Shocks don't pivot on mounts, should they? - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
  • 1 Post By Flash Nick
  • 1 Post By Forchetto
post #1 of 3 (permalink) Old 04-16-2019, 03:27 AM Thread Starter
Main Motorcycle: '14 Scrambler
Shocks don't pivot easily on mounts. Should they?
I've got TEC shocks on my Scrambler, which I've just removed to replace the TEC OE springs with the lighter version and refitted to the bike. When I took the shocks off, the bushes were all seized fast to the frame and swingarm lugs. Rather than butchering the bushes to get them off, when refitting the shocks I just pushed them back over the old bushes and set the bolts to the required torque.
This presumably means that any pivoting of the shocks on their mounts would require the rubber cushion inside the shock eye to revolve on the bush, rather than the bush revolving on the frame/swingarm lug. Seems to me that this would a) cause any movement to be sticky rather than slick, and b) wear the rubber cushion.
Is there in fact any revolving movement of the shocks on their mounts as the suspension moves: does the geometry change slightly as the shocks compress and rebound? Or am I fretting about a problem that doesn't exist?
If it is an issue, what would your suggestions be, please?
Brewers Whoop is offline
post #2 of 3 (permalink) Old 04-17-2019, 06:17 AM
Main Motorcycle: 2009 Bonneville
Flash Nick's Avatar
Other Motorcycle: Kawasaki Super Sherpa
By bush you mean the steel sleeve? The shock eye, rubber bush and sleeve would all be bonded originally. Angular movement is taken up by the rubber flexing, as the sleeve is locked solid. I don't think you have any problems the way you have it, in fact some shocks come without the steel sleeve. Just make sure you have a keeper washer in case it separates.
Forchetto likes this.
Flash Nick is offline
post #3 of 3 (permalink) Old 04-17-2019, 01:02 PM
Supernova
Forchetto's Avatar
You know, I've been wrenching for decades and it never occurred to me that those oversized washers or sometimes a flanged nut had any other purpose than to look good. Learn something new everyday, many thanks.
GiddyG likes this.
Forchetto is offline
Hagon Classic shocks. Cure for the squeaking. Forchetto Air Cooled Twins Technical Talk 44 12-18-2017 01:33 AM
Rear Shocks & Front Springs - Progressive 412 vs. Ohlins 36E w/ Progress Fork Springs blackrod Air Cooled Twins Technical Talk 20 03-24-2015 03:00 PM
Triumph TR6 Shocks Ray the Aviator Classic, Vintage & Veteran 7 03-02-2011 02:10 AM
How tightly should rear shocks fit the mounts? thistle66 Air Cooled Twins Technical Talk 5 05-19-2010 06:51 AM
zrx shocks on a bonneville metasac Air Cooled Twins Technical Talk 5 07-09-2008 11:22 AM
