Rear Brake grinding when engaged at only 2,000 miles - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 4Likes
post #11 of 17 (permalink) Old 05-18-2019, 06:48 PM
Main Motorcycle: Triumph Scrambler
Kiwi Tiger's Avatar
Question
Originally Posted by Scotty_b View Post
Well, we'll see what it looks like in a few days time.
Illegitimi non carborundum - Sons of arthritis - Ibuprofen Chapter :-)
Kiwi Tiger is online now
post #12 of 17 (permalink) Old 05-18-2019, 07:09 PM
Main Motorcycle: 2009 America EFI
MattyMo's Avatar
@Scotty_b , when you do get to look at the rear brake pads, don't be surprised if you don't have the same amount of material on both inner & outer pads. Think the brake bits have remained the same for many years. New pads for me have different amounts (depth?) of friction material for inner & outer pads.
edit: And yes, the OEM rear pads do seem to wear rather quickly compared to EBC or other replacement pads.
2009 America with some modifications, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #13 of 17 (permalink) Old 05-19-2019, 04:41 PM
Kiwi Tiger's Avatar
Think I may have found a photo for this post.
All the best in getting it sorted.
Kiwi Tiger.
post #14 of 17 (permalink) Old 05-23-2019, 11:41 AM Thread Starter
Main Motorcycle: 2015 Triumph Speedmaster
Scotty_b's Avatar
Other Motorcycle: 1977 Honda CB750K
Hey y'all,
Still haven't had a chance to take the calipers off yet. Work piled up, the Ol Lady got the flu, etc, etc.
I came to the assumption that mediocre OEM pads + a lot of Chicago city traffic braking + now a bunch of mountain downhill braking probably has eaten up the pads way faster than I would have expected. So I also ordered some front pads so I can change them all no matter what.
I'll be swapping them during the long weekend this weekend and will post a follow up. Thank you all for your advice and instruction it is much appreciated!
-scotty
steventhechef likes this.
2015 Speedy: Fabricated seat, sissy, idiot bracket & cut fenders. Biltwell bars, risers, grips. Motion Pro lines. Drag Spec brackets. T100 tank. BC pipes & covers. K&S signals. TC Bros plate holder. Prism Supply tail light. TTP EFI Induction kit.
Scotty_b is offline
post #15 of 17 (permalink) Old 05-24-2019, 08:37 AM
Main Motorcycle: 2014 Bonneville T100
I did exactly what you did which was assume my rear pads were bad. I took everything apart and my pads were in fact barely used after 4k miles. Just a bunch of dirt and a piece of melted plastic bag caught in the caliper. I cleaned everything, lubricated the slide pins and put everything back together and kept the pads I bought for another day.
Chada is offline
post #16 of 17 (permalink) Old 05-30-2019, 05:47 PM Thread Starter
Scotty_b's Avatar
Yep, what many of you had thought, including myself in the end, was in fact the case.
Rear brake pads were completely worn off while the front had a ton of material on them. The piston did not seem stuck so I'm now just convinced that 2K miles of city traffic and steep, curvy downhill passes ate my stock rear brakes away much faster than I expected. Kind of surprised they went that quick but, hey, stopping is good right?
I put on some Galfer's and now I know its something I need to check more regularly, like once a year. Thanks everyone for the advice, it was a ridiculously easy process but your input was beneficial to what to look for.
Cheers!
Scotty_b is offline
post #17 of 17 (permalink) Old 05-30-2019, 07:49 PM
Main Motorcycle: 2006 Blue Thruxton
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Thanks everyone for your advice!
unfortunately I'm attending a wedding this weekend.
Unfortunately for you or for him? I am pleased that you got it sorted easily.
I also use brake cleaner in a spray can. That keeps everything clean and working correctly
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is online now
Rear brake flush 2000 Triumph Sprint skos Sprint Forum 0 10-12-2014 10:25 PM
Rear brake flush 2000 Triumph Sprint skos Air Cooled Twins Technical Talk 1 10-12-2014 10:16 PM
2009 Speed Triple rear brake not working at all weekdaywarrior Speed Triple Forum 6 08-23-2014 11:11 AM
Suspension Setup - Step by Step Sparti Speed Triple Forum 11 05-28-2006 03:33 AM
rear brake problem smoothnutbrown Air Cooled Twins Talk 6 08-03-2005 12:27 PM
