Super Low MPG on '14 Scrambler - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 06-11-2019, 02:26 PM Thread Starter
Jaynes's Avatar
Was hoping to get some help trouble shooting my EFI scram and it's low gas mileage. Here's what I know...
I don't always pay attention to my tank mileage, but noticed something seemed off so I tracked the last 4 tanks. I'm averaging 26 MPG. No performance issues noticeable. I have noticed a sporadic ticking noising in my engine though that seems to happen when the motor is at it's hottest. Haven't troubleshot that yet and have no idea if it's actually related or not. Where should I start?
Kyle
Jaynes is online now
post #2 of 8 (permalink) Old 06-11-2019, 07:56 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
Does your bike have intake/exhaust mods?
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is offline
post #3 of 8 (permalink) Old 06-12-2019, 12:46 AM Thread Starter
Jaynes's Avatar
It’s got the arrow exhaust on it. I bought it used though, so I’m not sure what map or tune was used.
I had my speedo replaced a couple or so months ago by the dealer. Any reason they would’ve had to wipe the CPU (and any custom tunes it had on it) as a part of the install. Maybe they forgot to reload the right map back onto it.
Kyle
post #4 of 8 (permalink) Old 06-12-2019, 06:44 AM
yrunvs's Avatar
That's where I would start. Remap to compensate for whatever mods you have. Check your intake to see what has been changed. TTP makes custom maps to match mods or maybe your dealer can remap.
yrunvs is offline
post #5 of 8 (permalink) Old 06-12-2019, 10:53 AM
Main Motorcycle: Triumph Bonneville SE
mick 85's Avatar
Originally Posted by Jaynes View Post
I had my speedo replaced a couple or so months ago by the dealer. .
Why was the speedo replaced, and is it showing accurate mileage now ? Might be worth measuring distance travelled by satnav or phone for a while, jus to cross-check. 26mpg seems far too way off the mark, even with the wrong map.
Born to be mild
mick 85 is offline
post #6 of 8 (permalink) Old 06-12-2019, 12:29 PM Thread Starter
Jaynes's Avatar
K. Time to get the TuneECU software I think, so I'll know more about what's going on in the ECU.
Bike wasn't starting and after a bunch of troubleshooting at home, I took it to into the dealer and they found some corrosion in there. They plugged it into a working speedo and it fired right up. Not sure if it's tracking mileage accurately. I'll crosscheck that with my phone.
Thanks!
Kyle
post #7 of 8 (permalink) Old 06-12-2019, 05:37 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
Check the air intake rubbers and the 3mm vacuum lines running up into the MAP sensors (2). These develop leaks leading to poor fueling and can give rough running/popping out the back etc.
Your TuneECU reading can also help tell various items are giving correct values. The MAP sensors need to be within 10 hPa's of each other. Assuming no leaks, this indicates the throttles need balancing via the white-painted screw sitting between the throttle bodies.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
post #8 of 8 (permalink) Old 06-13-2019, 10:53 AM
Legend
Maybe you're getting 26 km/liter.
All kidding aside, there actually once was someone on this forum whose odometer somehow got set to kilometers instead of miles.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT "Thruxton" needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
