Broken front mudguard in minor accident - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 05-19-2019, 03:43 PM Thread Starter
Main Motorcycle: Bonneville SE EFI 2011
Lpar's Avatar
I was just waiting feet down in a traffic jam when an idiot in front of me decided to go in reverse and hit my front wheel. Mudguard broken in half and bike dropped.
I was < 5 minutes from home so I checked suspensions and brake (seemed OK) and drove normally.
Tomorrow I will obviously put the wheel up and check spinning, the forks, etc. Anything in particular I should look at? I am worried the mudguard broke since it's not like it protrudes in front of the wheel.
TORs, SAI/O2/snorkel removed, TTP Airbox Cover w/DNA filter, TTP Tune#1, Triumph windshields, G2 Throttle Tamer, NH Low-UK bar, SW-Motech Footpegs, Gammatronix Battery Monitor, Triumph handguards, Oxford heated grips, Denali SoundBomb + more ;)
Lpar is offline
post #2 of 11 (permalink) Old 05-19-2019, 04:02 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
Wow, sorry! I had an '04 Bonnie with a plastic front fender and it seemed wobbly as hell, surprised yours actually broke. Maybe the fasteners created a weak point.
Really hard to 'sight' along the forks to assess 'true' particularly if you got hit square on. I'd study all up front and remove the forks for some good looks and comparisons.
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is online now
post #3 of 11 (permalink) Old 05-19-2019, 05:00 PM Thread Starter
Lpar's Avatar
I am surprised myself because if the fork goes up, the fender also goes up, so how the heck did it break. Never removed the forks so I hope it's not so hard. Not sure what to look at though, they will look identical (?)
Lpar is offline
post #4 of 11 (permalink) Old 05-19-2019, 07:01 PM
Main Motorcycle: 2013 bonneville t100
kunkledude's Avatar
There are no shortage of idiots out there. They didnít see your bright orange SE? Any other damage from the drop?
kunkledude is offline
post #5 of 11 (permalink) Old 05-19-2019, 07:31 PM
Legend
This might help to check the forks:
https://www.motionpro.com/product/08-0412
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT "Thruxton" needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is online now
post #6 of 11 (permalink) Old 05-20-2019, 10:35 AM Thread Starter
Lpar's Avatar
This morning I have checked all I could following the Haynes manual maintenance/checks for wheels and forks. Everything appears to be ok. Even the wheel bolt slides in like butter. There is a little binding/resistance moving the handlebars to the right but I believe it's the cables. There is no binding pushing up and down the bars like a gorilla.
I also put the wheel on my balancing stand and it's true.
Although the forks are parallel there's always the doubt whether they might be slightly bent inwards the same amount, since I got hit square on. Maybe my bike is a little shorter now
Lpar is offline
post #7 of 11 (permalink) Old 05-20-2019, 01:05 PM
6t
Main Motorcycle: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
I'd be tempted to loosen the triples one side at a time and slide each tube down one at a time to make sure there hasn't been damage/crease to the plating. One at a time makes it easier to put it back in the same spot as you have the other side for reference.
When I took my new-to-me T100's forks apart to upgrade the internals I discovered that a previous owner had slid the tubes up the triples to hide some damage. 'Bike rode true and straight before but I ended up buying new tubes.
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is offline
post #8 of 11 (permalink) Old 05-24-2019, 07:44 PM
My fender broke exactly as yours did a while back when a small critter ran in front of my on a back road. I was amazed how easily it snapped off, as it wasn't a hard hit, but there was no other damage to the bike, and everything remained in alignment.
Lone Commuter of the Apocalypse
2012 Bonneville T100
2013 Honda CB1100
Gone in 60 is offline
post #9 of 11 (permalink) Old 05-25-2019, 07:58 AM Thread Starter
Lpar's Avatar
I was also amazed looking at the price (£154.36 / Ä166.71 / $197.58) !!. I've been very lucky to find the only one in orange on eBay.
Although everything else seems ok, the hit damaged the carcass of my front tyre, so now I don't know what to do because the forks seem perfectly ok and straight. Doing the alignment thing as per Delboy video involves loosening the lower yoke and the steering stem nut and I am afraid I could mess up with the front end of the bike.
Lpar is offline
post #10 of 11 (permalink) Old 05-27-2019, 08:28 AM
Main Motorcycle: Scrambler (#2)
Other Motorcycle: ZR-7S
Extra Motorcycle: 900 Monster
I would also be concerned about the fork tubes. you could loosen one up at the triple, rotate it 180 degrees and see if they're still parallel. or take them out and check them properly for straightness.
Sorry about your fender.
tenex1 is offline
Front mudguard stays - '68 T120 tjwood Classic, Vintage & Veteran 4 12-29-2016 07:32 AM
Front mudguard fit Pharisee Classic, Vintage & Veteran 41 02-04-2015 05:24 AM
Front mudguard needed Pharisee Classic, Vintage & Veteran 7 12-06-2014 04:59 PM
TBS - Front Mudguard Removal Tigeralorange Hinckley Classic Triples 12 09-25-2014 05:37 PM
Can't remove front mudguard aniseed T3 Sport / Touring Forum 5 02-24-2006 05:36 PM
