Tuneecu Mapping - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 04-28-2019, 09:55 AM Thread Starter
Main Motorcycle: Triumph Thruxton
Tuneecu Mapping
Hello,
Can an ECU be mapped on one Thruxton 900 then unplugged and shipped to run on another Thruxton 900? And/or do people ship out their ECU's to be programmed then returned with a new map? I thought there might be adaptation issues or other.
Thank you
Rats Ass is offline
post #2 of 5 (permalink) Old 04-28-2019, 10:24 AM
Main Motorcycle: 2009 Scrambler
As long as the mods for each bike are the same, or both standard bikes then yes, Triumph Twin Power offer a mapping services for their bought maps, you could also start bike and let run for 20mins for it to do adaption
I once has a 955i which had an issue with ecu, bought a used one off eBay fitted straight in and ran with no issues
Ade-955i is online now
post #3 of 5 (permalink) Old 04-29-2019, 05:23 AM
Main Motorcycle: 2008 Bonnie Black Special
triumphrat.net Vendor
PieMan's Avatar
In addition to what Ade-955i said, an ECU for a mechanical odometer model and a LCD odometer model can't be swapped, they need to correct for each model.
Mike (UK)
https://www.triumphtwinpower.com
PieMan is offline
post #4 of 5 (permalink) Old 04-29-2019, 12:06 PM
Supernova
Forchetto's Avatar
Unfortunately I can confirm that .
I bought a used ECU with a view to loading it with the standard map, my bike is now due for inspection every year which means a lot of my mods have to be swapped back to standard, the ECU TTP map included.
I reasoned that rather than go through the re-mapping process I'd just swap ECUs for the Inspection and emissions test.
My bike is a 2009 with mechanical speedo and I found a used ECU from a 2010 model (with LCD speedo) for a good price so I sent for it. The bike won't even run with it and TuneECU tells you that no map can be loaded as it's the wrong ECU for the bike...
I'm now looking for an older ECU to swap with. The used one comes with the following info/map on its label:
Part number: T1290618
Tune: 20506 (although Tune ECU reads map 20446 when connected)
The original one I'm looking for (for my mech speedo bike) should read at least the part number as below:
Part number: T1292106
Tune: originally 20187 (now loaded with TTP's 20333.ttp)
Forchetto is offline
post #5 of 5 (permalink) Old 04-30-2019, 10:55 AM Thread Starter
Hey Guys,
Fortunately I am programming on a 2013 Thruxton to be installed on a 2015 Thruxton... Both LCD with identical mods.
Thank you all,
Rats
Rats Ass is offline
Speed four tuneecu mapping issues Adi Yuci Triumph SuperSports 7 02-26-2019 01:09 AM
2014 Thruxton: TuneECU / Mapping Help Danny900 Air Cooled Twins Technical Talk 11 06-11-2018 03:14 PM
tuneecu mapping Neato23 ECM and FI Tuning - Help, Tips & Tricks 0 05-19-2018 01:00 PM
Comp Werkes PCV (or just go with TuneECU mapping?) NTek ECM and FI Tuning - Help, Tips & Tricks 4 01-03-2012 04:00 PM
TuneECU mapping question David L. Speed Triple Forum 6 05-24-2011 02:57 PM
