 13 Post By Gone in 60
  • 3 Post By BasilM
post #1 of 9 (permalink) Old 08-13-2019, 08:04 PM Thread Starter
Doing a valve adjustment and didn’t notice one of the camshaft cap hollow alignment dowels was in the rag I was using to cover the holes. I was adjusting the rags and the dowel popped down the chrome oil tube.
I’ve gone at it with a magnet and a claw tool. Also tried flushing it out by draining the oil and funneling it down the oil hole.
Might try a vacuum necked down to fit the oil hole.
Wondering what the next move is. Pull the sump pan? If so, looks like the lower frame and exhaust need to come out too? Ugh.
Lone Commuter of the Apocalypse
2012 Bonneville T100
2013 Honda CB1100
Gone in 60 is offline
post #2 of 9 (permalink) Old 08-13-2019, 08:24 PM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
Sucks man. At times like this, I think of myself. Takes lots of pictures, let us know what happens!
Something like this may help, just don't let any of it's attachments join the dowel in the bowels of the motor: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Seriously, hope this works out quickly for you man. Move slowly, don't panic, just work it.
LapinAgile, yrunvs and Back2-2 like this.
BonnieBlack is offline
post #3 of 9 (permalink) Old 08-14-2019, 06:34 PM Thread Starter
I read everyone else's posts about doing this, including someone who did exactly as I did - drop a dowel into the same hole. I have some time to kill as I'll be waiting for my new shims and other little parts to arrive. This would have added insult to injury - one of my telescoping magnet tools came apart right over the head, and two little pieces that hold the thing together popped out and fell on either side of the hole.
I made a flexible tool by taking the magnet off of a telescoping stick and attaching it very securely to some 1/4" vinyl fuel hose. This can snake around curves, and might do a better job.
So, thinking that the dowel fell past the balancer shaft, it would have landed somewhere in front of or below the timing chain, or bounced to one side and ended up in the sump. I'm looking at all of the pictures I can of the "landing area" to see what the most logical place would be.
Going to keep at it, not panicking yet. Other guys have had luck with this.
BonnieBlack and TILL_PT like this.
2013 Honda CB1100
post #4 of 9 (permalink) Old 08-14-2019, 09:57 PM Thread Starter
Well, slow and steady wins the race. My many thanks to all of the other poor souls to which this has happened.
Studying photos of the inner casting of the lower crank case, as posted by forum members who have tried to help others in this position, I observed the curved path the steel dowel most likely took after falling down the breather tube.
I bent a coat hangar to this curvature and slid it inside my home made fuel hose magnet tool. Fifteen minutes of fishing and I heard the magical click of steel on magnet. Up she came.
A huge worry is lifted. Thanks again to all who have gone before, leaving a detailed trail to follow in previous posts.
Now, just waiting for shims and seals, and I will never let this happen again!
2013 Honda CB1100
post #5 of 9 (permalink) Old 08-15-2019, 07:20 AM
Main Motorcycle: Thunderbird LT
Last time this happened there was an epic thread that held us captivated for ages. It was tenser than Miley Cyrus' twitter feed.
H3CT1C, Forchetto and maydaymike like this.
BasilM is offline
post #6 of 9 (permalink) Old 08-15-2019, 09:16 AM
Legend
Driftless Admin
Well done! Real pucker moment there, glad you got yourself out of it.
post #7 of 9 (permalink) Old 08-15-2019, 12:34 PM Thread Starter
Those epic threads gave me all the information I needed!
2013 Honda CB1100
post #8 of 9 (permalink) Old 08-15-2019, 01:08 PM
Main Motorcycle: Triumph Bonneville 2008
TILL_PT's Avatar
Other Motorcycle: Yamaha DT MX 125cc 1980
Extra Motorcycle: Yamaha TDM 850cc 1998
Good Job man! perseverance pays up
A Similar thing happened to me a couple of weeks ago, a screw fell from my frame into the hole where the timing chain goes down into the engine.....
luckily it got wedged midway down, and I manage to very delicately (a lot of sweating involved like if I was defusing a bomb) bring it back up with nonother than a pair of scissors this could easily have ended in a similar predicament as you.
08 Bonnie
+ Tec Sprint Exhausts / TTP Map #6 / Airbox Intake / DNA Air Filter / LED Conversion / Harness,Rectifier,Ignition Relocation
+ Hagon Nitro Shocks / Progressive Springs / Motone Pimping
- Air Baffle / Snorkel / O2 Sensors / AI System
TILL_PT is offline
post #9 of 9 (permalink) Old 08-15-2019, 05:02 PM Thread Starter
I was praying that maybe, just maybe mine bounced and went down the cam gear hole, and that it was possibly wedged like yours. Shined the brightest lights I had down there, but no such luck. But I can imagine the surgical nature of your operation and the tension you must have been feeling.
2013 Honda CB1100
