Broken front brake clamp - Triumph Forum: Triumph Rat Motorcycle Forums
 7Likes
post #1 of 15 (permalink) Old 04-20-2019, 10:20 AM Thread Starter
Main Motorcycle: Bonneville SE EFI 2011
Lpar's Avatar
I was finished adjusting the front brake lever angle so I tightened the clamp bolts carefully to 10, then 12, then 15 Nm as per manual.
Shortly after I hear a 'crack' and the clamp has broken in two! As you can see it's that kind of crappy alloy that 'breaks', but I did not over tightened it for sure.
I am very disappointed because spring just started and now it'll take 10 days to get the part from where I live.
Anyway here's my questions: checking Fowlers parts I can only find part T2025450 which is for the clutch. But of course the clamp itself i.e. the only part I need from the assembly is the same for both levers (right?).
Also, apparently I have to order the entire assembly? (Even though it is less than 20 euro... which seems strange!) when I only need the clamp..?
Would you try to fix this with epoxy so I can ride the bike while waiting for the part?
TORs, SAI/O2/snorkel removed, TTP Airbox Cover w/DNA filter, TTP Tune#1, Triumph windshields, G2 Throttle Tamer, NH Low-UK bar, SW-Motech Footpegs, Gammatronix Battery Monitor, Triumph handguards, Oxford heated grips, Denali SoundBomb + more ;)
Lpar is online now
post #2 of 15 (permalink) Old 04-20-2019, 12:55 PM
Main Motorcycle: 80 gl1100
Psycrow's Avatar
I cant answer your question and Ill probably get flamed for saying this... But Yes...you obviously overtightend it... Torque wrenches are for head bolts and thays about it IMO... Torque values are not written in stone and are not some kind of black and white law... There are so many factors going into the forging/casting of metal parts and fasteners ... If your going to wrench on your bike learn to go by feel and not some number in a book. You'll snap fewer bolts and breake fewer cases...
Psy
Not a rant at you OP just a cautionary word of advise to any who overly rely on a Torque Wrench... Now flam away!
Sent from my LG-H873 using Tapatalk
Hedgepig and BonnieJon like this.
A bad day biking is still better than a good day at work.
2015 Bonneville, Mag Wheels, TOR's, Arrow 2 into 2 Map.
Psycrow is offline
post #3 of 15 (permalink) Old 04-20-2019, 01:39 PM Thread Starter
Lpar's Avatar
Psy you are certainly right, I clearly shouldn't have used a torque wrench at all. I have tightened those bolts many times and always using a normal ratchet wrench. Today I thought to do things properly (!).
It's funny that it cracked almost a minute after I was done. And that the other bracket, also tightened to 15Nm, didn't crack.
Anyway I've found the part numbers which are T2025450 (clutch) & T2025411 (brake). So I've already ordered the T2025411 (which anyway, in my hands, looks identical to the clutch side, T2025450).
This joke has cost me 43 euro and a sunny Easter weekend on a bicycle.
Lpar is online now
post #4 of 15 (permalink) Old 04-20-2019, 01:40 PM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
I'd be real concerned about gluing those pieces together. Remember they are your main brake. I know the riding season has just begun but better to be safe that sorry.
BonnieJon likes this.
Ride safe,
Quentin
wenzel850 is offline
post #5 of 15 (permalink) Old 04-20-2019, 02:00 PM Thread Starter
Lpar's Avatar
I was thinking to swap the left bracket with the right one. So the glued one would go on the clutch side. They look exactly the same (unless the mirrors have opposite threads? haven't checked that. They have two different part numbers though).
Lpar is online now
post #6 of 15 (permalink) Old 04-20-2019, 03:07 PM
Main Motorcycle: My old 1967 '500
Twintorsk's Avatar
Nope. No glue. Dont do that. I dont even think that crappy metal can be welded, i was barely able to weld up the clutch lever when it broke..
Twintorsk is offline
post #7 of 15 (permalink) Old 04-20-2019, 03:54 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
Epoxy doesn't hold metal or alu particularly well and in that application it would need to hold a lot of tensional force ....would not hold any real force there. Would need to be wrapped in fiberglass or carbon fiber before having any proper strength.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
post #8 of 15 (permalink) Old 04-20-2019, 04:31 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
Maybe a steel or aluminum strap to bridge from one bolt to the other (with holes drilled on each end for the bolts) would get you by for a few days... Not epoxy.
rweb is offline
post #9 of 15 (permalink) Old 04-20-2019, 10:42 PM
Main Motorcycle: 2013 Rocket 3 Touring
norton74's Avatar
Other Motorcycle: 2013 Torphy SE
Extra Motorcycle: 2012 Bonneville T100
No glue. Get a new part and take it easy installing it.
"Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realize that he likes it."
norton74 is offline
post #10 of 15 (permalink) Old 04-21-2019, 07:48 AM
Supernova
Forchetto's Avatar
It's made of Chinesium... Lots more examples here:
https://www.reddit.com/r/chinesium
Hedgepig, yrunvs and Jonnys Bonnie like this.
Forchetto is offline
Rounded brake pad retaining pin Lewishamilton Water Cooled Twins Talk 2 03-11-2019 07:32 AM
T140 / T150 front hydraulic brake Adam M. Classic, Vintage & Veteran 4 10-21-2016 10:03 PM
Alternative front brake light switch Forchetto Air Cooled Twins Technical Talk 22 01-04-2016 06:39 PM
Replace Front Brake Pads - 2007 Speed Triple KCinWhitby Speed Triple Forum 7 10-22-2012 02:04 PM
Mushy front brake - I'm back!!?? Rich_Williams Speed Triple Forum 16 07-01-2008 04:28 AM
