Bitubo WME / spring rate - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
  • 1 Post By wenzel850
  • 1 Post By Paint It Black
  • 1 Post By Flash Nick
post #1 of 7 (permalink) Old 05-22-2019, 07:02 AM Thread Starter
Main Motorcycle: 2012 T100 Black
tlchris's Avatar
Other Motorcycle: KTM 250 XCF
i would like some help from the forum to help me choose my rear shocks, i have been exchanging emails with the canadian dealer here in Canada, my main concern is getting the right spring for me, im 155 ponds, drive mainly solo mi bike is a 2012 T100. When i ask what spring rate they suggest for me they said " 50kg leaving extra preload adjutment " is that right?
i was expecting 25-30kg/cm.
thank you for your comments.
christian
tlchris is offline
post #2 of 7 (permalink) Old 05-22-2019, 12:33 PM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
Not even close. My Hagon's came with 20kg springs that are right for my weight 200 lbs. I to ride solo on my 08 T100.
tlchris likes this.
Ride safe,
Quentin
wenzel850 is online now
post #3 of 7 (permalink) Old 05-22-2019, 01:20 PM
Main Motorcycle: Triumph Scrambler
Other Motorcycle: Yam XJR1300 , Honda NX650
Extra Motorcycle: Suzi GS1000, DR350
My Ohlins springs are rated at 18-27 N/MM which is near enough the same as KG/CM
I'm 190lb and the springs work well for me solo or 2 up with extra pre load
tlchris likes this.
Mine's the black one
Paint It Black is online now
post #4 of 7 (permalink) Old 05-23-2019, 06:19 AM Thread Starter
tlchris's Avatar
i found out that there is 4 spring rate for thr WME ; 1.2-1.7, 1.9, 2.4 (standard) and 3 kg/mm.
they said that for my weight the 2.4 kg/mm (24kg/cm) will be the correct choice.
if 20kg/cm is good for a 200lbs rider, maybe i should go with the 1.9 ??
and the progressive one seem very smooth. 1.2-1.7
tlchris is offline
post #5 of 7 (permalink) Old 05-23-2019, 06:20 AM
Main Motorcycle: 2009 Bonneville
Flash Nick's Avatar
Other Motorcycle: Kawasaki Super Sherpa
When I priced Bitubo I was told they come with 24kg springs. They were a bit pricey so I went with Hagons fitted with 20kg. I'm 160lb. I probably would have been happy with 24kg, my Hagons sometimes bottom out.
tlchris likes this.
I'll have you know I come from the best of convict stock.
Flash Nick is offline
post #6 of 7 (permalink) Old 05-29-2019, 07:01 AM Thread Starter
tlchris's Avatar
does a progressive spring like 1.3-1.7 equal a 1.9 standard spring ? and should a progressive spring better than a standard spring?
tlchris is offline
post #7 of 7 (permalink) Old 05-29-2019, 07:42 AM
Flash Nick's Avatar
You did have me confused when you mentioned only the lower Bitubo spring was progressive. I'd be surprised if any manufacturer fitted non-progressive springs. (could be proven wrong). For example all the Hagon springs are progressive, I believe the spring rate represents an average.
The way they work is that the rate is constant until the more closely wound coils bind i.e. coil to coil locked. The remaining active springs is therefore shorter, so each mm of travel puts an increased torque on the coil wire, resulting in a higher spring rate. So you can easily tell if a spring is progressive by the non uniform coil winding.
I can't verify your Bitubo data as I could never find any published info on the available springs, I was only offered 24kg.
Cheap rear suspension upgrade gregp Hinckley Classic Triples 309 10-23-2018 03:27 PM
Shock choices for '98 T-Bird Sport? Armen Hinckley Classic Triples 39 07-09-2016 08:51 AM
Sprint st 1050 shock spring upgrade raptorryus Sprint Forum 10 10-02-2012 03:26 AM
Bitubo rear shocks -longer+stock rate springs OK? HiVel Club Cafe' 12 03-09-2010 12:26 AM
Spring Load/ Rate of shocks happyray Classic, Vintage & Veteran 0 05-21-2008 02:41 AM
