Cam cover woes - Triumph Forum: Triumph Rat Motorcycle Forums
 9Likes
post #1 of 13 (permalink) Old 04-13-2019, 11:08 AM Thread Starter
Main Motorcycle: 2007 T100 Bonnie
jimmymc's Avatar
Other Motorcycle: 1959 5Ta SpeedTwin
Cam cover woes
2007 T100
Just out in the shed replacing my cam cover gasket. When refitting the new bolts and seals, I stripped one of the threads. I had set the torque wrench to 10nm but hey ho it let go.
I initially went into panic mode, but once I read through some posts on here, the panic subsided, so a helicoil kit ordered and the cam clamp removed.
Should I look to order 2 new bolts for the cam clamp as well
jimmymc is offline
post #2 of 13 (permalink) Old 04-13-2019, 01:36 PM
Main Motorcycle: '02 Triumph Bonneville
LapinAgile's Avatar
More power to you if you got those two torx bolts out already, some apparently can be removed without setting the bike on fire, but I ended up having to grind off three heads when I replaced them during a valve check recently.
Here's a thread covering the complaints and the replacement bolts with hex heads that are a dream to work with:
https://www.triumphrat.net/air-coole...der-bolts.html
Same torque for these as standard - Good Luck
Back2-2 likes this.
'02 Bonneville - AI removed, 152MJ's, 42's 1.5 turns out, Air Box Gone/Uni Filters, TPS removed/capped, NH Togas, Nology Coil, Hotwire plug wires, TTP SafeStart, TTP Firestarter, D9 Bracket, Pingel petcock, Michelin Pilot Active tires.
LapinAgile is online now
post #3 of 13 (permalink) Old 04-13-2019, 03:18 PM Thread Starter
jimmymc's Avatar
Yes I managed to get them off, although it did break one of my torx bits (I wonder if that's covered in Halfords "lifetime" guarantee.
And looking at the bottom of it, someone has butchered it with a screwdriver in the past...Not me
I'll check out that link, cheers
jimmymc is offline
post #4 of 13 (permalink) Old 04-14-2019, 09:25 AM
LapinAgile's Avatar
Yep, there are butchers in the garage not just the meat market. Looks like it doesn't affect anything really, but I know I couldn't resist filing off the rolled side area.
Before the cam cover goes on you could write on the inside in permanent marker - No Screwdrivers!
Back2-2 likes this.
post #5 of 13 (permalink) Old 04-14-2019, 04:28 PM
Main Motorcycle: '01 Bonneville
RichBinAZ's Avatar
Other Motorcycle: '91 GSX1100G
Extra Motorcycle: '14 FZ-09
I replaced those stupid torx bolts years ago with grade 8 hex head bolts from Ace hardware.
Not sure where you get them in Scotland This google link might help
The hardest thing to do with a helicoil is keeping it vertical. If you have access to a drill press, use that.
jimmymc likes this.
RichB in AZ
RichBinAZ is offline
post #6 of 13 (permalink) Old 04-16-2019, 06:07 PM
Main Motorcycle: 1970 Triumph TR6R
McBike's Avatar
Other Motorcycle: 2007 T100
Extra Motorcycle: 1969 Bonnie Basket
I just finished up my second valve check. First one was at 15,000, today was at 30,000. Every Everything was still in spec. One thing I learned about torque wrenches is that don't trust the cheap ones that you pick up in an automotive store. I purchased a 3/8 wrench for $25 in order to do the original check. I brought it into my calibration lab in work. The wrench was + 35% in the low range, climbed to be right on at mid range and - 35% in the high range. I would have stripped out my cap bolts if I relied on the markings. Once I knew where the 10nm was I marked the adjustment dial. I also marked the cap screws and the valve cover, and counted the turns to be sure. When assembling the torque wrench broke right when the marks were.
Mike
RichBinAZ likes this.
2007 Black / Red T100 AI removed, Hella H4 "E" Class Headlight, Feked Toga style mufflers 118 mains 40 pilot 2 3/4 turns out, Dual Star heated grip kit.
First Bike: 1966 Yamaha YL1 Twin Jet
The older I get, the faster I went.
McBike is offline
post #7 of 13 (permalink) Old 04-16-2019, 07:24 PM
Main Motorcycle: 2013 bonneville t100
kunkledude's Avatar
Last year I changed my valve cover gasket and triple-checked my torque wrench with the right settings before honking them down. Everything went back together fine.
kunkledude is offline
post #8 of 13 (permalink) Old 04-17-2019, 12:55 AM
Main Motorcycle: '07 Bonneville T100
CliffGrizzle's Avatar
Same thing happened to me when I was checking valve clearances the other month, those torx bolts are awful to remove. I figured that since I had stripped one, I might as well helicoil all of them. I ended up borrowing a buddy's heat gun and used a manual impact driver to get the bolts loose, and have replaced them with hex-head bolts as mentioned above. I don't have access to a drill press and was not confident in my ability to re-thread one cap let alone all four, so I took them to a local machine shop and they had them ready in a day for about $60 total.
LapinAgile likes this.
CliffGrizzle is offline
post #9 of 13 (permalink) Old 04-17-2019, 06:30 AM
Main Motorcycle: 2009 Bonneville
Flash Nick's Avatar
Other Motorcycle: Kawasaki Super Sherpa
I had same and was sh**ing myself doing the cam holders, it seemed way too tight. Tried calibrating like you and couldn't even get it consistent. Threw it away and use good old feel.
Was looking at digital torque adaptors, has anyone used one?
Flash Nick is offline
post #10 of 13 (permalink) Old 04-17-2019, 07:04 AM
McBike's Avatar
A friend of mine has had a Harley Davidson repair shop. He's been working on bikes for over 40 years. The only torque wrench he will use is SnapOn, he was 3 of them. Also sends them out every 6 months for calibration.
Mike
McBike is offline
cam cover bolt seal questions atlthrux Air Cooled Twins Technical Talk 7 05-15-2017 11:39 PM
Cam Cover Gasket Leak LapinAgile Air Cooled Twins Technical Talk 14 08-29-2012 01:48 PM
Old Cam Cover Gasket Beakster Air Cooled Twins Technical Talk 11 05-16-2012 12:57 PM
Not too technical - cam cover and clearance update ohiorider Air Cooled Twins Technical Talk 10 07-07-2011 09:46 AM
'68 cam cover woes BILLYSIM Air Cooled Twins Technical Talk 6 06-23-2007 10:11 AM
