I'm giving up... Battery issue - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 25Likes
post #11 of 36 (permalink) Old 05-05-2019, 11:33 PM
Supernova
Forchetto's Avatar
Originally Posted by tenex1 View Post
P.S. Where are you getting your batteries? Some dealers are not diligent about properly filling and charging a new battery. This can cripple them before they get to your bike.
Indeed. Correct new battery commissioning is very important. Triumph publishes this procedure on all their technician training manuals for use by their dealers service departments:
Battery Commissioning Procedure
This procedure is designed to ensure that the battery is at its best when fitted to the motorcycle, and provide the best possible performance and reliability.
Failure to comply with this procedure may lead to reduced battery performance and/or shorten the life of the battery.
Warning! The electrolyte solution is SULPHURIC ACID. Ensure that you read all the warnings supplied with the battery and are familiar with the necessary safety precautions and remedial actions should spillage or contamination occur.
1. Read the instructions and warnings delivered with the battery!
2. Place the battery on a flat level surface and remove the sealing foil.
3. Remove the battery sealing strip from the electrolyte container (if applicable) and save for use later in this procedure. Do not break the seal on the electrolyte container.
4. Place the electrolyte container and adapter (if applicable) on the battery and fill the battery according to the manufacturers instructions.
5. After starting to fill the battery with electrolyte, allow the battery to stand for 30 minutes with the filling container in place.
6. Check that all of the electrolyte has drained from the container, do not remove container at this point. If the container has not completely drained, tap the sides of the container to start the electrolyte flowing again.
7. After all of the electrolyte has drained into the battery, allow the battery to stand with the electrolyte container in place, for a further 30 minutes for batteries 3Ah 12Ah or 1 hour for batteries greater than 12Ah.
8. Remove the electrolyte container and adapter carefully, and dispose of immediately.
9. Fit the sealing caps to the battery according to the manufacturers instructions.
10. Measure the terminal voltage on the battery to assess the battery condition and charge the battery as necessary (see table of charging time) using a suitable charger (i.e. a charger with a suitably controlled charging current and appropriate cut off voltage.)
Charging current should be controlled to 10% of the nominal capacity (i.e. for a 10AH battery charging current I = 0.1 x 10 = 1Amp)
Table of charging time
Terminal Voltage....Charge Time......Cutoff Voltage
>12.8V............... 2 hour............ 14.5V
>12.7V............... 3 hours........... 14.5V
>12.6V............... 4 hours........... 14.5V
>12.5V............... 6 hours........... 14.5V
<12.5V............... 8-10 hours........ 14.5V
11. Disconnect the charger and allow the battery to stand for 1 hour before fitting
to the motorcycle.
12. Fit the battery to the motorcycle, positive (Red) lead first.
End of Procedure
49erx2 likes this.
Forchetto is offline
post #12 of 36 (permalink) Old 05-06-2019, 03:10 PM Thread Starter
Main Motorcycle: Bonneville T100 EFI 2007
nicetown's Avatar
Thanks for all your answers.
I bought all my batteries online, respecting the procedure to fill them in.
Model Yuasa-YTX12-BS.
https://www.ebay.co.uk/itm/Genuine-Y...S/273270877441
I charged my most recent one for 24 h.
After unplugging the charger: 13.34V
8 h after: 12.87V
Here are the different voltages I read on my voltmeter:
- Off the bike: 12.87V
- Connected: 12.87V
- Turn the key: 12.55V
- Idle: starts at 13.60 and moves rapidly to 14.10V
- 3000 rpm: 14.20V
- 15 min after stopping the bike: 12.84V
Is the photo attached the cable that comes from the stator? It's not burnt inside.
- No parasite current when I plug the Ammeter.
- I don't have any alarm or anything extra that could drain the battery.
From what I understand, my battery seems to be charging, so it's not a problem of stator/rectifier ?
nicetown is offline
post #13 of 36 (permalink) Old 05-06-2019, 03:41 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
Check that the cable connections at the battery, both sides of the solenoid and starter are clean and tight.
vitesse likes this.
rweb is offline
post #14 of 36 (permalink) Old 05-06-2019, 09:35 PM
Main Motorcycle: Scrambler (#2)
Other Motorcycle: ZR-7S
Extra Motorcycle: 900 Monster
8 h after: 12.87V
- Connected: 12.87V
- 3000 rpm: 14.20V
Very interesting, this is exactly what I would expect from a properly functioning electrical system. Normally at this point I'd be getting a new battery. How old is this battery?
I have the same battery on my Zr-7s, the first one lasted 7 years, the second on 4 years, The battery in my scrambler 2 years. Both electrical systems tested and yielding the same performance as yours.
Since all the batteries I have bought (all Yuasa) have been from the same dealer, I thought I'd try a factory charged battery. I replaced the scrambler battery with a Deka battery. We'll see how long it lasts.
I'm sorry I don't have a better suggestion, everything looks perfect.
Cheers,
Steve.
tenex1 is offline
post #15 of 36 (permalink) Old 05-07-2019, 01:28 AM Thread Starter
nicetown's Avatar
The cable connections at the battery and solenoid are tight, starter you mean the starter relay ? If yes, it's clean as well.
My last battery is 6 month, and because of all the acid attacks in London, this one came already filled. I might try to buy one in a Triumph dealer I guess...
Thanks for your help
nicetown is offline
post #16 of 36 (permalink) Old 05-07-2019, 05:11 AM
Supernova
Forchetto's Avatar
No. That looks like the connector for one of the sensors. Follow the larger of the two cable looms that exit the alternator casing until you find it.
The alternator stator connector is like this, burned examples:
post #17 of 36 (permalink) Old 05-07-2019, 02:57 PM
Main Motorcycle: Triumph Scrambler
Kiwi Tiger's Avatar
To the O P.
This has been going on for some time and throwing new batteries is not fixing it, not to mention expensive.
I suspect fixing this problem will be a little like climbing a ladder. You do one step at a time.
Follow the steps and then deal with the next one. Eventually the fault will be found.
Dont be tempted to go charging off in all manners of if directions like a mad woman's ****e as you will miss some steps and probably your bike will remain unreliable.
It appears you have been doing this for over a year so far ......... and it remains unreliable....
Follow the yellow brick road.
vitesse likes this.
Illegitimi non carborundum - Sons of arthritis - Ibuprofen Chapter :-)
Kiwi Tiger is offline
post #18 of 36 (permalink) Old 05-09-2019, 09:02 PM
Main Motorcycle: 2007 Speed Triple
Anybody knows what is the parasitic draw should be on 2007 speed triple, what is the accepted amperage draw?
I'm giving up
Sent from my GT-N5110 using Tapatalk
PhilipG is offline
post #19 of 36 (permalink) Old 05-10-2019, 12:22 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
Not sure what. "****e" is...I'D like to buy another vowel please Vanna ;-)
vitesse and Jonnys Bonnie like this.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
post #20 of 36 (permalink) Old 05-10-2019, 12:29 PM
Tornado99's Avatar
I think we need more detail by what OP states as "doesn't start".
Does it fail to go through power on process, with clocks cycling, fuel pump pressurizing? Does the starter solenoid just single click when pressing start button? Multiple clicks but not turning over engine? Turns over rapidly or slowly?
Could be a bad starter relay, bad solenoid, bad starter motor. By bad, it could be the contacts of any of these components need cleaning/tightening. Or component may need replacing.
Only testing each will reveal what needs to happen.
6V Electrical questions Roma Classic, Vintage & Veteran 13 11-21-2018 04:22 AM
Timing marks and Tri Spark Ignition problem tjkoko Classic, Vintage & Veteran 58 11-09-2018 07:12 PM
Persistent Battery Drain Issue Speed Triple arodnyc Speed Triple Forum 14 01-08-2013 11:40 AM
questions about battery life and new selection keithk Air Cooled Twins Technical Talk 14 03-24-2010 08:31 AM
Now a battery issue... menage et trois Speed Triple Forum 4 03-15-2010 01:38 PM
