Cheap Immobilizer - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 9Likes
  • 9 Post By Ripper
post #1 of 7 (permalink) Old 07-06-2019, 03:32 AM Thread Starter
Ripper's Avatar
Lightbulb Cheap Immobilizer
Over the last couple of weeks there has been quite a bit of talk about immobilizers/kill switches in various threads, and so I thought of coming up with something cheap, reliable and easy to do. Not a new idea by any means but provides an alternative option to more expensive ones. This is based around the same remote controlled relay that has appeared in other threads as keyless ignition. It has only 3 wires to connect to the alarm connector and measures around 2 inches square, so it is ideal for fitting in tight spaces.
The 12 volt remote relay is widely available on eBay for around 5 with a range of different push button fobs and comes in a small plastic box which can simply be stuck down with foam tape. It operates (in ideal conditions) with a range of about 100m but if surrounded by a lot of metal this can be halved.
An important point to remember about its behaviour is that it activates (immobilizes) automatically when the ignition is turned off. The fob button is only needed to de-activate it after switching the ignition on.
Arrow 2-2, Snorkel/Baffle removed, DNA filter, TTP Tune#3, TEC piggy back gas shocks, 5.5" risers with drag bars, LED Lighting, Hazards, Oberon Footpegs, Burton Seat, D9 bracketry, Hands Free Keyless ignition.
Ripper is offline
post #2 of 7 (permalink) Old 07-06-2019, 06:21 AM
Supernova
Forchetto's Avatar
Brilliant, thanks.
A couple of ebay listings from as little as $6.90...
https://www.ebay.com/itm/DC12V-10A-R...-/153498374118
https://www.ebay.com/itm/DC-12v-10A-....c100005.m1851
Forchetto is offline
post #3 of 7 (permalink) Old 07-11-2019, 12:03 PM
Main Motorcycle: 2009 Scrambler
Nice and straight forward, adding in another layer of security
Ade-955i is offline
post #4 of 7 (permalink) Old 07-12-2019, 05:49 PM
Main Motorcycle: Triumph Bonneville 2008
TILL_PT's Avatar
Other Motorcycle: Yamaha DT MX 125cc 1980
Extra Motorcycle: Yamaha TDM 850cc 1998
Another great contribution to the community, Simple and effective
08 Bonnie
+ Tec Sprint Exhausts / TTP EFI Remap Map #6 / Breathe Airbox Intake / DNA Air Filter / NGK Iridium Sparkies
- Air Baffle / Snorkel / O2 Sensors / AI System
TILL_PT is offline
post #5 of 7 (permalink) Old 08-14-2019, 06:36 AM
R0B
Main Motorcycle: Modified Bonnie
Other Motorcycle: another Bonnie
Extra Motorcycle: Selling it.........
Thanks for posting this. I'm an electronics disaster area. I presume that as it only arms when the power cuts out that it is effectively fail safe and therefore can't cut the engine out whilst riding?. I found another on ebay........cheap as chips......
https://www.ebay.co.uk/itm/DC-12V-Re...72.m2749.l2649
Cheers Rob
R0B is online now
post #6 of 7 (permalink) Old 08-14-2019, 05:45 PM Thread Starter
Ripper's Avatar
Like with everything, that depends - if you have an electrical fault, even without the immobilizer the engine will cut. You can also use the fob button to cut the engine with the ignition on, but I can't see why you would want to do that. The immobilizer works by replacing the link between pins 1 and 2 of the alarm connector with the contacts of a relay. With the ignition on, pressing the fob button activates the relay and makes the connection between pins 1 and 2 - the bike runs. When you switch off the ignition the power to the relay is cut and the relay drops out - the bike is now immobilized. To start the bike again you must first switch on the ignition then press the button on the fob. The relay will hold contact for as long as the ignition is on. It is possible to modify the wiring so that the button is required to immobilize as well as disarm but I did it this way to avoid the tiny current drain on the battery when the bike is standing. The kill switch is on the same circuit but further down the line, so if you use the kill switch to stop the engine the bike will not be immobilized.
Ripper is offline
post #7 of 7 (permalink) Old 08-15-2019, 04:10 AM
R0B
Thanks very much for the comprehensive reply..............
Rob
R0B is online now
