Oily substance all over the left side of the engine - Triumph Forum: Triumph Rat Motorcycle Forums
 15Likes
post #1 of 17 (permalink) Old 04-25-2019, 03:16 PM Thread Starter
Main Motorcycle: Bonnie '07
Other Motorcycle: '75 CZ 250 Sport
Hi all,
after leaving my Bonneville standing unattended on the street for two months, I found the left side of the engine part covered in an oily substance. Also, at the same time, I found that the gas tank was empty (it was almost full when I parked the bike and the gas valve was closed).
It's covering the whole engine side cover, most of the cylinder, left cam cover, left carb and a lot of it was on top of the transmisson and even on the bottom rim of the gas tank (ABOVE the gas tank valve). See attached pictures.
The bike caught some dust so you can really see the wet part.
The stuff feels and smells like a mixture of oil and gasoline, but I cannot really identify it. Together with the fact that the tank was empty, this brings me to a hypothesis that the substance could be an old gasoline, but I always thought that when exposed to air, gasoline would evaporate. I have no idea how it could cover such a large portion of the bike.
Hypothesis 1: Someone tried to steal the gas from my tank and spilled some gas all over the engine (not likely but also not impossible in this part of the world).
Hypothesis 2: Someone dropped the bike and some of the fluid leaked - but why would the tank be empty?
Hypothesis 3: The gas valve was leaking - but why would the gas be all over the place? Maybe it was just dripping and because it was windy, the gas could be sprayed even above the gas valve?
Hypothesis 4: Magic
Any idea what I'm seeing here?
The bike seems to be running fine after refueling.
Thanks
ID:	640532   Click image for larger version
ondrej.glembek is offline
post #2 of 17 (permalink) Old 04-25-2019, 06:55 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
I'm going for #3, the petcock leaked. Was it closed when you discovered the mess? Perhaps even someone turned it on 'just to see'...
That's a real mess, hope the stores sell Simple Green there, it'll do it quickly with no residue left.
Good Luck -
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, 19 tooth sprocket, Michelin Pilot Actives.
LapinAgile is online now
post #3 of 17 (permalink) Old 04-25-2019, 06:59 PM
Main Motorcycle: '14 Thruxton
rummy77's Avatar
Agreed. It looks like a little bit of gas and oil that then mixed with water and turned into a mess.
It's tough to rule out option 4, though
'14 Thruxton: TTP Stage 2 (ARK, Tune 11, DNA pods); TEC 2-2 Clubman, rear shocks; Motone TB tops, side bolts, seat bolts, cowl bolts, choke, fuel cap, oil cap, Lucas tail light; halo headlight; billet indicators; bar end mirrors... still in progress!
rummy77 is online now
post #4 of 17 (permalink) Old 04-25-2019, 07:58 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
Someone siphoned out gas and split a fair bit. Explains empty tank and mess even on top of gas cap.
LapinAgile likes this.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is online now
post #5 of 17 (permalink) Old 04-26-2019, 02:37 AM
Main Motorcycle: 2010 Bonneville T100
Ridgy's Avatar
Other Motorcycle: 1975 Norton Commando MK 3
I am surprised your bike was still there.
The Hornet likes this.
Dogs are the best people.
Ridgy is offline
post #6 of 17 (permalink) Old 04-26-2019, 06:01 AM
Main Motorcycle: My old 1967 '500
Twintorsk's Avatar
Did you shut off the fuel tap?
Twintorsk is offline
post #7 of 17 (permalink) Old 04-26-2019, 08:16 AM
Supernova
Forchetto's Avatar
It's a long shot but, have you considered other possibilities?
Joking apart. Many years ago an experienced mechanic told me that if you had a misterious leak on your vehicle the best way to identify its source was to dip your finger in it and taste it with the tip of your tongue. Stuff like anti-freeze has a certain sweet tang, transmission oil tasted different from engine oil, brake fluid a dry sort of taste, etc.
Seemed perfectly reasonable to me until I got to my car every morning and had strange sticky deposits over one of my wheels. I thought it might be brake fluid, but the level was not going down in the reservoir. After a a couple of days I started to taste it, but it had a certain sharp, tangy taste I could not identify.
A few days later I caught a dog pissing on my wheel.
Forchetto is offline
post #8 of 17 (permalink) Old 04-26-2019, 10:49 AM
Other Motorcycle: 1970 TR6R: SOLD....
Extra Motorcycle: 1999 Yamaha Virago 1100
Forchetto: I do hope that he was of a good pedigree.
Sorry, my friend, I just couldn't help myself: Jim
Forchetto likes this.
Jim Ballard
jimballard is offline
post #9 of 17 (permalink) Old 04-28-2019, 05:36 PM Thread Starter
Thanks guys for your answers.
Twintorsk: yeah, fuel tap was off.
LapinAgile: thanks - apparently I can get Simple Green here, but there are more options. Which kind were you talking about?
Forchetto: With that kind of mess, the dog would have to be cow-sized, but maybe I should have a taste...
post #10 of 17 (permalink) Old 04-28-2019, 07:58 PM
LapinAgile's Avatar
I use the standard Simple Green All Purpose Cleaner for about everything, but there may be other types available also, best to do some label reading.
Good Luck -
Thunderbird 900 - Left side indicators not working jimitodd Hinckley Classic Triples 7 11-08-2018 09:52 AM
Right side turn signal won't work! Left side good. scout Classic, Vintage & Veteran 4 03-27-2016 10:01 AM
Thoughts on side or kickstands Forchetto Air Cooled Twins Technical Talk 30 01-27-2016 12:55 PM
Week Left Side AoChalong Classic, Vintage & Veteran 3 05-19-2010 11:50 AM
hot engine (one side) retrobiker Classic, Vintage & Veteran 11 09-18-2007 05:10 PM
