Carburettores & gas Sensors? - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #1 of 21 (permalink) Old 04-20-2019, 07:54 AM Thread Starter
Main Motorcycle: Triumph Bonneville 2008
TILL_PT's Avatar
Other Motorcycle: Yamaha DT MX 125cc 1980
Extra Motorcycle: Yamaha TDM 850cc 1998
I am a bit baffled right now, really don't know what to make from this.
I have a 2008 Bonneville with twin carburettors. So.... Why da hell do I have gas sensors going into my pipes?
I am I missing something?
I am about to replace my exhausts, and the new ones have the hole for the sensors or a plug to cover the hole.
Shall I keep them shall I remove them?
I have a problem of throttle jerkiness that I have read its attenuated by removing the sensors can anyone confirm? And if so do I.. Just cut them off? XD
Thanks a Lot, help appreciated as the presence of this sensors is humbling me, as I really don't get it
ID:	640034   Click image for larger version
TILL_PT is offline
post #2 of 21 (permalink) Old 04-20-2019, 08:48 AM
Main Motorcycle: 2009 America EFI
MattyMo's Avatar
I'm sure someone can give a more definitive answer than me. But I will throw this out there. You have an 08 and are in Europe? Right about the transition to EFI.
Do you have a fuel petcock for the gas tank? If yes you likely have carbs, if no, then you have a fuel injected model. The faux carbs on the EFI models look very much the same as carburetors.
RichBinAZ likes this.
2009 America with some modifications, a lot of fun that I can ride all day. (sold and miss my 2008 Bonneville, a great daily driver)
this message was created using recycled electrons
MattyMo is offline
post #3 of 21 (permalink) Old 04-20-2019, 09:23 AM Thread Starter
TILL_PT's Avatar
No I dont have a Petcock
TILL_PT is offline
post #4 of 21 (permalink) Old 04-20-2019, 11:18 AM
MattyMo's Avatar
Then it looks like you have a first year EFI model. The O2 sensors are providing input to the ECU. . And yes, you have an ECU, and can connect to it through the OBDII port that is likely under your seat. Check out the TTP site for lots of good info if you haven't already.
BonnieJon likes this.
MattyMo is offline
post #5 of 21 (permalink) Old 04-20-2019, 11:46 AM Thread Starter
TILL_PT's Avatar
OMG this will make my mods so much easier, how was I oblivious to this... so the entire carb is fake?
Tornado99 likes this.
TILL_PT is offline
post #6 of 21 (permalink) Old 04-20-2019, 12:15 PM
MattyMo's Avatar
It contains the fuel injectors and I believe is referred to as a throttle body. I used the "faux carb" term because it uses the carburetor form factor to hide the EFI components but maintains the more classic look of carbs.
Back2-2 likes this.
MattyMo is offline
post #7 of 21 (permalink) Old 04-20-2019, 01:44 PM
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
If you notice your carbs say 'CTK' on them. My stock carbs for my 08 where 'CVK'. Like was said you have a EFI bike.
Ride safe,
Quentin
wenzel850 is offline
post #8 of 21 (permalink) Old 04-23-2019, 04:27 PM
Main Motorcycle: Triumph Bonneville 2006
sonicyouth's Avatar
Carbureted bikes are easily spoted because they have the tps connector at the right side of the carbs. Also, there are not fuel light and there is a fuel peacock.
Triumph Bonneville Black 2006. Norman Hyde Togas. AIS/Airbox Removed. CR35 Carb. Aftermarket Tach.
sonicyouth is offline
post #9 of 21 (permalink) Old 04-23-2019, 04:57 PM
Main Motorcycle: 07 Triumph Tiger 1050
Cloudy's Avatar
Extra Motorcycle: Triumph Bonneville 2013
CVK on Carbs, CTK on Injected Bikes.
07 Tiger 1050,K&N Filter,Snorkel Removed,Storm GP Exhaust,20550 Frankentune Map,NGK Iridium Plugs,Ricks R/R,Ohlins Rear Shock,Ohlins Front Springs,Bar End Mirrors,LED Spots,Leather Seat Cover,Ebay Levers,Ebay Risers,Custom Bars.
Cloudy is online now
post #10 of 21 (permalink) Old 04-23-2019, 06:38 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
I spotted the FI setup from your image...the little 3mm vacuum lines running off the top side of the intake manifolds....running up to the MAP sensors.
I know the fake bodies fool other riders/passers-by, but haven't heard them fool an owner until now!
Don't be disheartened....the fakes are actually made by the real carb company, and just hollowed out for the FI's.
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is offline
Sitting at work smelling like gas and feeling like an idiot dchernikoff Air Cooled Twins Talk 38 05-02-2016 07:27 PM
I can't be the only one with gas cap issues yellow_cad Classic, Vintage & Veteran 16 05-30-2015 08:57 AM
Gas milage? Code Man Classic, Vintage & Veteran 49 01-13-2015 09:58 PM
Ran out of Gas Story Vffr1 Biker Hang-Out 9 05-15-2009 09:56 PM
Help! Gas leak! '07 T100 Kframe Air Cooled Twins Technical Talk 27 10-31-2007 01:03 AM
