Starting a T-100 after 5 years (long post) - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #11 of 12 (permalink) Old 04-11-2019, 05:40 AM
Main Motorcycle: 1068cc '05 Thruxton
H3CT1C's Avatar
Originally Posted by zlatansays View Post
This can be done after a fresh oil change yes? I've never done this before and don't want any new oil to drain out by opening something at the wrong time.
No risk of any oil spilling out - even with the bike on its sidestand.
Noob question-- when the cam cover is off, is there anything that shouldn't get oil on it or can I lubricate every moving part?
To paraphrase the old adage: there's no such thing as noob questions, only noob answers! There's *nothing* under the cam cover that *shouldn't* be lubricated. If you're gonna take the cam cover off, do so (and lube the head) *before* you attempt to turn the engine over manually for a belt AND braces approach to security and peace of mind.
Tim
~'05 Thruxton~Sport Evolution 1100cc~FCR 39mm~813 cams~shim-under-bucket~+1.5mm valves~45mm headers~Ignitech CDI~m-Lock~m-Unit~Acewell CA85~F3 Frankenfork~Hagon Nitros~Pretech caliper~520 chain~wide 17" rims~sticky rubber~
H3CT1C is offline
post #12 of 12 (permalink) Old 04-11-2019, 09:51 AM
Main Motorcycle: 2015 Triumph Thruxton
yrunvs's Avatar
Now you've got me interested in removing the cam cover. This can be done after a fresh oil change yes? I've never done this before and don't want any new oil to drain out by opening something at the wrong time. Noob question-- when the cam cover is off, is there anything that shouldn't get oil on it or can I lubricate every moving part?
In any case I won't be manually turning over the engine until i've put some fresh oil in there and at least oiled the cylinder bores.
If you are going to remove the cam cover be aware that the gasket may or may not be able to be reused and that the 4 sealing washers under the cam cover bolts will most likely need replacing as they normally get crushed down when reinstalling the cover. When you get the cover off be careful as there are open slots leading down into the bowels of the motor that things could be dropped into.
This might be helpful....start at the beginning of the video.
TTP Tune#3, NH Toga's.
I'm no Gynecologist but hey I'll take a look.
yrunvs is online now
10,000 Post In Just Under 10 Years LEE Biker Hang-Out 3 01-18-2016 02:20 PM
08 speed - constant neutral light, not starting post low-side, 9 fault codes DROIDbehavior Speed Triple Forum 3 05-30-2015 09:01 AM
1st post from a 1.5 years 2013 Thruxton rider BeetleGoose The Welcome Center 2 02-23-2015 11:00 AM
Post test training - 30 years late PatrickO RAT - United Kingdom 1 04-18-2010 03:37 PM
