Banjo bolt replacement - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 1Likes
  • 1 Post By Baltobonneville
post #1 of 10 (permalink) Old 07-09-2019, 03:56 PM Thread Starter
Main Motorcycle: 2010 Triumph Bonneville
AirCanuck's Avatar
Hey gents, I need to replace a banjo bolt on the engine during a rebuild. It is part T1210242. A local shop told me it is an M6x20 banjo bolt that can be purchased at any fastener shop. Reason I am driven to that is it is a $10 part and it would be $20 to ship it to me.
Can anyone confirm these can just be bought generically? Further question - has anyone replaced their carb boot clamps, if so, with what?
Cheers!
AirCanuck is offline
post #2 of 10 (permalink) Old 07-10-2019, 09:09 PM
Legend
If I were in your position, I'd certainly buy the generic part. You'll know soon enough if it doesn't work, but I don't see how it couldn't if it's the right size. It's only a banjo bolt, not some exotic part.
Jonnys Bonnie likes this.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green clutch springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #3 of 10 (permalink) Old 07-10-2019, 11:17 PM
Supernova
Forchetto's Avatar
https://newbonneville.com/shop/stain...nifold-clamps/
You could source your own, look for clamps with a 50-70 mm diameter range and 9 mm wide, preferably in stainless steel. It's a standard size.
Heed the advice of @PieMan in post 2 of this thread as regards tightening:
https://www.triumphrat.net/air-coole...ld-clamps.html
Forchetto is offline
post #4 of 10 (permalink) Old 07-11-2019, 06:39 AM Thread Starter
AirCanuck's Avatar
Mine are about 10 years old so was looking at replacing them simply as a safety precaution while I had them off. Is this necessary?
post #5 of 10 (permalink) Old 07-11-2019, 07:07 AM
Legend
If you mean the clamps, no. What would be wrong with them?
Marty
post #6 of 10 (permalink) Old 07-13-2019, 05:25 PM
Main Motorcycle: 2002 Bonneville T100
RaceDweeb's Avatar
Other Motorcycle: Tri, Ducati, HD, Gilera
Extra Motorcycle: "The Knucklution"
M6x20 banjo bolt
Where exactly is this banjo bolt located? I've never heard of a M6 size banjo bolt.
As for manifold clamps, make sure they are NOT the perforated type (row of slots punched in the band) because the sharp edges dig into the rubber. These are NOT perforated:
/M
ENGINEERED TO THRILL
RaceDweeb is offline
post #7 of 10 (permalink) Old 07-16-2019, 10:49 PM
Supernova
Forchetto's Avatar
There are 4 M6x20 Banjo bolts altogether.
We've got two of them under the cam cover. They're used on the oil feed to the cams, see items 9:
Another two are on a small pipe linking the oil pumps, items 10 here:
post #8 of 10 (permalink) Old 07-21-2019, 02:42 PM
RaceDweeb's Avatar
Well, that explains it. I stay away from 'inside' the engine.
/M
post #9 of 10 (permalink) Old 07-21-2019, 06:04 PM
Just remember that what makes the banjo bolts work is the copper crush washers. Seals em up tight.
Pylot7 is online now
post #10 of 10 (permalink) Old 07-22-2019, 05:54 AM Thread Starter
AirCanuck's Avatar
Yup! I have the washer. Hoping to get it all together this week
