Bridgestone Battlax BT45 - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
  • 1 Post By Baltobonneville
  • 1 Post By jackthebiker
post #1 of 10 (permalink) Old 08-12-2019, 05:51 PM Thread Starter
Main Motorcycle: 2015 Bonneville T100
jackthebiker's Avatar
Other Motorcycle: 2019 Road King
You can never have enough tire threads. After some investigation I have decided to put a Bridgestone Battlax Sport Touring BT45 on the back of my 2015 Triumph T100. My reasoning is that it is a multi tread tire, and it has 9mm of tread. The Avon AM 26 only has 7.5 mm, and Michelin doesn't even have the amout listed. Any comments?
jackthebiker is online now
post #2 of 10 (permalink) Old 08-12-2019, 06:03 PM
Ran BT45s on my Honda 750 Nighthawk. Got good wear out of them, and enough grip for what the bike's performance, which is very similar to a Bonneville.
Lone Commuter of the Apocalypse
2012 Bonneville T100
2013 Honda CB1100
Gone in 60 is online now
post #3 of 10 (permalink) Old 08-12-2019, 06:11 PM
Legend
They were original equipment on my 2005.
Of course everyone bad-mouthed them at the time, but that's how it goes with tire threads, especially if you're comparing the old worn-out tires you were riding on with the brand new ones you just installed.
jackthebiker likes this.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #4 of 10 (permalink) Old 08-12-2019, 06:32 PM Thread Starter
My rear OEM has 6000 miles on it and almost shot. How can a T100 with not much over 50 hp wear out a tire that fast? Thanks for the replies.
post #5 of 10 (permalink) Old 08-12-2019, 07:25 PM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
Good Question !
Ride safe,
Quentin
wenzel850 is online now
post #6 of 10 (permalink) Old 08-12-2019, 07:59 PM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
That's what I have front & back on my Bonneville. Seem to be a decent tire. The wear has been good with 4K on them they still look close to new. Never had any lack of grip or issues with them. Good all around tire in my opinion.
Its all about motorbikes. Always has been, always will be
Neil in the Black Hills
Back2-2 is offline
post #7 of 10 (permalink) Old 08-12-2019, 09:21 PM Thread Starter
Thanks
Back2-2 likes this.
post #8 of 10 (permalink) Old 08-13-2019, 10:06 AM Thread Starter
I just noticed that there are actual two different BT45 rear tires. A tubeless and a tube tire. Now I have always put a tube in a tubeless tire with no issues, and most places only stock the tubeless type. The tube type is also more money and I am cheap. Do you have a tube type on your bike, or a tubeless?
I see that the Metzler that came on the bike is a tubeless tire with a tube in it.
post #9 of 10 (permalink) Old 08-13-2019, 05:04 PM
Back2-2's Avatar
Hi Jack, mine are both the "Tube Type" - I wish they were the tubeless since I want to seal my rims and go tube less. I am just waiting to wear these out to do the change over to tube less and sealed wheels.
Back2-2 is offline
post #10 of 10 (permalink) Old 08-13-2019, 06:28 PM
Main Motorcycle: '03 Bonneville T100
coachconnor's Avatar
Other Motorcycle: 74 Honda 450 long gone
OEM on my 2003 T100. Replaced rear after getting it used. put about 5k miles before it too was worn out. Replaced with Pilot Activs and getting much better wear. Battlaxs are a little softer and stickier
19t, BC Sleepers, 42 pilots, Thrux needles & springs, 135 mains, K&N, Dart screen, air box bafflectomy, Barnett greens, TEC shocks
Wonderous apparitions - provided by magicians. J Fogerty
coachconnor is offline
