Burnt Valve Gasket? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 05-04-2019, 03:58 PM Thread Starter
Main Motorcycle: Triumph Bonneville 2008
Other Motorcycle: Yamaha DT MX 125cc 1980
Extra Motorcycle: Yamaha TDM 850cc 1998
Exclamation
Hey Guys
Today I went for a bike run to commemorate the 60 Years of the 59 Club in London, From the Ace Cafe to St Pauls Catedral. and as you know those rides can get kind of slow... and my bike heated like crazy. after I parked the bike for 2h It wouldn't start again...it took me 5 minutes to be able to start it (never happened before, normally starts first try even cold) I checked the bike and found this 'photo' looks like an oil mark coming from the valve gasket, did the heat burn off the gasket?
Give me your thoughts Guys
TILL_PT is online now
post #2 of 10 (permalink) Old 05-04-2019, 07:55 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
Doubtful the gasket is ruined. The grommets/seals under the hold down nuts are known to collapse and lose their tension reducing the force holding the cam cover down. Best to replace them. They can be shimmed using thin gasket material between the nut and washer, but be careful and do not over tighten, some say they are easily buggered. How many miles on the bike?
rweb is online now
post #3 of 10 (permalink) Old 05-05-2019, 02:46 AM Thread Starter
Just under 10,000.
I believe under the heat the motor was subjected to during the ride with the metals expanding and contracting, a bit of oil might have "perspired" trough the gasket.
I have to get rid of the the Freaking AI system
post #4 of 10 (permalink) Old 05-05-2019, 10:29 AM
My 08 T100 was leaking when I bought it at 13,000 miles. I didn't replace the gasket but did shim the grommets, now at 33,000 miles it's still leak free.
rweb is online now
post #5 of 10 (permalink) Old 05-05-2019, 11:34 AM
Legend
Seepage around the cam cover gasket been a common issue for years on these bikes. Replace the four seals as mentioned and torque evenly and carefully to 10NM only. Do NOT overtighten.
It might be difficult to loosen the screws if you've never had them off. Use a quality bit and a breaker bar to crack them loose.
If replacing the seals doesn't fix it, you can try replacing the gasket, but it probably is not necessary.
Marty
2005 Bonneville Blue 790cc, AI removed, Staintunes RC, no snorkel, inlet enlarged, 118/40/NBZT "Thruxton" needles/1 shim/3 turns, Ikon 7610s, Ricor Intiminators, Barnett green springs, Michelin Pilot Activs, D9 gauge panel, tachometer.
Baltobonneville is offline
post #6 of 10 (permalink) Old 05-06-2019, 06:21 AM Thread Starter
Thanks everyone, I have to get around to buying a torque wrench.
I have a full garage of tools in Portugal but it's not worth bringing them here so... I have to buy a lot of them again
since I will remove the bolts to replace the grommets don't you thing since I am removing them might as well do the seal as well?
post #7 of 10 (permalink) Old 05-06-2019, 03:34 PM
Main Motorcycle: 2013 bonneville t100
kunkledude's Avatar
Same. Replaced the gasket and replaced the washer/grommets. Still holding up from last summer.
kunkledude is online now
post #8 of 10 (permalink) Old 05-07-2019, 10:40 AM Thread Starter
So... not the same XD
post #9 of 10 (permalink) Old 05-08-2019, 03:19 PM
kunkledude's Avatar
Dealer recommended I switch out the 4 grommets when I do the gasket change. Torqued accordingly and it was all good.
post #10 of 10 (permalink) Old 05-13-2019, 11:19 AM Thread Starter
Will do Will do Thanks
Adjusting 1050 Valve Clearances champ87 Maintenance Tips and Tricks for your Sprint 84 02-21-2019 11:04 AM
new gasket after valve check? secondwindsteve Sprint Forum 4 02-22-2018 07:52 PM
Sprint Forks Maintenance and Upgrade champ87 Maintenance Tips and Tricks for your Sprint 18 08-03-2014 05:59 AM
Valve Cover Gasket 61842 Air Cooled Twins Technical Talk 5 01-12-2012 11:45 AM
valves in a bucket - literally Haggis Maintenance & Workshop Talk 8 01-28-2011 04:26 PM
