Parking/Pilot Light Issue - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 1Likes
  • 1 Post By jhancock
post #1 of 6 (permalink) Old 08-10-2019, 07:21 PM Thread Starter
Main Motorcycle: 2013 Hinckley Bonnie T100
jhancock's Avatar
Replaced the factory headlight with a Hella metal and glass unit. Problem with the parking/pilot light, as the factory lamp and wiring are not compatible with the Hella lamp. Anyone addressed this issue before?
The Hella pilot lamp seems better quality, but I don't know where to get the correct plug for the single spade and separate ground attachment on the housing.
Thanks, Jeff
Jeff Hancock
Richmond, VA, USA
jhancock is offline
post #2 of 6 (permalink) Old 08-10-2019, 08:29 PM
Main Motorcycle: 2002 Triumph America
Wire-Wheels's Avatar
Other Motorcycle: 1995 Triumph Sprint
Extra Motorcycle: 2000 Triumph Legend TT
A photo would be helpful. ...J.D.
Wire-Wheels is offline
post #3 of 6 (permalink) Old 08-11-2019, 10:54 AM Thread Starter
jhancock's Avatar
Found that a standard 6.4mm female spade connector fits the bill, so I removed the stock socket and added the spade connectors. Now to dig up the wiring diagram and modify the rubber socket cover on the headlamp to fit the wires!
Thanks, Jeff
Jeff Hancock
Richmond, VA, USA
jhancock is offline
post #4 of 6 (permalink) Old 08-11-2019, 06:34 PM
Legend
When I replaced my headlight with a Hella without a place for the parking light, I unplugged the parking light and tossed it in my parts box. No problem there, it's a totally useless part, but I think that the Euros require it.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #5 of 6 (permalink) Old 08-11-2019, 09:08 PM Thread Starter
jhancock's Avatar
That was my fall back plan, Balto!
Baltobonneville likes this.
Jeff Hancock
Richmond, VA, USA
jhancock is offline
post #6 of 6 (permalink) Old 08-19-2019, 11:56 PM
Main Motorcycle: 2013 Bonneville T100
CapitalSon's Avatar
Other Motorcycle: 1955 AJS 350 (ex)
Hi Jeff,
If the Hella pilot light is an LED, remember to spin it around 180 degrees if it does not light the first time. I fell for that one and rode around for three years thinking the position light (LED) as dud when all it needed was the different polarity from taking it our, rotating it and then back in the socket.
Cheers.
2013 T100 - Cranberry Red, New England White, Triumph QR Screen, Racetech Shocks-F, YSS Shocks-R, Biltwell Grips, Moto bars, RoxSpeed Risers, GIPro DS, MC/NightRiderz LED Tail/Head light, Scotolier, Michelin Anakee III's, TORs; No SAI, ECS, Baffle
CapitalSon is offline
