Clutch Lifespan - Triumph Forum: Triumph Rat Motorcycle Forums
Air Cooled Twins Technical Talk Technical Talk for Hinckley Triumph Twins: Bonneville, Bobber, T100, Speedmaster, America, Thruxton, and Scrambler. Sponsored by: triumphtwinpower.com
 11Likes
post #1 of 16 (permalink) Old 05-06-2019, 04:56 PM Thread Starter
Main Motorcycle: Scrambler 2012
Clutch Lifespan
Hey
I am almost at the 30K mile mark on a 2012 Scrambler EFI and was planning a few tweaks, preventive rather than repairs and wanted your thoughts on clutch wear.
The bike's got the usual mods, TTP stage 2 map with free flowing 2:1...... i ride hard often pushing 7k revs. The clutch is doing just fine but at times feel if I go the green Barnett route it may bite a little better.
Since i am opening her up i was wondering if at 30K miles, i should consider changing the plates too.
I have heard both ends of the spectrum of folks who have reached the 70k miles before the plates were toast and those that say its 30k, so go ahead and change the plates.
Be great if you could reply back with, when and if your plates gave in or if you are running higher than 30k miles with typical riding style and any performance mods to get a better idea on the expected life of the clutch plates.
Cheers
Tom
Thomasinasu is offline
post #2 of 16 (permalink) Old 05-06-2019, 07:32 PM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
I have a 2015 Thruxton purchased new and recently installed Barnett green springs but I have to tell you when I opened her up the OEM springs in there sure looked green. I think Triumph updated the clutch springs somewhere in the EFI range bikes but I'm not sure when and that's just an educated guess. If I were you I'd go full on with plates and springs if you do anything....just my opinion.
Thomasinasu likes this.
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is online now
post #3 of 16 (permalink) Old 05-06-2019, 09:11 PM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
If you are not getting clutch slippage leave them alone. when and if you get slippage it's time to change. Don't try and fix what is not broken. Just my 2 cents of many years of riding high HP sport bikes.
“Its all about motorbikes. Always has been, always will be”
Neil in the Black Hills
Back2-2 is offline
post #4 of 16 (permalink) Old 05-06-2019, 10:05 PM
Main Motorcycle: 2013 Thruxton 900
MyEvilTwin's Avatar
I have a 2013 Thrux and yes the OEM springs have a faded light green strip on them. However, they lack the coil thickness of Barnetts and more coil turns as the Barnetts are shorter. I must say the shifts are noticeably crisper and snappier with Barnetts at the expense of a little more hand pull effort. Worth the swap any day of the week.
2013 Thruxton EFI
MyEvilTwin is offline
post #5 of 16 (permalink) Old 05-07-2019, 09:08 AM Thread Starter
Back 2-2, I hear you and that's usually my stance, but then the "what if" creeps in. I believe the plates at this point should only be half way down from what I have gathered thus far and so if the springs can give a bit more feel for the hot summer then it may just be the tipping point to open her up.
Back2-2 likes this.
Last edited by Thomasinasu; 05-07-2019 at 09:15 AM. Reason: addressed the reply to earlier comment.
post #6 of 16 (permalink) Old 05-07-2019, 09:11 AM Thread Starter
Thank you this is super helpful. I think i will switch the springs when the oil change is due and will keep you all posted on the results once done.
post #7 of 16 (permalink) Old 05-08-2019, 01:58 PM
Main Motorcycle: 01 Triumph Bonneville
Other Motorcycle: 01 HD Night Train
Extra Motorcycle: 87 Honda Super Magna
The Clutch plates barely wear...OEM Springs have 65k life span.
Arrow 2-2...Unrestricted Air box with K&N and TTP Breathe 140 mains with 42 pilots 2 shims
DUCKMAN is offline
post #8 of 16 (permalink) Old 05-09-2019, 11:30 AM
Main Motorcycle: My old 1967 '500
Twintorsk's Avatar
You cant really talk about miles with clutches, some people burn through them instantly, for some they never wear, its a matter of technique.
Back2-2 and Gyp like this.
Twintorsk is offline
post #9 of 16 (permalink) Old 06-03-2019, 05:16 PM Thread Starter
A quick update after the job
I managed to get the springs switched out the plates looked great, while i was in there dropped in a TTP safe start. In that same time i also changed out the fork oil with Maxima 10W & 15W on a 40:60 ratio, new drive chain and sprocket, tore out the old brake lines and replaced with braided lines and really cleaned out the calipers.
And the result is just fantastic..... Superb, it was worth all that time & effort as the bike runs even better now. The clutch pull is just a tad tighter but as someone said the gear changes are crisper. I feel like there is a bit more of the power low down and it just pulls better on hard acceleration.
Anyone on the fence about this, it’s an easy project that takes time with the fiddly things such as removing the old gasket and also putting the spring restrain back in without the tool while keeping the alignment.
Here are some images
Cheers
Tom
ID:	644454   Click image for larger version
ID:	644456   Click image for larger version
ID:	644458   Click image for larger version
ID:	644460   Click image for larger version
ID:	644464   Click image for larger version
ID:	644466   Click image for larger version
ID:	644468   Click image for larger version
ID:	644470   Click image for larger version
Back2-2 likes this.
post #10 of 16 (permalink) Old 06-03-2019, 09:39 PM
yrunvs's Avatar
Thanks for the update. See this is how it should work....when a poster starts a thread they need to finalize it.
Back2-2 and InTheSoup like this.
1972 T120 Terrible clutch 19callducks Classic, Vintage & Veteran 81 02-12-2018 07:32 PM
1967 Triumph Tr6c engine and gearbox oil and capacities. dustyclark87 Classic, Vintage & Veteran 27 07-09-2017 09:42 PM
Clutch Disengaged (Technical Problem) thinkjerm Sprint Forum 0 12-09-2013 11:49 AM
Clutch Lifespan HOPOIL Air Cooled Twins Technical Talk 5 05-25-2011 10:57 PM
79 t140 clutch hub assembly fitment issues tobydmv Classic, Vintage & Veteran 26 12-07-2010 05:25 PM
